Question about Nikon 3-9x40 Buckmaster Riflescope With Bdc In M
I mounted my scope and when I tried to bore site the rifle I need to adjust the horizontal to the left and I ran out of adjustment. I have tried 2 different scopes with no luck any suggestions?
  • Anonymous Dec 29, 2008
    25 yards is the same as 200 yards on a 22-250 true r not
  • 117 Answers
Sounds as if the rings are slightly misaligned.was it factory drilled and tapped or was it done aftermarket.A competent gunsmith can correct this with an aligning tube'or youcan try shimming the inside of the rings with plastic shims cut from a plastic bottle.I always used plastic because it is impervious to weather.Good Luck
Posted on Mar 25, 2009
How to use redfieeld 3x9x42 scope
Depends on the scope and rifle type to which it is attached.
I invested in an inexpensive laser bore such as this one for an AR: SightMark AccuDot Laser Bore Sight - 223 Model SM39001 (for AR-15)
Once the scope is mounted properly, and assuming you have not made any vertical or horizontal adjustments, set the rifle on a stable platform, insert the bore sight, point it at a target 50 (rimfire) to 100 (AR) yards out (works best in low light situation).
Once you have the laser centered on your target, make elevation and windage adjustments as necessary placing the scope cross hairs over the laser. Remove the bore sight and fire 3 rounds, then fine tune elevation and windage.
Dec 27, 2014 | Optics
How do i use a tasco 28A
1. Insert the Bore Stud into the Stanchion while aligning the arrows as shows. Insert the assembled scope guide into the muzzle of your rifle with the grid pattern upright. 2. Select the Aperture Cap that fits your objective rim. Place it over the objective end of your rifle scope and press until it fits flatly against the rim. 3. Using the Adjustable Scale measure the top of your rifle scope tube to the center of the rifle bore as follows: Open the rifle breach. Rest the upper arm of the scale on the scope tube before or behind the windage and elevation turrets. The scale markings should be facing towards you reading vertically and ascending from bottom to top. Slide the lower end of the scale up or down until it is touching the center point of the bore. On center fire rifles the center point will be the firing pin. On rimfire models the center will be the shell extractor. Read the number that corresponds to the indicator marked "CF". Make a note of the reading. 4. Aim the rifle toward a light, flatly lit area such as a wall or open sky. Caution: Do Not Look At The Sun As Permanent Eye Injury Could Result. 5. While keeping the riflescope at the right distance to see the full field of view, sight through it on the grid pattern. Move the stanchion right or left until the bold centerline is parallel to the vertical reticule wire. Turn the windage dial right or left until the vertical reticule is aligned with the grid centerline. 6. Use the reading from the scale to align the horizontal reticule wire. Find the numbered horizontal grid line that corresponds to the number on the scale. Turn the elevation dial right or left until the horizontal reticule wire aligns with this corresponding grid line. 7. To make your final zeroing adjustments remove the scope guide from the bore of your rifle. WARNING: FIREING YOUR RIFLE WITHOUT REMOVING THE SCOPE GUIDE MAY CAUSE DAMAGE TO YOUR RIFLE AND OR CAUSE YOU INJURY At a range or other safe area test fire a group of three rounds of the same type ammunition at a target at least 50 yards away. Refine your scope alignment by adjusting the windage and elevation dials. Move to your desired distance from the target and test fire another group and make your final windage and elevation adjustments. 8. Restore the stud tension by pressing the end of the spring.
Feb 13, 2011 | Tasco Scope Guide Quickly Zeroing Rifle...
Cannot get to the bull's eye. rifle shoots 2" to right of bull's eye. after two full turns left on windage - nothing happened. I',m ready to return to the store. Any help???
continue to adjust the wind-age. If your problem persists I would suggest turning both to a random point and re-start sighting the gun. If that does not fix the problem return the sight because this most likely means the wind-age is disconnected.
Aug 17, 2010 | Bushnell .22 Rimfire 3-9x32 Rifle Scope...
How to readjust a weaver mount?
