Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Igniter is on, gas is released, a small explosion occurs in oven
I'm afraid to turn on the oven & leave it on until the gas ignites because when it does go on, a small explosion occurs. I've replaced the burner. I think it's the igniter but I'm not sure. I put a replacement igniter but I am scared to leave it on until it lites up the oven in case an explosion occurs. How long should I leave on the oven before the explosion is too severe. Is the explosion bad enough to cause damage to the house. Maybe the new igniter works but I'm not giving it a chance to light. Please reasure me that all will be ok if I leave the oven on until it lites up. I know that the igniter is hot enough to open the gas valve because I can hear the gas being released. If it doesn't ignite immediately, I shut off the oven. Is there any other causes of this explosion besides the igniter. Does the igniter need to be extremely close to the burner. If so, how close. Mine looks like it might be too far away.
  • lvlamb Apr 13, 2009
    I have the same problem. The small explosion blows the door open a little. I don't think that"s normal.
  • rnbraun Apr 16, 2009
    We have had the same problem. I had GE replace one of the ovens already but the second one is doing exactly the same.
    Sergeant:
    Champion:
  • 251 Answers
No the little boom before it lites is normal mine does it all the time
Posted on Dec 04, 2008
Delayed oven ignition
see the next steps and proceed with common sense:God bless you
Fuel Type
If this is a new installation make sure the gas valve has been properly adjusted for the type of gas. Lp and natural gas use different orfices and pressures. A conversion kit is available.
Burner
The burners may need to be cleaned. There are small holes that allow gas through holes that are ignited by the igniter. These holes can become clogged up. You can usually clean these with a toothpick or small wire, watch the video. If it is the oven burner and you have a small flame or it does not stay lit check the video on troubleshooting a gas range.
Gas Valve
The gas valve rarely fails but this can. If the gas burners are clean and the gas valve is properly adjusted replace the gas valve. This should be done by a professional. Leaks can be very dangerous and also the gas pressure needs to be adjusted for the type of fuel you are using.
Jul 27, 2012 | Kitchen Ranges
Frigidaire GLG=F366asd stove igniter problems and solutions . ... on the element lights up the smell of gas is real strong and then it lights and sounds like an explosion.
Where is the problem -- in the oven burner or a stovetop burner?
If something got spilled on a burner ring and clogged the small holes, especially near the igniter, the burner will be slow to light. A stiff wire (small enough to fit) can be used to clean out the holes.
Mar 18, 2012 | Kitchen Ranges
Oven turns on gas but doesnt ignite until theres gas build up and has small explosion. kenmore model 362.75702001
What is causing that is a weak oven igniter that is not strong enough to fully open the gas valve yet just open it a little,letting gas accumalate in the oven then finally the igniter gets to full strenght and all the gas explodes. By replacing the igniter with a new strong one it will stop that.
The igniter is pretty easy to replace. Just remove the floor of the oven and the wing looking flame spreader, the screws that hold igniter to bake burner can be removed, and disconnect wiring.Then attach new igniter to burner reconnect wires and reinstall spreader and floor .
The part number for igniter is WB13K21 it could be purchased at your local appliance parts store or online at;
repairclinic.com
searspartsdirect.com
apwagner.com
appliancepartspros.com
apdepot.com
I hope i have been able to help you fix your oven,
Gene
Aug 13, 2011 | Kenmore 30172 / 30174 / 30179 Gas Single...
My GE oven takes a long time to lite. When it finally does there is a small explosion sound. I already replaced the ignitor 2 weeks ago. It worked fine for about 1 week and now I have the same problem...
If the gas valve is opening in a reasonable amount of time then the problem isn't with the igniter and you don't need to bother testing amp draw... Could be a number of things, clogged burner ports near the igniter, incorrect air/ gas ratio, incorrect igniter position (too far away from the burner), incorrect gas pressure. If you can, watch the burner when it lights from a safe distance and see if both sides are igniting at the same time or if it just builds up gas until BOOM! Ha ha, hope you figure it out, be careful.
Oct 04, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven slow at starting, there is smell of gas before oven turns on
If there is a smell of gas PLEASE STOP USING IT you risk fire or explosion or both. Please get a registered Gas-fitter to look at this. If you can Turn OFF the Gas at the Wall/Outlet. Until it can be looked at. If you smell gas it is very dangerous.
Feb 11, 2010 | Ovens
Ignitor problem with gas oven
The spark ignition coil is failing. As this is an oven, it can be dangerous not to have a strong ignition spark. A gas buildup in the oven could cause an explosion.
You should replace the spark generator coil which is located at the back of the oven and is usually orange/black or blue in color. Ariston usually use ITW Ispracontrols ignition coils.
Mar 26, 2009 | Ovens
Explosion potential
Absolutely do not use it until the problem is taken care of. You do indeed have an explosion hazzard.
95% chance all it needs is a thourouch cleaning of the ignition assembly.
When burner orifices and lighting tracks get contaminated and partially clogged with rust, dirt, and other sediment it starts to block the gas flow.
The gas starts to build up unburnt untill it eventually encounters the flame or ignitor, and then all the built up gas ignites at once.
It would eventuallty get worse.
Clean or replace the ignition assembly and burners.
A brass wire brush works wonders.
Jan 11, 2009 | Jenn-Air JGR8775QD Gas Kitchen Range
Oven igniter causes small explosion
Sounds like the ignitor is worn or mispositioned or the gas mix is wrong.  Could also be a worn burner.  Don't do this yourself unless your fire insurance is up to date.
Nov 16, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Explosions
Gas valve needs to be replaced. You may want to pay a pro to handle this one! (gas is nothing to play around with) Goodluck!
Dec 16, 2007 | GE Profile JGS968 Gas Kitchen Range
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
969 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
