Question about Sony Handycam DCR-TRV510 Digital Camcorder
Sony DCR-TRV510 error code C 31:10 tape bay closes then opens
the door at one time was completly jammed open and wouldnt close
now it closes(without the tape and with it ) sits for a few seconds then open, playback is not possible.
ilooked at the internals i dont think nothing is in there hindering movement..
  • roman_t14 Dec 04, 2008
    additianl info to the above problem.
    when it closes it closes pretty smooth, without the tape
    goes all the way closed
    with the tape sometimes it does not close all the way.
    but still no excessive sounds.
    Scholar:
  • 107 Answers
The error code was indicated the LS chassis assy is defective, bad luck it require a qualified Tech trained from Sony. I suggest you to bring it in Sony to repair it would cost you about from $180 to $250 if you are in AUS
I hope that give you some ideas
Posted on Dec 04, 2008
I have a Sony Handycam DCR-HC-48 and the tape door won't close along with a 32.11 error code.....HELP
Try these steps:
1. Open the tape cover fully until it clicks open.
2. Turn the camcorder on to "VCR Mode."
3. With the cover still open and the camera in "VCR mode," take out the battery.
4. Put the battery back in--out should pop your tape.
Keep us updated.
Jun 06, 2011 | Sony Handycam DCR-TRV140E Digital...
When I put my tape in the camcorder and close the metal door, the tape does not go down. but when empty, the tape holder do go down.
Hi, My Sony DCR-HC32 handycam's tape mechanism is giving me some problem. It ejects and the tape deck opens up properly but after putting a tape and closing it, the tape deck does not go in. I tried with or without tape but it doesn't go in. It is still open.
Can you please suggest how it could be fixed?
Thanks,
Pramod
Nov 26, 2010 | Sony Handycam DCR-HC32 Mini DV Digital...
Door not open
Before doing anything the numbers on this code tell you to clean camera and heads.
After it should all be fine.
Jul 02, 2010 | Sony Handycam DCR-TRV280 Digital Camcorder
Opening the tape compartment
something may be jammed in one of the hinges of the compartment door.
Jun 26, 2008 | Sony Handycam DCR-PC100 Mini DV Digital...
My camcorder tape door won't close
Try removing the battery for a few seconds, and then re-inserting. This seems to reset something on my DCR-TRV20, and it starts closing properly.
Jun 15, 2008 | Sony Handycam DCR-HC48 Mini DV Digital...
DCR-HC42
  1. I'm having the exact same problem. It wont accept the cassette...only half way then errors. It will close fully without a cassette as well. hmmmmm
Comment by Guest, posted on Apr 02, 2008 Load cassette, turn it on, then message says re-load cassette. Door to cassette compartment only works half way. After fiddling with power, can get the cassette door to open and close all the way, but not with cassette. Tried several brands of cassettes, no joy.
Mar 09, 2008 | Sony Handycam DCR-HC42 Mini DV Digital...
TRAP DOOR WONT CLOSE
I had the same problem with my camcorder. I removed the tape transport control from the top of the unit (be careful not remove the attached ribbon cable). It appeared that the ribbon cable attachment was bent a little. I straightend it out and reset it in the camera and re-attached the transport. Once this was complete I returned power to the unit and pushed the door closed and the trap door closed in place.
I was also having a problem with the unit not wanting to play the tape. I was getting Error Code C:31:XX or C:32:XX. I read in another forum that several people with same error message tapped or hit the tape side of the unit (similar to the way a television would be hit to try and get a signal). I had previously called Sony but the repair would be about half the cost of the camera ($500) and a repair shop quoted me $400. With nothing to loose I smacked the side of the camera a few times and belive it or not "IT WORKDED!!!" Something mechanical must have been out of line or loose. Unfortunately I purchased a New JVC Hard Disk camcorder prior to trying this, so now I have two perfectly good units.
Jan 18, 2008 | Sony Handycam DCR-TRV510 Digital Camcorder
"Re-attach the power source" but tape is stuck, door open
I had the same problem. First, depress the reset button, located on the camera body (where the LCD screen closes over it). It is hard to see at first. It is important that the camera be set to the OFF position. When the camera is whirring after the reset, then hit the EJECT button so the tape comes out. Take the tape out and insert it back. That's it. My camcorder worked fine and let me record or plaback once I followed those steps.
Vic
Aug 22, 2007 | Sony Handycam DCR-TRV280 Digital Camcorder
Sony Handycam DCR-TRV510 Digital Camcorder Logo
298 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
