Maytag Neptune MAH5500B Front Load Washer Logo
Posted on Dec 04, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have the neptune front loader. The lock light wont come on and the door wont lock. During a wash cycle the water just started comming out of the door. If I hold the stop/start button manually the light still wont come on but the water will drain out properly. Tried to start a new load and the button wont even stay on at all. I let go and the machine stops.
Carmen Mikulic
Level 2:
Sergeant:
  • Expert 415 Answers
  • Posted on Dec 04, 2008
Carmen Mikulic
Expert
Level 2:
Sergeant:
Answers
415
Questions
0
Helped
217633
Points
909
you have a door latch problem. the reason you can still push on the button is because this particular washer has a time delay function. i would recommend taking a look at the latch itself and possibly the wax motor that runs the latch.
Eratic, sometimes door lock doesnt activate, when it does wahser starts but stop mid cycle and wont continue. Replaced door switch and pump
Repair needed on Maytag Neptune washer - Home Improvement ...
www.dslreports.com > ... > Home Improvement
DSLReports
Aug 5, 2007 - 19 posts - ‎8 authors
Forum discussion: We have a Maytag Neptune front-loader washing machine that ...the drain/spin cycle after a wash even though the timer continues to ... related circuit board failure" their Neptune washer will lock the door, turn on the ... then will either not start tumbling or will stop operation mid-spin cycle.
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 13, 2013 - The absolute first thing to do to your washing machine that will notspin or drain (whether it. ... I was so fed up with the machine sometimes refusing to spin or drain the .... I just did a load and it stopped midcycle with e and f error codes.... I tried different cycles but all that happens is the door lock engages ...
Maytag Washer Troubleshooting - YouTube
My kenmore he2 front loader is not going threw the wash cycle, but all the lights come on and the door is locked what could be wrong?
Hum may have a bad water pressure switch? It detirmines when the wash cycle should start according to the water level. if bad it will not signal the appliance to start washing. Also may want to check ur door lock switch if its bad it wont go into wash either.
Samsung wf8750lsw front loader door wont open
Not sure if you mean when it is fully off or operating, but if you mean that once it is operating the door won't open, then the following applies...
Once a front loader wash cycle starts, the door on a front loader is physically (electronically) locked until the full cycle ends after spin dry. This is to prevent anyone opening the door and letting all the water out in the middle of the wash cycle, which a lot of people try to do to put in more clothing etc.
6helpful
2answers
Maytag neptune washer clothes staying wet after cycle
Is your door lock light on when machine is in use? I am having the same issue as you and I believe it is because my door is not locking during use.
Maytag Neptune Front Loader Washer
Sounds like the door lock unit isn't locking and may be bad. It is also a possiblity but not likely that there could be a problem with the computer board but start with the door lock unit first
Maytag Neptune Leaking From the Door
possibly door lock not latching could be a bad wax mtr (within door lock asm) or control board
2answers
Maytag washer/front end loader
HI...mine has just started dong the very same thing. I unplugged it to reset the computer and tried
just the 'spin' setting....still...the water is still in the machine....not sure what to do. I thought a blockage too.
abby
1helpful
Washer door pops open during wash cycle
Start the washer in a cycle. When the door locked light comes on, before unit gets to full of water, see if you can pull door open. If so, you probably have a broken latch. The wax motor is activating the switch, but latch is not actually closing. There was a door latch upgrade for some of these models.
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
