Question about Philips 50P8341 50" Rear Projection Television
Blue convergence problem with Philips model 46PP930217
After reading numerous posts I have concluded that the convergence chips need to be replaced. I have the required part number STK 392-120. The problem is I can't find the chips inside the TV. I need a schematic or some one with with some knowledge to tell me where the chips are located.
  • Anonymous Jan 31, 2009
    same issue
    Problem Solver:
  • 31 Answers
Look for the big heat sink.
Posted on Dec 04, 2008
Red will not line up on a philips mod 46pp930217 and i can't get the color to ajust
Your convergence chips have failed and need to be replaced. You can get the parts and instructions from www.TvRepairKits.com
Apr 30, 2009 | Philips 46PP9302 46" Rear Projection...
Philips Magnavox 55P8288 Entire picture has green
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Apr 09, 2009 | Philips Magnavox 51MP392H Rear Projection...
Blurry edges, white objects too bright, glowing
  • Screen looks 3D
Mar 16, 2009 | Philips 51PW9363 51" Rear Projection...
Philips rear projection t.v
the convergence ICs and resistors need replacemnet. You can get the DOTV305-DPTV345 convergence repair kit at the following link which includes both ICs and all the feed resistors plus step by step instructions with pictures so you can do the repair yourself. Heres the link.
http://servicemanuals.vstore.ca/
Feb 06, 2009 | Philips Televison & Video
Where to buy the convergence board of a 55PP9502
You can find a replacement auto convergence board for a model # 55PP9502 from this major Philips part distributor at the following link:
Philips 55PP9502 Replacement Part Auto Convergence Board
Feb 02, 2009 | Philips 55PP9502 55" Rear Projection...
No picture, no sound, error code 7
Sounds like one of two problems
1) Convergence chips are shorted....One quick test is to desolder and remove both STK392 chips....then power the set on. If the tubes light up the chips were shorted. You can get new ones from www.TvRepairKits.com
2) Another possible problem is a bad HVG - AKA the flyback.
Try the convergence chip test first. Note: On some Philips sets you can just unplug cable "1516" instead of removing the chips.
For instructions on how to find/remove cable 1516 visit the website listed above and click on their tips page. On that page click on the "Magnavox DPTV3xxx Checks" link.
Jan 31, 2009 | Philips 46PP9302 46" Rear Projection...
43 philips problem with green
  • Screen looks 3D
Jan 24, 2009 | Philips 43PP9202 43" Rear Projection...
Converge colors?
If the colors look 3D or if you can't adjust the blue or red convergence the convergence chips and resistors should be replaced. You can get a repair kit and photo instuction guide for this exact model from www.TvRepairKits.com. Hope this helps
Nov 15, 2008 | Philips 9P5034C 50" Rear Projection...
Picture is warping and colors are seperating giving a picture that looks like a 3D picture without the glasses
you need to replace both convergence Ics. Post the model number of your set and I will post the correct IC numbers as well as alink where you can get replacements with free instalation instructions. Respond to this same post so I will have access to your symptoms when you post the nodel number.
Jun 30, 2008 | Philips 46PP9302 46" Rear Projection...
Philips 50P8341 50" Rear Projection Television Logo
140 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
