Question about NetGear WGT624 Wireless Router
Netgear wgt624 just stopped connecting to internet
All the lights are on just as usual. Yet no network connect. When I bypass the router, I hook right up.(that is how I am typing this message). Worked yesterday but not today. I am a comcast cable customer. Any suggestions?
  • Anonymous Jan 23, 2009
    I have a similar problem.
    The router works fine and I have Internet connection, however because its on an ADSL line it hangs everytime the phone rings.
    When the router gets reset then works fine until the next phone call.
    The modem is DM111P netgear again.
    The router was working fine on a cable Internet connection, now that I shifted to ADSL it drops with each phone call
I encountered the same problem, with the same modem and also Comcast, and here's what wound up working for me, after time spent with a nice guy on the Netgear customer support line:
1. Log into router: http://192.168.0.1 (or 192.168.1.1) - user: admin / password: password
2. Under Maintenance, click Router Status. If IP Address is listed as 0.0.0.0, there's your problem-- router isn't getting address from modem.
3. At bottom of Basic Settings, under Router MAC Address, change selection from Use Default Address to Use Computer MAC Address.
4. Click Apply.
5. Click Router Status again-- non-blank IP address should now be listed.
6. Basic Settings will now show MAC address under Use This MAC Address. See if you can get online now. I could, and I hope you can, too!
Posted on Dec 23, 2008
  • 21 Answers
Comcast uses DHCP and does not supply a router, only a modem. Bridge mode will not help a comcast customer. Before post#1 did you reboot the modem/router 1st?? Post#1 should work, the modem binds to the nic mac of the pc, when u clone that to the router the modem thinks its the pc still. If you had a DSL service like ATT/Verizon then yes you need bridge mode....
Posted on May 14, 2009
  • 174 Answers
The modem must be set first into a bridge mode by Comcast who had provided you the modem before connecting the modem to the netgear router.
you will not have an internet connection if your modem was not set into a bridge mode if you will connect it to your netgear router.
Posted on Dec 04, 2008
How can i connect my iphone to my wireless network when i forgot the password! i have netgear wgt624, i tried "password" no joy
you can access the router's wireless settins so that you can check the wireless password or the network key for you to connect your iphone to the internet
Jul 24, 2010 | NetGear WGT624 Wireless Router
I lost my password and lost the WGT624 installation CD, how can i get the router to work on a new laptop
If you have lost the password to access the router page then you have to reset the router
Ensure that you have all the details regarding your internet connection before resetting the router
If you reset the router you can run the smart setup wizard and get connected by entering correct information in all the pages of the wizard
If you are looking for the wireless password:
Access your router page ( Open Internet Explorer --> Type 192.168.1.1 and enter it--> Login name(default)-admin, Password(default)-password) --> GO to wireless settings,under Wireless settings you will find the wireless password.
Jan 17, 2010 | NetGear WGT624 Wireless Router
Netgear wgt624 with WGt111 usb wireless connection showing red no connection when using netgear wizard programme
Follow the steps to configure wireless connection :
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove.Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
4. Highlight the SSID from the list that you want to connect to.
5. Type the security Key here and click on the 'Connect' button.
6. You should have successfully established a wireless network connect
Jun 08, 2009 | NetGear WGT624 Wireless Router
Netgear WGT624 router won't connect to the internet
I am in the UK and have found through experience the Netgear's seem to work perfect on a BT line (equivalent of AT & T)
but not on the cable.
I would suggest purchasing a Linksys by Cisco WRT54GL Wireless-G Broadband Router as these seem to install in minutes,
saves me hours of wasted time when setting up wireless networks.
Jan 18, 2009 | NetGear WGT624 Wireless Router
No connection when installing WGT624 Netgear router
Plug an ethernet cable into the wan port of the router from your virgin modem... then plug ethernet cable from computer into a port on the router....that should solve your problem.
Jan 09, 2009 | NetGear WGT624 Wireless Router
Wireless connection
Make sure that your computer is getting a valid IP address from the router. If your wireless network is secured, you might as well consider checking the wireless settings.
Oct 06, 2008 | NetGear WGT624 Wireless Router
Netgear Super-G Wireless Router WGT624 v4
This really happen when you run the setup CD of a router sometimes it will tell you that there's no internet connection on your network but the truth there is so if you still need further help for this since the router is new better call Netgear and let them hel you all the way in configuring this router this is the complete list of phone number for Netgear tech support just check the linkfor it
http://kbserver.netgear.com/kb_web_files/N101460.asp
Hope that helps.........
Aug 10, 2008 | NetGear WGT624 Wireless Router
My router is not working
More info please? Which lights are on on the router? What kind of Internet service do you have? Can you connect to Internet when you bypass the router and plug the Ethernet directly into your computer?
Jul 16, 2008 | NetGear WGT624 Wireless Router
Wireless network
Have you looked at these posted solutions? http://www.fixya.com/support/t133938-wireless_connection
Feb 14, 2007 | NetGear WGT624 Wireless Router
Open Questions:
See all NetGear WGT624 Wireless Router Questions
NetGear WGT624 Wireless Router Logo
1,079 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
