Question about Cooktops
Turn front element on and back element comes on also
When the front element turned on the back element comes on and stays on high.Red Hot.
  • Robert Artiaco May 11, 2010
    Do you have a glass panel or push button to turn your elements on or do you have knobs?
I ordered a new Cartridge, cause the back element burned out. Maybe it will fix the problem.
Posted on Dec 04, 2008
Large element stopped working/that hot surface light stays on
I have the same problem with mine. Do you have any answer yet?
Jul 20, 2010 | GE 30 in. Profile JP938SCSS Electric...
The elements in my ranges is not working
the 8" run on 240volts,the 6" only on 120 volts,check the input volts on high at this element connection for 240v.a.c. on high,otherwise the supply line is missing one leg of power or theres a burned wire or component
Mar 19, 2010 | Cooktops
Right front (large) burner indicates hot, won't work, flashes F153
I hade a code 153 also. Changed the element(costly-$200) and had to recalibrate the pan sensors(in the manual). All works fine now.
May 21, 2009 | GE Cooktops
Stove top will not heat oil hot enough to fry foods. Burner continues to re-cycle on and off while switch is on high. Burner gets red hot for a few seconds then turns off for a few seconds, then back on.
You may have a cracked element, they expand when heated and cause a separation in the element. You really have to put a voltmeter on it to test it under load. If the voltage remains constant while the element is heating and cooling, then indeed you have a bad element.
If you don't have a voltmeter, or don't want to perform this test, buy a heating element and replace it, if you have the same problem, you'll have a spare element
May 14, 2009 | Jenn-Air JED8430 Electric Cooktop
GE Profile cook top - four years old
unplug unit allow to dry ..12 to 24 hours,,or cut breaker to stove,,,try again..if still lite..you ground out,,you have to take a look at light circuit for ground short
Dec 24, 2008 | GE 30 in. JP340 Electric Cooktop
Whirlpool ceramic cooktop
Scott,
On each of the heating elements there is a thermostat that does two things. It is a high limit safety thermostat and then a different set of contacts turn on the hot surface light. Unfortunately, you can't just replace that part. You will need to isolate which element it is with a mutimeter and replace the entire element.When you turn one of the units on high you will see a dark line under the glass running 1/2 way across the elements. Those are the thermostats... Find the defective one and the rest is pretty simple to replace
Dec 18, 2008 | Whirlpool 30 in. RC8700 Electric Cooktop
Dual Element
check underneath the element, you may have something preventing the element from gihting up. if you didn't find anything, then it is time to get a new element.
Oct 08, 2008 | Jenn-Air JED8430 Electric Cooktop
Burner gets hot even when not turned on
sound like you have a shorted element, it will stay hot but not high heat hot (glowing) red, other posibility is bad infinate control switch that switch could be bad
Apr 13, 2008 | Cooktops
Electric Cooktop Heating Elements Get Hot, Turn Off, Get Hot, Turn Off
no they are made to cycle that way they are halagen and cycle with a sensor dont work like the old coil ones do enegey efficent and hotter than old coils dont use them without a pan on them to reflect heat back to the sensor to prolong their life
Dec 29, 2007 | Viking 31 in. VGSU101 Gas Cooktop
Cooktops Logo
106 people viewed this question
Top Cooktops Experts
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
