Question about Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive
My hard disk goes hang when it boots the bios and cannot detect it. but my hard disk is still running.
I have a similar problem with an 80 gb drive in a Compaq. I've isolated it to the cable or the connector on either the motherboard or the drive. Try unplugging the cable at each end, then plugging it back in. Reboot. If it finds it and works normally, you have 1) a bad hard drive cable 2) a bad hard drive controller socket on the MB (bad MB :-( ) or 3) an intermittent connector on the hard drive. 1 is easy. 2 and 3 are problems. Try a different drive and see if it boots reliably every time - if so, suspect the drive. If its the MB, probably time to UPGRADE.
Posted on Dec 04, 2008
Try to install a window 7 on a gatewaydx4870 I cant find the hard drive driver not found
If you are just trying to install from a bootable Windows 7 disk, the BIOS itself provides the basic hard drive driver, otherwise the system would never be able to load an Operating System. Now what you are probably experiencing is that the system cannot find the hard drive itself to begin the installation process. You need a hard drive in order for the system to load the files for the OS. When booting, press whatever key(s) is/are required to access the CMOS (BIOS). Look in the general information area to ensure that a hard drive has been detected by the BIOS. If one has not been detected, shut down the PC, then check the power cable and data cable connections of the hard drive to the power supply and mainboard, and then power up and check the BIOS again. If you still do not see a hard drive detected, should also look in the advanced settings area to ensure that the SATA port where the HDD data cable is connected to ensure that it is enabled and has not been disabled in the BIOS. If, after all that, you reboot and the drive is still not detected, then you have either a defective hard drive or mainboard. If the hard drive is showing in the general area of the BIOS, then look in the boot order/boot sequence area to ensure that the hard drive is included in the boot sequence. It should normally be the second boot device, with the optical disk drive being the first in the order.
Oct 16, 2016 | Hard Computers & Internet
Tip
NO BOOTABLE DEVICE
When the computer/laptop cannot see a boot file/disk on either the hard disk or floppy drive it gives an error message - "No bootable device. Insert boot disk and press any key"
First thing, check to see if the is a floppy disk inthe floppy drive, if so removes this disk.
If there was no disk in the floppy drive then it maybe a hard disk problem.
Check the BIOS to see if the hard disk is detected, if not open the case and re-seat the data cable on the hard drive and also where it connects to the motherboard disk controller.
If it still gives this error message and the BIOS does not detect this hard drive, then the hard drive is probably faulty.
A further check on the hard drive, remove the hard drive and connect it to an USB hard drive adapter and connect it to a working computer's USB port, if this computer does not detect it as an external storage device then the hard drive is faulty.
To get the computer operating again, install a new hard drive in your computer and then install Windows on this hard drive plus the computer's device drivers and your programs.
on Oct 02, 2010 | Computers & Internet
How to fix my desktop hardisk?
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty. . Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Jan 13, 2013 | Computers & Internet
Hard disk is not detecting
Nov 08, 2012 | Computers & Internet
Hard disk is detected in BIOS setup, but after boot it shows "DISK BOOT FAILURE, INSERT DISK" So what can i do now
it means insert your copy of windows operating system to finish the installation if you already have a operating system on your hard drive and if you dont wish to remove it when in bios scroll down Adavanced bios features and change settings on first boot device
Aug 27, 2010 | Computers & Internet
I am not able to instal OS in my home PC. Asking me to install scsi drive. my hard disk seagate. where download this flopply disk bios drive software
hi
Checked the Bios Setting and check whether the Hard drive is recognizing or not -
Check the Boot sequence
Check Boot from the CD Drive
Format the Hard drive
it will work
Feb 23, 2010 | Seagate 500GB Maxtor Diamondmax21 SATA2...
Hard Disk hangs
You have to give it for reairing or buy a new hard disk..
Aug 22, 2008 | Seagate Barracuda (ST380215A) 80 GB IDE...
Hard drive stops booting
Hi, If your computer stops booting from the hard drive and is asking for a boot disk, then: 1. The motherboard/PC is no longer recognizing the hard disk; 1.1 Go to your CMOS/BIOS setup and manually detect the hard disk, save & exit. 2. The CMOS/BIOS is set to boot from other devices such as CD, FDD or USB but not from the HD. If after configuring the CMOS/BIOS and the hard disk is not recognized, then it is probably defective and therefore need to be replaced. If the hard disk is recognized but will not boot, then some files of your OS needed to boot are missing, corrupt or overwritten. You would need to re-install your OS and opt for a "repair". Hope this be of some help/idea. Post back how things stand or should you need additional information. good luck and kind regards.
Oct 01, 2007 | Fantom Drives EXT HD 80GB| MTT80 RTL Hard...
I delete all the partitions from my hard disk. i didn't make partition.when i restart the system,msg came that nofixed drive present.bios don't dectect my hard disc.my hard disc is maxtor d540x-4k. how can...
Assuming this was your only hard disk, there is nothing on the disk for the BIOS to boot from. You need to boot from the installation disk for your operating system. The OS installer will then let you create a partition and install to it.
Mar 06, 2007 | Maxtor DiamondMax D540X 40 GB Hard Drive
CMOS auto detection of samsung SP0411N HDD stops and hangs
Hi download this program its seagates diagnostic tool, put in floppy disk and run program to make a boot disk, restart pc, and let it boot off the floppy disk and it will test the drive for you... http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=DiscWizard&vgnextoid=d9fd4a3cdde5c010VgnVCM100000dd04090aRCRD All the best john
Feb 16, 2007 | Samsung (SP0411N) 40 GB Hard Drive
Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive Logo
62 people viewed this question
Top Seagate Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Mark Taylor
Mark Taylor
Steve
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