Make sure the nuts are on the same side of the rifle (both on the right OR left). The clamping mechanism can vary the centering of the scope if they are on opposite sides of the mount.
The other problem may be poorly drilled mounting holes on the receiver or scope mount, check these for alignment with your bore or barrel.
Mar 15, 2010 | Weaver 1 INCH PICATINNY WEAVER BASE RIFLE...
I just purchased a savage .17 HMR with a cabelas pine ridge 3x9x40 tactical scope and I'm having problems siteing it in. It is shooting aout 4 inches low regadless of adjustments I try and make.
A quick and easy way to bore sight your rifle, if it is bolt action only, or an AR, mount the rifle in a cardboard box with cutouts so it will sit without tipping, remove the bolt and sight down the bore at a target 100 yards away, a mail box, or the corner of a building, make sure the rifle doesn't move, then peek through the scope, it should be seeing the same target your bore is seeing, if not, adjust your scope to it, if it won't travel that far, shim the front with pieces of 35 mm film. then check it again, if you can get it to stay there, it will put your bullet on paper at 100 yards.
Mar 07, 2010 | Cabela's Cabelas Pine Ridge 3 X 9 X 40...
Adjustment Issue
the scope should all ways be fitted with the wind adjustment on the right as you look down the rifle, therefor the top ajuster is for up/down,
right ajuster is wind,,left/right, the easy way to set it up is to aim at some sand with the rifle on a stand or in a jig, shoot one round see were it hits and without moving the rifle, turn the turrets till the cross is over the point were the bullet landed, having a pall to move the turrets for you helps a lot here, the main point is dont move the rifle till the turrets have been moved first,, its that or bore sight it,,, jig the rifle up pointing at a target at say 200yds look down the bore aim the bore at the target lock down the rifle check it by looking down the bore again then set the cross up in the scope on what you see down the bore
you will need to tweek the scope a bit as you havent taken the bullet drop into the ajustment that way,,
Dec 17, 2009 | Zeiss 3-9x40mm Conquest Rifle Scope...
CAN NOT ZERO GUN
You may try to bore sight it first. Pull the bolt and setting the gun on a good rest sight thru the barrel at a dot on the wall within ten feet. Then adjust the scope to that dot. As you adjust the scope tap the bore of the scope with a screw driver handle, tap it after each adjustment not hard, but enough to give it a sharp jolt. Once you are close here, move out to the range and shoot at 15 yards. Using a rest, again tap the scope after each adjustment. Then move out to 50 yards and you will want to be shooting high 1.5 to 2 inches here. Shoot slow keep the barrel cool and try for 2 shot groups till you have got the scope dialed in. Then move out to 100 yards for your preference of zero. Remember use the same ammo you will hunt with or at least the same bullet weight. If you can't get her to get on paper you can try to loosen the scope in the rings, one at the time once the gun is a little warm. Loosen the barrel ring first then snug it back down and then the receiver ring. If your group moved now, she was in a bind due to a cold gun at set up / installation.
Dec 01, 2009 | Optics
I need a scope guide instruction sheet for the Tasco 28a
Dec 14, 2008 | Tasco Scope Guide Quickly Zeroing Rifle...
Rifle scope is hitting 5 feet high but dead center
mounts are probably too high.....had the same prob on a .22 rifle with high mounts for open site shooting also. i bought a lower mount and zeroed it in with no prob
Nov 24, 2008 | Bushnell Sportsman 4x32 Riflescope (4x32...
Bushnell Sportview rifle scope wide angle 4x38 T4389 limited adjustment inconsistant results
I had the same problem but was able to solve it by shimming the scope mounts with a thin piece of plastic. Put it under the rear to raise the sighting and under the front to lower. I still plan to buy my son a better scope.
Mar 02, 2008 | Optics
Nikon 3-9x40 Buckmaster Riflescope With Bdc In M Logo
158 people viewed this question
Top Nikon Optics Experts
George Merkley
George Merkley
Mark Campeau
Level 1 Expert
Are you a Nikon Optic Expert? Answer questions, earn points and help others
