Question about Kenmore Washing Machines
I need new water pump for model no.: 417.42042100 serial no.: XC
How do I order this replacement part?
  • 50 Answers
Posted on Dec 04, 2008
Water does not completely drain from bottom of dishwasher when cycle has completed.
May just need to take sump apart and clean or you need new drain pump
Mar 23, 2015 | General Electric Dishwashers
I bought a new KK and it seems to have such strong suction to the bottom that it doesn't move along very well!!
adjust the speed control to allow more water to bypass. your pump is too strong for the situation. Call bob 61243690299 if you do not have a speed control
Jan 11, 2015 | Pool & Spa
Repair shop said steering pump expolded on our 2000 Volvo XC V 70
never heard of the pump exploding... bursting one of the high pressure lines is more likely. new belt afterwards? sure. new battery? dont see how it could have harmed the battery. new tie rod? no way did this damage a tie rod.
replacing burst high pressure line 75.00 for parts
replacing belt 15.00 for parts
replacing power steering pump if needed no more than 150.00 for parts. thats 240.00 for parts... for the sake of argument lets double that for labor. 480.00
replace tie rod (in no way damaged by power steering pump) 35.00 to 125.00 depending on where you get it. installation cost about 75.00 (Tie rods can most often be adjusted to correct problem without having to replace them.
now, new battery (probably not related to the burst line) anywhere from 40.00 to 200.00 from autozone with free installation.
Feb 11, 2014 | 2003 Volvo XC70
Oil capacity for a devilbiss cac-4029 pump
The sears manual that has that pump in it lists the oil capacity as 16 oz. of 30 wt non-detergent oil. If you need parts, many are still available under other manufacturers like porter cable. Several parts are only available in kits. Ring kit KK-4313, Reed valves KK-4275, Gaskets KK-4312-2, valve kit KK-4315.
Jan 09, 2012 | Computers & Internet
I need to order a new internal tube air chamber unit as the seams have begun to pull apart. Please give me a resource for this. It is Skedaddle 1 model AE1001-WM . It is 8 ft. 4 inches over all Beam is...
Might be cheaper to get a new one at WestMarine. I just saw the Skedaddle 1-XC on clearance for $202 in the store. The stores are limited to whatever they have in stock, so you might want to call your local store to see if they have one or if they can find one in inventory at one of the other stores in your area. They also have the Skedaddle 2-XC on clearance for $285 if you were looking to upgrade to a two-person kayak -- I just bought one of these myself.
Aug 06, 2011 | West Marine Skedaddle 1-XC Solo Inflatable...
KK hugs sides and adges
Try lowering the suction first. If this is a new unit you should have received a suction gauge with it. Make sure to set it to factory specs.
Feb 16, 2010 | Universal Kreepy Krauly In-Ground Pool...
Water will not drain
Need new drain pump. You will need to have Model and Serial number when you call to order a new pump or belt.
Jan 06, 2010 | KitchenAid Dishwashers
Need to find parts dealer for Ariston dishwasher
Please let me know where I can order replacement part for LI 700-NA I need a water valve, serial number of that part 409245172. Thank you
Feb 02, 2009 | Ariston Technologies Dishwashers
Kenmore Series 70 washing machine whines and low flow on cold H2O
Thanks for your request, you do not specify exactly what the problem is, I am assuming it a problem with the filling cycle.
Turn off the water to the washer, remove hoses and check and clean the wire mesh filters in the valves, before reconnecting hoses, check the water pressure, reconnect and test, if you are still having a problem with it filling, then you may have to fit a new valve.
They are straight forward to fit.
To order a new valve, go on line to Kenmore washers.
I cannot give any more info as to where they are, as I am in the u/k, and we do not have Kenmore washers here.
Hope this helps you .
Plz rate my suggestions,and leave comment if need be.
Jan 21, 2009 | Washing Machines
Open Questions:
Washing Machines Logo
41 people viewed this question
Sal De
 Brian Main
Brian Main
