Question about Kitchen Ranges
After a oven self cleaning the range would display and error code of F 1-A and the lower oven will come on then turn off. This is a Maytag range model #MER6550BAW Sn. 14367494CC
    Sergeant:
  • 409 Answers
this error comes up when the latch switch is open or does not close properly. please check that the door is closing correctly.
you may have to replace the door switch.
the oven shuts off because it's a safety precaution.
Posted on Dec 04, 2008
    Sergeant:
    Champion:
  • 251 Answers
F1:-A Latch Switch, Upper Check door latch switches, replace if necessarythis should help u let me know if u need anything else
How to unlock a Maytag double oven
Hi Mary,If the door locked after you started the oven!
Press Cancel/Off key to start a latch reset, wait 20-30 seconds and open door, or turn the power off at the circuit breaker or fuse box for one minute, then turn the power back on.
If the oven has a manual latch handle!
Allow the oven to cool, approximately 30-90 minutes, move the latch arm to the left to unlock the door.
If the latch arm will not move after cooling to room temperature, or is stuck in between full right and full left positions, schedule service.
Is the oven door locked due to power failure during Self-Clean? If the oven door locked due to a power failure during a self cleaning cycle!
Select the "Self Clean" option, then select "Cancel". Wait a couple of minutes then try to start the cycle again.
If you started the oven clean cycle by mistake!
Press Cancel/Off key. The oven will need to cool to approximately 200F(95C) before the oven door will open.
Was there an error message!
Follow directions in the display, and refer to the Error Code Symptom, or:
Reset power to the oven!
  • Power the oven down by turning off the circuit breaker(s) or fuse(s) or if you can, unplug the oven for one (1) minute.
  • Turn the power back on turning on the circuit breaker(s) or fuse(s) or plugging it back in.
  • Monitor the oven for one (1) minute to ensure the error code does not display again.
  • Verify the ovens operation.
Kind regards
David
Dec 04, 2017 | Maytag Kitchen Ranges
How do i start self cleaning oven
To Self-Clean:
1. Press SELF CLEAN to set the clean time to HI (4 hours
30 minutes).
2. Press the TEMP/TIME "+" or "-" keypads to cycle between LO
and HI clean time.
3. Press START.
The oven door will automatically lock. The CLEAN indicator
light will be displayed. The time remaining will also be
displayed.
4. When the self-clean cycle is complete and the oven cools, the
CLEAN indicator light will turn off.
5. When the oven is completely cooled, remove ash with a damp cloth
Remove the broiler pan, grid, cookware and bakeware, all
cooking utensils, oven racks and aluminum foil and, on some
models, the temperature probe from the oven
Dec 07, 2012 | Maytag MGR5751AD Gas Kitchen Range
The oven is giving error code LOC
amana self cleaning convection oven displays an F9 code.
Sep 06, 2011 | Maytag Kitchen Ranges
I was baking at 350degrees. My oven turned itself off and the error code F9-3 is flashing. please assist if abe.
The F9-3 error code means that either of the two oven self clean latches is stuck so ya need to check and see in both ovens if their is something from obstructing the lacth
if you also get a F9-4 that would mean its just the lower oven
a F9-5 would be just the upper oven
but for the F9-3 it could be either oven
Aug 28, 2011 | Maytag MER6772 Gemini Electric Kitchen...
My Maytag Gemini oven is displaying an F9-2 error code...I believe this has to do with the upper oven door lock mechanism...anything I can do, or does this require a service call?
F9-2 error code indicates:
  1. Door latch motor failure/jammed. Latch motor switch failure.
  2. Oven control software failure, or component failure(stuck relay).
  3. Wiring problem.
  • Press the clear key.
  • If the Clear key does not eliminate the problem, turn off the power to the range for 30 seconds, then turn the power back on.
  • It is most likely to have a failed or misaligned door lock switch.
Feb 06, 2011 | Maytag Gemini 30" Self-Cleaning...
. THE MESSAGE APPEARED WHILE I WAS CLEANING THE
F1:-4 Runaway Clean Lower oven Check oven temperature sensor, replace if necessary
Nov 09, 2009 | Maytag Gemini 30" Self-Cleaning...
Does not go into self clean only beeps
here is a link for your owners manual click here
To set Self-Clean:
1. Close the oven door.
2. Press the appropriate Clean pad.
• CLEAN flashes.
• SET and UPPER or LOWER flash in the display.
3. Press the Autoset pad.
• “MEd” (Medium Soil, 3 hours) is displayed.
4. Press the Autoset pad to scroll through the self-cleaning
settings.
“HVy” (Heavy Soil, 4 hours)
“MEd” (Medium soil, 3 hours)
“LITE” ( Light Soil, 2 hours)
Choosing the soil level of the oven automatically programs
the self-cleaning time.
5. After four seconds, the oven will start cleaning.
• If the door is not closed, beeps will sound and ‘door’ will
display. If the door is not closed within 30 seconds, the
self-cleaning operation will be canceled and the display
will return to the time of day.
• CLEAN will appear in the display.
• LOCK will flash in the display. Once the door locks,
LOCK will remain steady.
• The cleaning time will start counting down in the
display.
Please take the time to rate this solution
Jan 30, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Maytag Gemini Electric Oven - Lower is not locked, but will not open.
Usually, starting with a COLD oven, turn the self clean on. Wait 3 minutes, then turn it off [cancel] WAIT 1 minute at least, do not immediately pull on the door. This should reset the lock sync. If you cannot get it open still, you may have a faulty sensor that thinks the oven is overheated, or at this point you could have a bent actuator rod from all the tugging!
May 01, 2017 | Maytag MER6772 Gemini Electric Kitchen...
Maytag top oven lock won't lock
Do you get any error codes? What shows on the display when you try? does it make any noises , like it is trying to lock? Is it a manual lock with a lever?
Jan 19, 2008 | Maytag MER5775Q Electric Kitchen Range
Kitchen Ranges Logo
136 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
