Question about Toshiba Satellite A100-S8111TD Notebook
I put two 2GB RAM in my memory slot and only one is registering, so instead of 4GB RAM, I have 2GB. Why is this and what can I do to get the full 4GB?
  • spc_young08 Dec 04, 2008
    I appreciate all of your help
    Novelist:
    Scholar:
  • 85 Answers
Ok i checked on your model and it says 2gb RAM max and so it is probably seeing both chips but only seeing 1gb each since that is what the slot is made for..
But to be totally sure you might wqant to check the bios and see what it says since some bios will sometimes give more details as to how many chips are installed.
or take out one chip and turn the computer back on and see if it shows 1gb or 2gb if it shows 1gb with one 2gb chip then you will know that the slot wont read more than 1gb.
Posted on Dec 04, 2008
What is the maximum memory on a Gateway MX8734 laptop?
Hi Anon
the Gateway MX8734 motherboard has two memory slots each capable of handling a maximum of 2gb of ram.
So, 2gb is the largest single ram module, and 4gb is the largest total amount of ram.
If you are uncertain if your motherboard is capable of handling a 4gb ram upgrade then check with the memory suppliers first.
In practice I have always found that the performance difference between 2gb and 4gb of ram is slight.
Aug 14, 2014 | Gateway Computers & Internet
AOD270-1824 can i put a 4gb ram in it
You can add 1GB of ram but that's it. Definately not a 2GB Stick or 4GB stick.
Sep 01, 2012 | Acer Espresso Black 10.1" AOD270-1824...
I m trying to upgrade my HP compaq nc6320 RAM MEMORY from 1GB to 4GB, Do i need BIOS upgrade if yes from were i can find the drivers and how can i do it? thanx i am gone wait for respond......
As far as I know, the machine supports 4GB of ram, so you purchase the ram modules from a pc parts dealer and install them inside the machine, removing the existing ram, there are 2 slots, so you need 2, 2GB cards.
You do not require any drivers or bios update.
Windows will need to be upgraded to 64Bit version if you wish to use the full capacity. as normal windows is limited to 3-3.75GB
Further questions? let me know.
Sep 01, 2011 | HP Compaq nc6320 Notebook
I have a p4m900mother board. i had 1gb ram in each slot. running 2gb ram. i replaced the one with a 2gb hoping to run 3gb ram but my pc will not boot. i have switched slots and still nothing. i can run up...
Make sure you have installed the correct type of ram into the board. Here are the ram specs for that board
• Memory:
Support DDR2 533/667 MHz
2 x DDR2 DIMM Memory Slot
Max. Supports up to 4GB Memory
Hope this helps
Positive Feedback ALWAYS Appreciated :)
Mar 06, 2011 | Biostar P4M900-M4 Motherboard
The Specs say that Ram is expandable to 2GB but can it go higher? to 4GB?
As it hasn't got dual core to utilise the full 4Gb or a bios to accept it, there is not a lot of point in going further than 2Gb.
Hope that answers your question.
Jan 23, 2011 | Gateway 8510GZ Notebook
I have a compaq presario cq60-215dx notebook pc, was wondering how do i go about upgrading the RAM?
I have checked the Compaq Presario CQ60-215DX Specification It Originally has 2GB Memory and supports upto 4GB RAM max. If you intend to upgrade the RAM, you can buy additional RAM and put them in you system. Here is the HP Guide to Replace RAM and How to Upgrade RAM Guide
Compaq Presario CQ60-215DX has two RAM slots for DDR-2 (533 or 667) Memory Modules. First you have to check that the RAM slot is available for additional RAM. I believe that it has two modules of 1GB each in both slots. So, you have to get two modules of RAM 2GB each to upgrade to 4GB (or one 2GB RAM module to upgrade to 3GB). Hence, it is recommended that you get 2GB replacement module for each 1GB module you have on you system from local laptop repair/ service center, which would be cost effective as existing 1GB RAM Modules would be useless for you upon upgrade.
Let me know if any further clarification/ assistance is required.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
Dec 31, 2010 | Compaq Presario Notebook
Can we ad a ram of 2gb
Yes you can. But you will have to leave the other ram slot open.
your total ram has to add up to 2gb.
so if you put 3gb of ram your computer will not start.
I recommend selling that 2gb and get two 1gb instead or buying a motherboard that supports 4gb max.
Aug 31, 2010 | Intel D101GGC Motherboard
Memory upgrade problem
I did some checking on your model laptop and it says that the maximum supported amount of ram is 2gb (2 x 1gb) and so since the slots are made for 1gb max each then thats all they will see even with bigger 2gb chips installed
Dec 04, 2008 | Toshiba Satellite A135 Notebook
ACER 9410-4933 LAPTOP ? Won?t boot with 4Gb CRUCIAL RAM
YES THE FREQUENCY OF BOTH RAMS DO NOT MATCH ... THATS BOOTING WITH EACH BUT ONLY ONE BY ONE ... YOU NEED RAMS OF SAME FREQUENCY AND SYSTEM WILL SUPPORT BOTH OF THEM TOGETHER ...
Sep 16, 2008 | Computers & Internet
Can i upgrade my MT3705 to 4GB RAM?
If you get rid of Vista and put in 2gb of Ram your Laptop will not need 4 gb of ram.  You need to get it will not support double sided or ECC this is why you can not have 4gb you need 2GB kit (1GBx2), 200-pin SODIMM, DDR2 PC2-5300 memory module
Jun 12, 2008 | Gateway MT3705 Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
139 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
