Question about Mitsubishi WD-52725 52". Rear Projection HDTV
Cant access "Antenna" in tv menu to change to cable
I own a mitsubishi WD-52725 and for some reason when I hook up my cable I get 27 channels. Some of these channels are "basic" and some of them are "extended basic" like G4 and national geographic but Im missing tons of channels from both tiers. I've been told I need to program them into my tv. But to do that, I need to access the antenna option which is just a grayish color that I cant even select. I had a cable box previously and that worked fine but im downgrading to just extended cable and now im having problems. Can anyone help?
  • TVCableKid Feb 04, 2009
    I am having the same problem except that the problem was caused when switching cable cards from a Motorola single stream cable card to a Scientific Atlanta multi-stream cable card. I cannot choose either "air" or "cable" in the tv antenna menu because it is greyed out. As a result, a lot of the channels won't stay programmed into the tv. Help!
It sounds like you haven't selected cable in the "pull-down" menu. You see, you physically have to tell your tv if you're selecting "over-the-air" programs(free), or cable. Select the cable option &
then run "auto-select". Your tv will go through it's steps & find your cable stations. I hope this helps.
Posted on Oct 23, 2007
The tv is connected to Dish Network as TV2. I accidentally changed the channel & now I can't get it back to channel 90 - it only goes to 13 now. How do I fix this?
In the menu screen, you must find antenna connections. For example " TV Air "(over the air channels 2 through 13) or cable TV. You must tell the menu to select cable TV (with the original remote). This will allow you access to channel 90. Thanks for asking and show a few hands of support.
Nov 07, 2010 | Orion STV2763 27" TV
Crashed WD-52725
contact mitsubishi consumer relations and see if they will offer any assistance on this
then check with the attorney general and see if there are others with a complaint against mitsubishi
good luck
Oct 31, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Timer light is flashing and I cant turn on tv
The V26 DM repair kit should take care of that issue. The kit has the caps and the instructions. You can get it at www.tvrepairworld.com
Aug 03, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Can't get it to go above channel 23... (nothing wrong with cable hook up)
all done so far looks good. But the part where you went into the menu is about i'd like to talk:
before you send to auto-program feature. try to find changing the band where the tv is working now.
Let me explain.
The tv is looking channels in the antenna or air band. Make sure you change the selector to CABLE.
this selection usually it is previous to send to auto-program.
if all this was done and nothing change, we need to send the tv into the workshop to check the tuner and voltages related to it.
Apr 14, 2009 | Televison & Video
Mitsubishi DLP wd-52725 wavy lines from top left to bottom right
the DM board is going bad and needs to be rebuilt. check out www.tv-techs.com
Jan 02, 2009 | Mitsubishi WD-52725 52". Rear Projection...
WD-52725, Denon 1508 and a PS3
use the component cables that will be your best bet.
Apr 29, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Can't get 1080
VJ-TRY RESETTING THE COMCAST RESOLUTION BY TURNING OFF YOUR CABLE BOX THEN PUHING THE CABLE BOX MENU AND YOU CAN USE THE ARROWS ON CABLE BOX TO ACCESS THE 720P AND CHANGE IT TO 1080I.JOE TV
Nov 23, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi WD-52725 52". Rear Projection HDTV Logo
209 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
