GE JKP28 Electric Double Oven
Problem for GE JKP28 Electric Double Oven
Ge double oven - both ovens stopped heating gradually
By amw59 on Dec 04, 2008
completly stopped heating within 2 or 3 days - power light still comes on - about a year ago both bulbs stopped coming on - any ideas?
Solution #1
posted on Dec 04, 2008
Not Rated)
Bob from LI
Rank: Guru  GE Expert
Rating: 85%, 740 votes
My first thought is the power supply to the unit.  Cut the breakers and inspect all connections from the fuse box to the oven.  You will likely find open connections or corrosion.  One breaker could also be bad.  Check the voltage with appropriate caution and a voltmeter.  Breakers should respond with a snap when turned on.
Note: there are two breakers which control the oven: one with a red wire, the other is black.  Each provides 110 volts to the oven in combination with the white neutral.  Together, the black and red give you 220.  If one of the circuits is out or in poor condition, the bulbs might not work and the oven won't either.
Was this helpful?
Yes
No
Popular Solutions for GE JKP28 Electric Double Oven
Questions and Unsolved Problems for GE JKP28 Electric Double Oven
Do you recommend GE JKP28 Electric Double Oven?
Answer
Answer
I have a model JKP90B0M1BB GE built in combo microwave/oven, built in; it is about 13 years old. ... (More)
Answer
Broil will not work on top oven and only heats eough to char a paper towel on bottom oven. The... (More)
Answer
please advise availability and price for knob for thermador double convection ovens model ct227n
Answer
Model JKP50 double oven... no power whatsoever to anything in oven (panel, oven light, timer,... (More)
Answer
GE double oven,model J KP 38 GOJ6BG, the timer beeps or buzzes continuously unless the power to the... (More)
Describe your Ovens problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Oven Experts
Top Range & Oven Repairmen
in , MD
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
(800) 555-9987
All the services you need in order to get your...
Home Blue
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
