Question about Mitsubishi WD-62525 62" Rear Projection HDTV
62" MITSUBISHI DLP SCREEN HAS WAVY LINES
HELLO, I AM NOT SURE HOW TO DIAGNOSE THE ISSUE THAT I AM HAVING WITH MY TV BUT LATELY I HAVE NOTICED BLACK WAVY LINES IN THE SCREEN. I AM NOT SURE WHAT TO CHECK OR WHERE TO START. I LOVE MY TV AND DONT WANT TO SCRAP IT IF I CAN FIX IT, BUT IF THIS IS A TOUGH PROBLEM TO FIX, PLEASE LET ME KNOW SO I CAN START PRICING NEW UNITS.
  • Paul Bade Nov 19, 2017
    Hi hollywuud, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Does the problem appear on all inputs, or just one? Does it affect the menu display? Are the lines only on the edges of the picture, or do they appear all over? Are there color fringes on the edges of the lines? Are the lines horizontal or vertical? How wide are they? Do they move, and if so, in what way/
    This will help us narrow down the problem perhaps to a specific module or part.
SOURCE:
SOURCE: Mitsubishi WD-52825 Black and Purple rolling lines
Sorry, dumb question but what does FMT stand for
Posted on May 13, 2008
SOURCE: mitsubishi tv
ok.
#1. replaced capacitors on power board. DM board FMT board .
# 2 on power board you need to chek caps. 3300mf x 35 v.QTY 2.
# 3 12 capacitor 1000mf x 16 v.
If caps 1000mf x 16 v . looked good. replaced anyway......
Posted on Sep 17, 2008
  • 179 Answers
SOURCE: Mitsubishi DLP WD 52525 has small green lines on the screen
do the lines go from top to bottom, and are they about 1 inch apart? or do they move diagonally across the screen?
Posted on Dec 29, 2008
  • 179 Answers
SOURCE: Vertical lines on Mitsubishi 62" DLP
the DM and/or the FMT board are going bad. the chassis needs to be rebuilt. check out www.tv-techs.com
Posted on Jan 02, 2009
  • 179 Answers
SOURCE: Mitsubishi DLP wd-52725 wavy lines from top left to bottom right
the DM board is going bad and needs to be rebuilt. check out www.tv-techs.com
Posted on Jan 07, 2009
60 inch dlp tv picture is bright mitsubishi
try to restore factory settings so that we can easily diagnose if the problem is on the settings or have a faulty parts inside
Best regards,
Chester
Jan 16, 2012 | Mitsubishi WD-62525 62" Rear Projection...
Screen role red and green wavie lines.
Hello dctc1,
Looks like there is a problem with the convergence IC's. You will have to replace both of them. I would also look for busted capacitors around the IC's.
However, if you are not familiar with TV repairs, I would advise against opening up the set. Best get a service man to come and diagnose/repair the set.
Hope that helps!
Please dont forget to rate or "Accept" the solution if it helped you in any way, or leas you to a fix.
Thank you for using FixYa!
IrishDruid
May 18, 2008 | Mitsubishi VS-60607 TV
Wavy lines all over the screen on a 55 in. Mitsubishi DLP 2005 Tv that has intermitent wavy lines around all the edges of the people and edges of the screen. Jerky picture and almost makes you sic...
You probably have a V26 chassis. The only fix to this problem now that parts are no longer available from MITS is to call their Consumer relations dept. at 800-332-2119. If you have a qualified tech come out and estimate the job, Mits will offer you an attractive discount on a new model. To repair your problem would be around $750
Bill W
integrityhomeworx.com
Mar 22, 2011 | Mitsubishi Televison & Video
The picture on my Mitsubishi WD62725 is starting to show some wavy lines and snow. We had a repairman come and he said that it needs a new chassis which would run around $550 and he said that it was not...
If the set is 6 years old I would not put $550 into it, but a new 60-65 DLP should only run you from 1200-1800. If you check around you will find alot of Mits DLPs on the internet for even less.
Jan 08, 2011 | Mitsubishi WD-62725 62" Rear Projection...
Verticle black lines on mitsubishi dlp tv screen
Press the Menu Key on your remote. If your menu shows clearly on the screen, then there is a problem with your source.
Mar 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Jan 02, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Blue Flickering Screen - Which Repair Kit?
yes they provide a free service manual with their kits. the symptom of the blue screen could either be the signal or the FMT as they can both cause those symptoms, My professional guess would be the signal board as the FMT will cause distortion lines across the screen with no picture.
Sep 25, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
177 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
