Question about Toshiba Satellite A135 Notebook
Memory upgrade problem
I put in two 2GB ram modules equaling 4GB, but it only registers as 2GB. Why is this and what can I do to get the whole 4GB?
  • spc_young08 Dec 04, 2008
    if you could, will you run this system unit to see if possible because a friend of mine did it and it worked on the same computer? A135-S2266
    Novelist:
    Scholar:
  • 85 Answers
I did some checking on your model laptop and it says that the maximum supported amount of ram is 2gb (2 x 1gb) and so since the slots are made for 1gb max each then thats all they will see even with bigger 2gb chips installed
Posted on Dec 04, 2008
  • Darren Kessinger
    Darren Kessinger Dec 04, 2008
    ok i did some checking on your model and it says that the maximum ram you can install is 2gb (2 1gb chips) and so since the slot is only made for 1gb each then thats all it will see.
I upgraded Memory to 4GB with Two 2GB SD Ram Modules but System shows Only One 2GB module and does not show/recognize second module. BIOS Setting Shows Second Slot/RAM Module Not Activated.
is the module in properly?,is anything broken?? switch them around and see if the module is good or not,also,just because the motherboard supports 2 modules,if intel only recognizes 2gb then that is all,whether you have 2 1gb modules or 2 2gb modules,upgrade your intel chip and upgrade your bios
May 21, 2015 | Computers & Internet
What is the maximum memory on a Gateway MX8734 laptop?
Hi Anon
the Gateway MX8734 motherboard has two memory slots each capable of handling a maximum of 2gb of ram.
So, 2gb is the largest single ram module, and 4gb is the largest total amount of ram.
If you are uncertain if your motherboard is capable of handling a 4gb ram upgrade then check with the memory suppliers first.
In practice I have always found that the performance difference between 2gb and 4gb of ram is slight.
Aug 14, 2014 | Gateway Computers & Internet
Can an old HP Workstation xw8000 Computer that is currently using 512 RAM (PC2100 registered 184 PIN ECC DDR SDRAM DIMMs) be upgrade using 4GB Kit (2 X 2GB) PC2100 Registered 266MHz 184 pin DDR SDRA
According to a couple of people I have conferred with, that RAM should work.
Take a stick of the old ram out and make sure the the cut out, in the new RAM, is in the exact place as the old sticks. It cannot be off by a micron, or it will not fit.
Understanding Identifying and Upgrading the RAM in your PC
Dont click on any of the ads in that article, just read it and you will be able to judge for yourself.
Mar 11, 2014 | Dell W4201C 42 in. Plasma HDTV
AOD270-1824 can i put a 4gb ram in it
You can add 1GB of ram but that's it. Definately not a 2GB Stick or 4GB stick.
Sep 01, 2012 | Acer Espresso Black 10.1" AOD270-1824...
I m trying to upgrade my HP compaq nc6320 RAM MEMORY from 1GB to 4GB, Do i need BIOS upgrade if yes from were i can find the drivers and how can i do it? thanx i am gone wait for respond......
As far as I know, the machine supports 4GB of ram, so you purchase the ram modules from a pc parts dealer and install them inside the machine, removing the existing ram, there are 2 slots, so you need 2, 2GB cards.
You do not require any drivers or bios update.
Windows will need to be upgraded to 64Bit version if you wish to use the full capacity. as normal windows is limited to 3-3.75GB
Further questions? let me know.
Sep 01, 2011 | HP Compaq nc6320 Notebook
I have a compaq presario cq60-215dx notebook pc, was wondering how do i go about upgrading the RAM?
I have checked the Compaq Presario CQ60-215DX Specification It Originally has 2GB Memory and supports upto 4GB RAM max. If you intend to upgrade the RAM, you can buy additional RAM and put them in you system. Here is the HP Guide to Replace RAM and How to Upgrade RAM Guide
Compaq Presario CQ60-215DX has two RAM slots for DDR-2 (533 or 667) Memory Modules. First you have to check that the RAM slot is available for additional RAM. I believe that it has two modules of 1GB each in both slots. So, you have to get two modules of RAM 2GB each to upgrade to 4GB (or one 2GB RAM module to upgrade to 3GB). Hence, it is recommended that you get 2GB replacement module for each 1GB module you have on you system from local laptop repair/ service center, which would be cost effective as existing 1GB RAM Modules would be useless for you upon upgrade.
Let me know if any further clarification/ assistance is required.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
Dec 31, 2010 | Compaq Presario Notebook
I have hp dv-1000 laptop with 256 ram, which i wud like to upgrade to maximum.so how many GB ram i can go for and what wud be the price.?Can i go for 4GB ram?
You can upgrade to 2Gb ram. I dont think your notebook will support 4Gb ram. A 2Gb Transcend ram will cost you around 1500 bucks INR
Sep 01, 2009 | HP Pavilion dv1000 Notebook
Acer Aspire 5601 4GB memory upgrade problem
Acer systems are picky about the type of memory you use.
What is your RAM Speed on the old chips compaired to the new chip
You may have to reorder the same type of speed memory
Try this website it will tell you what will work with your system
http://www.ec.kingston.com/ecom/configurator_new/mfrmod.asp?root=us&LinkBack=http://www.kingston.com
Aug 22, 2009 | Acer Computers & Internet
Problem with upgrading my acer extensa 5620z memory to 4GB
Hi there.
I recommend you get another stick of SODIMM to replace what seems to be the faulty stick.
If you are using XP or Vista X86 (32bit) then the system will only recognize 2.8 - 3GB of memory, only 64bit operating systems recognize the full 4GB.
Good luck ad thanks for using FixYa!!
May 24, 2009 | Acer Extensa 5620 Notebook PC
Can i upgrade my MT3705 to 4GB RAM?
If you get rid of Vista and put in 2gb of Ram your Laptop will not need 4 gb of ram.  You need to get it will not support double sided or ECC this is why you can not have 4gb you need 2GB kit (1GBx2), 200-pin SODIMM, DDR2 PC2-5300 memory module
Jun 12, 2008 | Gateway MT3705 Notebook
Toshiba Satellite A135 Notebook Logo
175 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
