Question about Goldstar MA-2117W / B 1150 Watts Microwave Oven
Intermittent display function
I have a 6+ year old 1150 watt goldstar that has been pampered, & has given us flawless service... it's used mostly to heat things up...not to cook for extended periods of time... it has developed an intermittent problem, that i'm guessing may be caused by a loose connection... symptoms: when setting the keypad for a duty cycle, the display will sometimes blank out or show 8's & blank-out for a period time, ranging from seconds, to, up to 2 minutes or so.... tapping on the cabinet or opening & closing the door, or un/re-plugging, the unit seems to restore function quicker... & my wife says sometimes when it blanks-out, she leaves the unit & finds it has returned to normal, when she returns later... it's totally random event happening perhaps 2% of the time... when the glitch is not present, the unit functions perfectly... no weird noises or smells detected... thanks in advance, guru's lee / columbus
  • Goldstar Master
  • 8,803 Answers
Re: intermittent display function
Sometimes this is a problem with a door switch or mount. Other times it's a problem with the control panel assembly, which we regularly repair nationwide for just $32.50. We have *critical* safety and disassembly tips plus info on diagnosing and replacing door switches at our Web site, which is linked at our listing here on FixYa: You can find helpful exploded view diagrams and order parts by entering your base model number (without the suffix) here:
Posted on Feb 06, 2007
0 characters
3 Points
What is watts for goldstar MA 1280M Microwave and if it is over 1100 watts cani i adjust it down
You can set it to different levels. It is doubtfull the magnetron will deliver more than 750 Watts as that is about all they can produce singley. Commercial ovens use at least two magnetrons.
Most specs on microwave ovens quote the power drawn not power produced.
I hope that helps.
Jan 01, 2011 | Goldstar MA-1280M Microwave Oven
Hi im trying to find out how many watts my goldstar MA-681M microwave has
We have the service manual, which says it outputs 600 watts.
Aug 03, 2009 | Goldstar Microwave Ovens
I need the wattage on a GE microwave WES1450DMBB
Product Features
  • Electronic controls are easy to operate and offer one-touch operation
  • 1.4 cu. ft. capacity accommodates everything from small snacks to family size meals
  • 1150 watts of cooking power and 10 cooking power levels allow you to reheat and defrost quickly
  • 5 sensor cooking options automatically monitor cooking progress and adjust time and temperature for delicious results; sensor options include beverage, reheat, popcorn, potatoes and vegetables
  • Auto and time defrost functions make it easy to thaw food quickly
  • Express cook control with 1-6 minute intervals for cooking or reheating leftovers
  • Add 30 seconds option
  • 12-5/8" glass recessed turntable provides ample cooking space for oversized and oblong-shaped dishes
  • Clock and countdown timer allow you to conveniently coordinate meal times; reminder signals let you know when cooking is complete
  • Black finish adds a touch of style to your kitchen
try{ var divArr = document.getElementsByTagName('div'); var rpDiv = document.getElementById('tabbed-overview'); var spDiv = document.getElementById('saleprice'); var rp = getRegPrice(rpDiv); var cp = getCurrPrice(spDiv); if(rp!='none'&&cp!='sale'){ spDiv.parentNode.insertBefore(ocRegPrice(rp,cp,'pdp'),spDiv); } }catch(e){}1150 WATTS
May 10, 2009 | General Electric Microwave Oven
No instruction manual
If that's MA-1417W, you can download the owner's manual here.
You will need the free Acrobat Reader to view or print it in case you don't have it.
Jan 02, 2009 | Goldstar MA-1417W 1150 Watts Microwave...
Ringing noise from refrigerator
It's probably a dry bearing on either the compressor or the fan in the freezer. The evaporator, I believe it's called.
For more Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit here.
If it's under a year old, it's probably in warranty. You can get warranty info & find a local authorized servicer from there, too.
To order Goldstar / L.G. parts for a do it yourself repair, visit Vance Baldwin Electronics. You'll probably have to call them.
Dec 06, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Goldstar MV 1501BQ microwave
It's probably a bad door switch or door switch mount.
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa:
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 22, 2008 | Goldstar MV-1501 Microwave Oven
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Otherwise, you may have a failing keypad. It can fail due to age, moisture, etc.
PLEASE Let us know if the hard reset doesn't fix it.
We have the service manual available to us.
Apr 02, 2008 | Goldstar MA-2117W / B 1150 Watts Microwave...
Sharp model number: R-320HQ (1200 watts)
the electronic circuit are corroded timer does not function / the IC program was lost of memory such as function / if you have some old look a like Sharp Model you may transfer control panel.
Jan 05, 2008 | Sharp R-510HW Microwave Oven
Power is on, but won't cook
First, be sure the child lock is off. It may have an "L" or the word "LOCKED" showing in the display. You can unlock it by pressing and holding the CLEAR pad for 5 seconds or so. Your model may use a different key, maybe the "0" (zero) key. If that doesn't fix it, since it's still under warranty you should grab your sales receipt and your owner's manual and call LG / Goldstar customer service at 1-800-243-0000 to find the nearest authorized servicer. There may be some foreign substance on the circuit board or inside the layers of the keypad. Most commonly this is due to spray cleaner being sprayed directly onto the keypad. Cleaner should be always sprayed on a soft cloth first, then use the cloth to wipe the keypad clean. Always use alcohol-based cleaner on microwaves, never ammonia-based cleaner, which can crack and/or warp the plastic. If this is what has happened, it would not be covered under warranty, and it may or may not be repairable. A handy person can remove the control panel frame and see if there's any liquid inside on or behind the panel. If so, it is possible to dry it out with an air compressor or heat, but often that does not work.
Nov 10, 2006 | Goldstar MV-1615 Microwave Oven
Goldstar MA-2117W / B 1150 Watts Microwave Oven Logo
43 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
