Question about Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve....
No hot water
I have a single handle Moen bath faucet that is only about 2 years old and does not get much use. Recently when we turned it one the cold water came out but when I continued to turn it around to the hot it trickled down to a small drip. Some insight to this problem would be greatly appreciated.
  • kmsp Dec 04, 2008
    I found that I have the exact same problem tonight. The shower has a rotating handel and was purchased in February 2005. It is rarely used. Any help is appreciated.
Thank you frcs68. After calling the manufacturer, I found that it is advisable to turn on the water for a minute or two more frequently than I have in the past in order to prevent the cartridge from sticking in the same cold water position. Hopefully that advice will help others.
Posted on Dec 07, 2008
    Genius:
  • 1,605 Answers
Turm off the water at the main first.
take the handle and the plate off the control.
use a plier to take out the cartridge.
replace with a new one or you can repair by change all of the "O" rings and rubber sets.
make sure the postion when you take off the cartridge. there is front and back to the cartridge. if you install it backwards, it will not work.
Posted on Dec 04, 2008
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    Why does moentrol bath valve give hot water pointed to "C" and vice versa?
    Easy one.
    Feel the pipes. The pipe on the right should be cold. If the pipes are correct, turn the cartridge 180 degrees.
    Jan 20, 2013 | Moen & One Handle Tub & Shower Faucet
    I need replacement part for bath sink cartridge 4570
    The Moen 1225 or 1200 cartridges are the same except the 1200 is brass in stead of plastic. They will fit most Moen single handle faucets. If it is a two-handle faucet, the 1224 cartridge will fit most two-handle models unless it is a fancy widespread faucet more than about 15 years old. I don't know the model numbers for those cartridges. All of these cartridges require a removal tool if you can't get them out with a pair of pliers.
    Dec 09, 2011 | Moen Soap & Lotion Dispenser 3910S
    Moen Kingsley Moentrol single handle bath/shower fixture. Had guests use this recently and they only could get hot water. When you turned the handle to cold nothing comes out. Only hot when turned the...
    Sounds like the cause of your problem is the pressure balancing spool. Call Moen at
    1-800-289-6636
    and explain the problem. They will send a repair part to you free of charge. the link below is a "blow up" of your valve.
    http://www.moen.com/shared/pdf/t3113pt.pdf
    Mar 10, 2011 | Moen & One Handle Tub & Shower Faucet
    When i move shower valve to hot, the water pressure drops. There is more cold water than hot. I have changed my moen valve before and this still happens. Good water any where else in the house including...
    probably have a kink on how water line feeding valve..if possible to cut drywall bhind tub valve and inspect pipe at bottom plate...moen faucets are equipped w/ anti scald device, pressure balanced (newer models) and this could cause cold water to overwhelm hot water...
    Nov 20, 2010 | Moen 3175 Legend One Handle Shower Faucet...
    We have a home that is 3 years old. We never used the 3rd bathroom shower until today. We have a Moen single knobe shower/bath valve. To get water from the faucet you pull the knob out. To adjust the...
    Remove handle to gain acess to the temperature limit stop. Remove handle and pull out handle adapter kit and next there is a dail that can be adjusted to control the water to balance the temp. It could have been installed wrong, pay attention to where it is now and pull it back to it disengages out of the stem and move it counter clockwise a little and reinstall. Put handle on and test water for correct movement.
    Go to link below for a part's diagram if needed.
    TO ORDER PARTS CALL: 1-800-465-6130
    www.moen.com
    Aug 15, 2010 | Moen & Posi-Temp Single Handle Shower Or...
    Moen L3175 faucet with low water pressure
    IS THIS A SHOWER ONLY? IF SO ,I WOULD REMOVE THE SHOWER HEAD FIRST THEN TURN YOUR WATER ON.THE HEAD JUST MIGHT NEED TO BE CLEANED AFTER 11 YEARS.
    May 10, 2010 | Moen L3175 Chrome Legend Single Handle...
    Moen Single Handle Shower Faucet-turn on get cold, little hot
    You can try to rotate the first plastic ring to the left of center a few teeth, this will let the handle advance alittle more to the hot side.
    Oct 09, 2009 | Moen 3175 Legend One Handle Shower Faucet...
    Moen - Single lever bath tub faucet - cold water only
    moen does not have a ball and washers....sounds like a Delta maybe. Moen uses cartridges. Either way sounds like a balancing spool problem....but you will need to make sure of the right name for the faucet to get the parts.
    Aug 17, 2009 | Plumbing
    No hot water
    http://www.moen.com/contact.cfm?location=TopNavCustomerSupport
    You will find a quicker answer and free parts for your bath room faucet at link above . I am sure it is the mixer valve assembly. If you are not a plumber I suggest a pro be called.
    John
    Mar 15, 2009 | Moen Plumbing
    Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve.... Logo
    289 people viewed this question
    Top Moen Plumbing Experts
    john h
    Don Numinen
    Don Numinen
    Mike
    Are you a Moen Plumbing Expert? Answer questions, earn points and help others
