Question about E-Machines eMachines Desktop PC
Computer wont turn on
When you press button on front fans start, and buttons light up. then3 to 4 seconds later about the time monitor should show something it, it turns off. It is an emachine 2616
    Problem Solver:
  • 13 Answers
You might try turnin yer PC off & unplug. Then open the case & carefully remove the battery. Let sit for 5 min. Re-install the battery & put it back together. Plug in & turn on. IF you get a screen givin you the option "last known good configuration" take it
Good Luck
Posted on Dec 04, 2008
What's your question? my proline laptop is not showing up the screen but it does show that its charging but doesn't show up the screen
That could be many problems. what your telling me is that u see the charge light when u charge it but when you turn it on nothing happens? this could be a number of things. I would hook up a monitor and see if anything shows up on the monitor if the laptop boots. if something does show up then its your laptop display cables that are bad.
Try This
--> First turn your computer off by pressing and holding down the start button. Next unplug the computer and then remove the battery. Press and hold down the start button for about 60 seconds. Release the button and plug in the computer. Press the start button and the display should return. Replace the battery. If this does not work, try it again up to four times. No results usually indicates a bad mother board. Hope this helps.
Mar 05, 2016 | Computers & Internet
Tip
Oldsmobile service light 1991-01
Alero
2000-01
Turn the ignition to the ON position, engine OFF. Press the RESET button and release. The CHANGE OIL indicator will start flashing
2000: Press and release the RESET button again.
1999: Press and hold the RESET button until an audible chime is heard and then release the button.
Intrigue
2000-01
Turn the ignition to ON without starting the engine. Fully press and release the accelerator pedal three times within five seconds. If the CHANGE OIL SOON indicator flashes two times, the system is resetting. Turn the key off after the the light has finished flashing, then start the vehicle. If the CHANGE OIL SOON indictor comes back on, the engine oil life monitor has not reset. Repeat the procedure again. If the vehicle is equipped with the U20 option code, the vehicle as an oil life low indicator. The oil life low indicator shows an estimate of the oil's remaining useful life. When the oil life index is less than 10 percent, the display will show OIL LIFE LOW. To reset the oil life monitor, press and hold the MODE button until the light appears next to OIL LIFE. Press and hold the trip RESET button until the oil life percentage changes to 99 percent.
Alero,
Intrigue,
Cutlass Supreme
1999,
1998,
1996-9
To reset the "CHANGE OIL" light, turn the ignition switch to the "RUN" position with the engine off. Fully depress and release the accelerator pedal three times in five seconds. The light will flash twice and go out.
Aurora
1995-99
To reset the "OIL LIFE" message, press the "ENG" button with the ignition on until "OIL LIFE PERCENTAGE" is shown. Press the "RESET" button for 5 seconds. "RESET" will appear and then "OIL LIFE" will show 100%
Eighty-Eight,
Ninety-Eight,
Regency
1994-97
When "CHANGE OIL NOW" is displayed, press the "RESET" button. Press "SEL" to display "OIL". Press "SEL" to display oil life. Press and hold "RESET" for 5 seconds. A "RESET" message should display with oil life changed to 100%.
Eighty-Eight,
Ninety-Eight
1992-93,
1991-93
Press and release the "TEST" button on the Driver Information Center. This will illuminate "CHANGE OIL NOW" if it is not already illuminated. Press and release the "OIL" or "OIL INDEX" button. Next, press the "RESET" button and hold for at least 7 seconds.
Toronado,
Trofeo
w/o CRT Display
1991
To reset "OIL LIFE INDEX", press the "2 OPTIONS" button: three times if the vehicle is equipped with a phone and compass, once if equipped with neither. While "OIL LIFE INDEX" is displayed, press and hold the "RESET/ENTER" key at the bottom right of the 15 button switch for 5 seconds.
on Dec 07, 2009 | Oldsmobile Alero Cars & Trucks
Acer x3400 wont start up
Remove the Power Cord and then press and hold the power button for 30 seconds. After 30 seconds plug the power cord back in and press the power button. If it reboots you had a Static Charge Buildup and released it by holding the power button for 30 seconds.
When you press the power button do you hear the fan running, disk drives running, cd drive clicks once, anything on the lcd screen? If not I would think your Power Supply is bad and needs to be replaced.
It's either the Power Supply or Motherboard.
Mar 23, 2012 | Acer Aspire X3400 PC Desktop
My dell S1709W flat panel monitor turned white
http://support.dell.com/support/edocs/monitors/S1709W/en/ug/operate.htm#Using the Front Panel
NOTE: You can also lock or unlock the OSD by pushing and holding themenu-logo2.gifbutton for 15 seconds. (Top of the buttons on right side)
Apr 07, 2010 | Dell Computers & Internet
PS3 Display settings issue
Carry out the following steps to solve your PS3 problem :
Step 1. Turn the PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep as soon as you press it and then about 5 seconds later it will beep again. Let go of the power button when you hear this second beep.
Step 3. Wait for your PS3 to start.
This solution basically resets the video output back to standard definition.
Hope this helps and thank you for using FixYa
Nov 09, 2009 | Sony Playstation 3 (PS3) Console
Wont boot/start
Turn off power, unplug, hold power button for 30 seconds, take out memory, or if you have more than one stick only take all but 1, plug the power back in and start the computer. If a screen pops up that bios has changed press F2 to continue once computer is completly loaded click start, shut sown, unplug power cord again, hold power button 30 seconds, insert other memory and restart
May 13, 2009 | E-Machines eMachines Desktop PC
LCD blank screen, blink white
blank_page Use a reset sequence on the monitor-
1. turn off monitor
2. unplug power
3. plug power back in, holding down the last button on the left, then push the power button to turn back on and off three times, holding on the third try until it comes on- hold for ten seconds and release; the monitor should work again
Jul 28, 2008 | Computers & Internet
Control locked on ghw920 can u help me unlock
Press and hold the End of Cycle Signal button for three seconds. This will turn off the Control Lock feature.
Jul 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
HP Pavilion DV2036e Wont Boot
similar cases,,,,,,,,won't boot,,,,,1.) if with black display; please check your ram memory, if you have 2 take out it all and replace it one by one, try to boot one at a time,,2.) if with black display and the pan start functioning maybe your cpu is dead, try to switch it to another computer with thesame socket and voltage,if this computer won't boot also,maybe you got the answer.........hope to help
Dec 24, 2007 | HP Pavillion ZV6000 Notebook
3yr old got ahold of monitor
ok, get to the event where you get this to happen "...then turn it back on the monitor does come on normally...", but just after power-up, press the F8 key to go to safe mode. If nothing visible, press ENTER anyway...get to safe mode yet?
Oct 27, 2007 | Computers & Internet
E-Machines eMachines Desktop PC Logo
70 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
