Question about Bosch & Tankless LP Hot Water Heater
I have a 2nd hand Bosch HydroPower LPG hot water system and am trying to find a manual. do you have one or is it pretty straighforwward in terms of installation? Mike
I have just dug my manual out (16H) because mine is faulty. email me and I will photocopy it at work this week and email it back to you.
Installation should be pretty straightforward and the manual's not that in depth. There are however some sections on adjusting the gas and the like that you might want to read over.
mchankey at gmail.com
regards
Mark
Posted on Dec 06, 2008
Need help with Bosch hydropower 13h tankless hot water system
when you turn on the hot water tap there is a pressure switch in the line that sends a signal to a gas solenoid to pass the gas and at the same time to the pizo to start the flame
I would have that pressure switched checked as it may be sticking ( internal contamination) or have dirty corroded points
as gas is involved I would suggest a gas technician do the jib
when you turn off the tap, that pressure switch is shut off so the gas is turned off at the solenoid and the pizo is stopped.
May 21, 2015 | Bosch Water Heaters
Bosch hydropower 13h gas water heater not working
the tank is possibly full of gunk and the thermostat is not sensing the request for hot .flush tank if you can thru the bottom drain a few times if it is bad enough that ou get no water out then only option is to replace with a new unit
I have a instantaneous water system 10H Hydropower ...did not get a manual when installed....I need to have hotter water as it's winter and the water is like warm...not sure what to adjust...opened...
take the cover off the 10 h unit light up the burner by turning on the tap turn the water flow tap on the front of unit (white knob) clock wise slowly feel hot water pipe coming out off unit when temp increases put cover back on check temp at sink if too hot turn knob anti clock wise
May 23, 2011 | Bosch Water Heaters
Hi, first of all, HAPPY HOLIDAYS! now...I was given a Bosch AQ125BNG in need of some repair but I want to convert it to LPG gas, can this be done? I am having a heck of a time even locating the LPG valve...
Happy Holidays to you too.
You will also need to change the
Burner
Nozzle
Pilot injector and the
Gas regulator in order for the unit to function properly. You might try running a ad on CraigsList. If you cannot find one for free, you may end up spending more money then the unit is worth. You could also put the word out with local plumbing companies that replace these heaters to look out for a used one. Some one out there has to have one those laying around.
Dec 19, 2010 | Bosch & Tankless LP Hot Water Heater
I have a 16h Bosh hydropower hot water heater . The unit suddenly has no spark .I have taken off the little generater cap and thouroughly cleaned it and the internal turbine . With no improvement . All...
sounds like the generator has packed up. check water flow and clean any filters on the water line. you will need a service agent to check milli volts on generator and power pack
Dec 15, 2010 | Bosch 1600H-LP Liquid Propane AquaStar...
Burners will not disengage after shutting off Hot Water.
Ok the way this system works is from a pressure and flow switch. The pressure switch picks up the slight drop in pressure when the hot side water is turned on then turns on the burner. The flow switch measures the amount of water flowing and adjusts the size of the burner to the amount of water flow. So a couple different things might be happening. The flow switch might be sticking causing the water heater to throttle down the burner but not off when the water flow is off. Or the gas control valve might be by-passing gas when off causing the burner to stay on even when the demand is off. Run the hot water on high demand then turn the water off. If the burner is still on try banging on the water heater with your hand and see if the burner shuts off completely. If it does the gas control valve might be by-passing. You would also need to check and see if the pressure/flow switch is giving any voltage signal changes when the water flow is off. These tankless water heaters are more comlplicated to work on than a standard water heater and you may need a professional's help...good luck
Sep 23, 2009 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
24i boiler lpg water gets to hot
temperature control knob may not be properly connected and not actually turning the spindle behind it.
OR if the flow through the hot tap has become reduced over the years there could be furring in the heat exchanger
Aug 15, 2009 | Bosch Water Heaters
Low Water Pressure Gas System but High Pressure when Solar Water
if you have a gate valve on the unit from the hot water tank it could be as simple as the valve on the gas system being clogged going to that bathroom,, from how it is described it sounds like that would be the problem check to make sure all valve are not stuck in the on position ans change the valve if it is frozen in place
May 22, 2009 | Water Heaters
Bosch & Tankless LP Hot Water Heater  Logo
573 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
john h
Paul Nielson
Paul Nielson
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
