Question about LG Cell Phones
I just got an LG shine TU270 3 days ago and I installed the LG USB modem driver and LG PC Suite but for some reason when I run connection wizard it fails when connecting to USB or Bluetooth and now im noticing a bubble at the bottom toolbar saying that there might be a problem with my LG USB Modem driver. How do I fix this?
  • Anonymous May 19, 2009
    have installed lgpc suite but it wont connect my phonr to the pc
  • 796 Answers
Dont connect the phone until the software is installed...
try to reinstall the phone software on the system again,,,and wait for the phone to install al the interfaces by itself on the system...till be be calm after connecting the phone with the system
thankyou
Posted on Dec 04, 2008
Wher i can download USB driver for LG-E900 FOR FREE?
Sep 17, 2011 | Health & Beauty
I want to access mobile internet to my computer (lg gb210)
If you have internet on your mobile and want to use on your PC first download PC Suite from LG Mobile site and install on your PC. Open Internet Kit from PC Suite and follow the instructions, get all the information from your mobile operator about internet connection and input them upon request trough setup internet connection. In you mobile, setup connection to "USB Modem" and will be possible to use your mobile internet on your PC.
Good Luck.
Apr 13, 2011 | LG Shine KE970 Cellular Phone
I used to connect to the net via PC using my LG ke970 as modem. But, suddenly it stopped working one day. Says error 777 on the PC. Modem is out of order. But,this problem is only with Windows 7. Why? How...
I used to connect to the net via PC using my LG GX 300 as modem.
But, suddenly it stopped working one day. Says error 777 on the PC (windows XP). Modem is out of order. And also LG PC suite cannot run. Why? How can i solve this?
Feb 11, 2011 | LG Shine KE970 Cellular Phone
I am unable find lg kg 195 mobile modem 7332 usb Drivers
Download ind install LG Latest PC suite......after installing connect your phone either usb or Bluetooth ...the suite will automatically install all the drivers...
Oct 17, 2010 | LG Cell Phones
I am unable to connect LG GB 210 to my computer through PC Suite. I changed the USB connectivity to Data services and tried. I have loaded both PC Sync and Modem driver to my computer. After installing...
FRIEND I TOO ENCOUNTERED THE SAME PROBLEM WITH THIS PHONE......DAMN....ITS A WORST PHONE I HAVE EVER PURCHASED...ONE SOLUTION TO THIS PROB IS TO BUY A NEW PHONE......
Sep 14, 2010 | LG Shine KE970 Cellular Phone
LG KP220 PC SUITE?
Finally, after spending 2 days on this issue, I am now able to back up my phone book on LG KP220 to my PC!  Hurray!
I have now used the pc sync software on Windows Vista as well as Windows XP (SP3) without any issues.
For Windows XP (SP3): ----------------------------------
After installing the driver, all you need to do is make sure that USBSER.SYS file has the following specs:
Size: 22,768 bytes     Version: 5.0.2195.4858
The newer one (which has the following specs) does not work and needs to be replaced with the older one with above specs.
Size: 26,221 bytes      Version: 5.1.2600.5512
(yes, for some reason, the older version works and newer does not)
For windows vista: -------------------------- When you first connect the phone in COM mode, let vista download the driver from the internet.  Then run PC Sync and viola it'll work!
For both: ------------ For running as a USB flash drive (data mode), you don't need any driver in either o/s. For running as a COM port (phone mode), you need a driver and a software.  The driver I'm using is USBSER.SYS and the software is called "Phone Suite" by MediaTek.  I've also tried a slightly older version of the same software called "PC Sync Manager" and that also works.  Other software should also work, as long as the driver is working correctly!
If you still need any help, drop me a mail at amoizpatgmaildotcom (you know what to do with "at" and "dot")
Feb 02, 2009 | LG CU500 Cellular Phone
Cant get the LG Viewty to connect to PC Suite
I had a simular prob but worse my laptop wouldnt even reconise it as a mass storage device! then i re installed the software and it worked again!? try that again but make sure u remove the old one first,start with the drivers the pc suite the usb modem.also check u have set the phone to data service :) menu-settings-phone settings-conectivity-usb connection mode.
Jan 17, 2009 | LG KU990 Viewty
No drivers for lg kp220
There is no need for drivers to connect KP220 with ur PC simply connect ur LG KP 220 with PC(WIN XP) via USB cable , While Connecting it needs u to choose any one option "1. Mass Storage" "2.Com Port" Simply choose first option(Mass Storage)
At the momoent ur mobile phone will atomatically get switched off and ur mobile behaves like an Ordinary USB Pen Drive
Simply go to MyComputer and browse ur cell phone like a pen drive...
Drivers of LG KG200/KG300 is also supports LG KP 220
Jul 30, 2008 | LG CU500 Cellular Phone
Connot connect via lg internet cube software!
use lower version of windows eg 2000, got the trouble too tried this sent you this thro such connection. Vista prompts me to restart each time I attempt connection- wont the chaps say a word? DAVID
Jan 08, 2008 | LG Shine KE970 Cellular Phone
Lg ku250 modem driver
Download LG KU250 modem driver herehttp://www.ziddu.com/download.php?uid=ZaqblpymZbOZnJSlsKyZlJyiYq2WlZyt2
Oct 21, 2007 | Microsoft Windows Vista Ultimate Edition
Cell Phones Logo
233 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
