Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Washer stops with an F1 Code during rinse cycles.
My Whirlpool WTW6300 with the agitator shuts down during with rinse cycle with an F1 Code. I have to hit the PAUSE/CANCEL and START button several times before it will continue washing. Sometimes I open the lid during the P/C and add about a gallon of water before closing the lid and restarting - don't know if that helps, but it seems to get rid of the F1 code a little sooner. Help!!!
Well I have the same problem the only way I have found that my washer works is that on the soiler level make sure you put that on the heavy. And that should work I know its a pain but thats what I do and my washer washs with out stopping
Posted on Dec 08, 2008
My Whirlpool GHW9250ML is having problems spinning
My Whirlpool Front Load Wasehr Model# GHW9250ML is having problems spinning on the final rinse cycle. The machine shuts down and the letter F appears on the digital read out.
Mar 06, 2010 | Whirlpool GHW9250M Front Load Washer
Washer agitates off balance and makes a loud banging sound until movement stops at the beginning of rinse cycle, advice?
If it makes this noise in the agitate mode and not during the spin cycle, I would suspect that the transmission is going.
Jan 03, 2010 | Whirlpool Ultimate Care II GSW9650LW Top...
Whirlpool washer stops after agitation cycle
Maybe check the belt is it cracked worn or fibers showing if so replace it
Jul 26, 2009 | Whirlpool Washing Machines
I get error F1 every time I start and before the rinse cycle. I will change cycles, change settings within cycle menus, it tales at least three attempts of shutting it off and restarting it. Now it will...
here's the part # W10189966. I guess whirlpool had a recall on the units and revised the control boards. might want to call whirlpool on that. Good luck :)
Jul 11, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Will not spin on any rinse cycle
Hi, This washer does not have a belt. While the washer is agitating, if you lift the lid will it stop? Some models will agitate but not spin if the lid is up. It sounds to me like the lid switch might be going bad.
If you will get me a model #, I can look this up for you and give you a better idea.
Vic
Jul 05, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine does not drain during rinse cycle?
Turn timer to rinse cycle. let fill up and agitate. when it stops agitating it should pause then start to pump water out. After about 2 minutes it should pause for 3-5 seconds then start again and spin. If it starts the first time and never stops it will just continue to pump but no spin. The 3-5 second pause allows the transmission to shift to spin. If it does not do this the problem is your timer. You may need to do this a few times to verify the problem.
If that is not the problem it is likely that you need a new clutch. You will need a technician to install a new clutch for you
May 17, 2009 | Whirlpool LSQ9600L Top Load Washer
Stops during rinse cycle
Dear customer,
              We recommend the following when a washer's cycles dont advance..
  1. If the washing machine fills with water and begins agitating, but the timer does not advance, the timer probably needs to be replaced
  2. If the timer does not advance while the washer is in a spin cycle, the timer probably needs to be replaced
  3. If the timer does not advance during the rinse cycle, check whether water has filled the tub, if not, it is likely cold water related. Check the cold water supply valve, check the supply hose for kinks, check the filter screen and check the water inlet valve
For details on how to self test these parts plz refer to http://www.acmehowto.com/howto/appliance/washer/washer.php
Plz rate this solution.. thank you..
Apr 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool calypso model GVW9959K-0 leaking during rinse cycle
hi my name is joyce
Sounds like your pump is leaking. if it is leaking when you are on a spin cycle.
now if it is stuck on f1 cycle and wont drain unplug and let stay unpluged for 60 seconds and replug and see if you can restart on drain and spin cycle. let me know if I can help with any other problems.
thanks
joyce
Feb 06, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool top Loading washing machine won't spin on spin cycle
If the washer won't finish a spin cycle, it probably means that your timer went bad or stalled. You can take the control panel off and look at the contacts for scorching or corrosion.
Sep 21, 2008 | Whirlpool LCE4332P 2.1 cu. ft. Top Loading...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
496 people viewed this question
Dan Webster
Dan Webster
Sal De
