Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Can convergence correction be handled by a novice?
Dear Ladywinn,
I saw that you seem to know a LOT about TVs. Do you think fixing the convergence is something we could do without a repairman? I live in the middle of nowhere (40 miles from the nearest city) and have looked high and low, but no one will come to my home for a house call. I don't own a truck and even if I did, I'm a woman and couldn't load this monster up.
I appreciate your advice!!
Peggy Lee
  • Philips Master
  • 5,138 Answers
You have 2 big black chips these ics control power off/on as well as the convergence circuits STK392-110s use 180s Go by the number on STKs replace them both, also you will need someone who can solder.Good Luck ! Let me know if you should need anymore help.
Posted on Dec 13, 2008
Rca hd56w66 convergence problem. ladywinn said it was a fuse where do i get replacement fuses?
that tv has a convergence module and a convergence power supply it also has a block fuse on sweep module but i can promise you replacing a fuse will not correct your prob. the fuse is there for a reason if it opens there is a prob.but i dought its opened its located on sweep module there will be 3 block fuess in a row on the left side of the sweep module they are small red blocks good luck
Feb 03, 2010 | RCA HD56W66 56" HDTV
Rca d52w23 has distorted picture. it is shaped
Go to menu then setup look for convergence if not on menu you have a blowed fuse FL231 will be next to FBT flyback transfomer on right side there is 3 in a roll small brown looking caps but they are fuses it will be the one in the middle.You can take a pair of plyers to pull off top they are all removeable and just snap back on.
Sep 15, 2009 | RCA D52W23 52" HDTV CRT TV
Convergence amp
You usually have to replace the two ICs at the same time along with resistors to get the longest life from the Convergence amps. You can get the repair kit for your model at the following link which contains both ICs and all 6 resistors plus instructions with pictures that explain how to do the repair yourself. Heres a link to the correct kit for your model Toshiba.
http://servicemanuals.vstore.ca/product_info.php/pName/toshiba-50h71--50h81-convergence-repair-kit/cName/convergence-repair-kits
May 18, 2009 | Televison & Video
Two picters, round on top and round on bottom
You are right. Check the convergence ICs and resistors.i don't know the resistance values . But that seems to happen a lot with Projection TVs
Nov 28, 2008 | Televison & Video
LCD Television
I live in Canada.
Personally I do not think many service techs do this type of component level repair.I would suggest to ask around and see if someone can fix it.
If you decide to send the power supply for repair, let me know.
Nov 12, 2008 | Astar LTV-3201 32 in. LCD Television
Convergence and HDTV Screen Issues
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Convergence adjustment procedure to many popular brand TVs are given.
Mar 04, 2017 | Televison & Video
TV powers on for about 5 seconds and then powers off
I really dont think resistors need changing on this make and model first check hori out put NTE2973 capiactor may be burnted 1200pf 2kvolt, this is what i found wrong with customer set after getting tvs high voltage up then i saw that convergence ic needed to be changed out also.If you need more help let me know ive been up all night,will answer as soon as i can.
Mar 06, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Mitsubishi ws-65819
The correct part# for the two convergence ic's is = STK392-570. The repair is close to $400
Aug 21, 2007 | Mitsubishi VS-60601 60" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
19 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
