Question about Radio Shack Accurian ADR-0106
Will not record or play back VHS for more than 30 seconds
My recorder begins to record on vhs and automatically shuts off in 30 seconds. Will not play back VHS movies or my recorded tapes for more than 30 seconds and shuts off automatically, ejects tape and gives eject symbol with "R" above it.
What do I need to do?
  • dom1926ad Jan 03, 2009
    accurian adr-0106I have the same problem with mine it used to play both but not record now does not do either what did you do?
  • jonandkrista May 13, 2009
    I am having the same problem. Will not play vhs tapes more than 2 or 3 seconds then spits out the tape and shuts the power off. It will not rewind for more than 2 or 3 seconds then the power shuts off also.
    Is this something we can fix ourselfs.
    The dvd recorder does fine.
    Genius:
  • Radio Shack Master
  • 1,689 Answers
I can tell you some ideas genericaly for VCR's.
This could be an idler wheel assembly problem, or a tape tension, or a reel torque problem.
It can also be a power supply problem where the supply is working just on the edge. Due to some worn components in the supply it can be partialy shutting down.
Your machine will have to be checked out by an experienced VCR tech.
Jerry G.
Posted on Dec 04, 2008
VHS plays for 5 to 10 seconds then power switches off
I think you might have a problem with the VHS mechanism. Perhaps damage to the mechanical parts. If the mechanism can't perform the task it has been set after a very short period it will send a message to the electronics to shut down. This prevents further damage to the tape or system.
Jun 12, 2016 | Toshiba RDXV60KB DVD HDD VHS Recorder
VHS tape will not eject and unit shuts down
It's not loading correctly. You need to open the cover (unplug first) and get familiar with the loading mechanism. You can get the tape out by rotating the loading motor wheel.
Mar 22, 2015 | Magnavox ZV427MG9 DVD Recorder/ VCR
Dubbing VHS to DVD With Magnavox
If you are trying to dub a commercial (pre-recorded) tape it will not work. If this is not what you are trying to do, get back to us.
Jun 07, 2013 | Magnavox ZV427MG9 DVD Recorder/ VCR
Toshiba dvr670ku - vhs tape won't play, shuts recorder off
look to see if tape will fully load and if FF or REWIND work, if not a transport problem, drive mechanism not moving the tape, unit will sense this and shut unit off----even a problem in the loading mechanism for the VHS tape not loading the tape all the way will do the same thing.
Oct 14, 2012 | Toshiba M754 VCR
I have a Magnavox ZV427MG9. I follow all directions in manual for dubbing VHS home movies to DVD but when I try to play the DVD back there's nothing on them.What am I doing wrong?
Depending on the procedure you may be pressing the record button instead of the D.Dubbing or Dubbing button. When recording from VHS to DVD you must first, load the blank DVD and VHS home movies, then play the VHS movies, then PAUSE the VHS movie when you want to START recording... then the only the you have to do is pressing the D.Dubbing button or the Dubbing button. If your VHS tapes starts to play after the Dubbing button is pressed you have been successful in Dubbing.
Aug 13, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Sony SLV-D100 DVD/VCR unit won't record on a VHS tape.
Check the tab on the VHS tape be sure it is there. If not place a [piece of transparent tape on it to simulate the tab and try again.
Oct 02, 2017 | Sony SLV-D100 DVD Player/VCR
Dubbing from vcr to vcr
Connect with RCA cable to RCA jacks\plugs::
output [player] audio to INPUT [recorder]
OUTPUT [player] Video to INPUT [recorder]
Place blank tape in RECORDER, Tape that you want to record from into PLAYER.Press Record [recorder machine], wait one second, press PAUSE.( thats to give record tape "breathing" space.) Set up your player tape to start playing. When you know what you want to record, press PAUSE again to begining recording. Press PAUSE after the recorded section to install 2nd tape, etc. etc.
NOTE:: some VCRs use PAUSE 2nd time to release and continue recording, while some machines you must press RECORD button again to release PAUSE. you must expirement before begining your project.
May 24, 2008 | Zenith VCS442 VHS VCR
VHS record to DVD
Insert the VHS and rewind or fast forward to the point you want to begin copying from.
Insert the disc you plan to use and format it if necessary. It will usually prompt you if it is necessary to do so.
Put the television on the channel or input needed to view the recorder on-screen.
Select the DVD drive and set the record mode you prefer - XP, SP, LP or EP.
There are two things you can do:
1. Press and hold the dubbing/copying button on the recorder itself in the direction of the DVD for 3 seconds. If you are using a DVD-R/RW or +R you will receive a message stating to press Play to record without finalizing or press Record to record and finalize. If you are using +RW or -RAM, these cannot be finalized - therefore this message will not display.
2. You can access the Functions menu and go to Copy, then select the copy direction VHS to DCD and select Start Copying.
Apr 01, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Transfering vhs to dvd
Is the vhs tape copy protected? I think you can only copy your own vhs tapes or what you record on tv. I could be wrong though.
Dec 03, 2007 | Sansui VRDVD4005 DVD Player/VCR
Adapter question
There are no such adapters that would allow 8mm, Hi8 and Mini DV tapes to be played in a VHS VCR. Only the old VHS-C tapes can fit and play in an adapter. There are several reasons why 8mm (or Hi8 and miniDV tapes) cannot be physically played in a VHS VCR: 1. 8mm (Hi8, miniDV) is a different format with different technical characteristics than VHS. These formats were never developed with the intention to be mechanically compatible with current VHS technology. 2. 8mm/Hi8 tapes are 8mm wide (miniDV is 6mm wide), while VHS tape is 1/2" wide, making it impossible for a VHS video head to read the taped information correctly. 3. 8mm/Hi8/miniDV tapes are recorded and played at different speeds than VHS, so even if the tapes could physically fit into a standard VHS VCR, the VCR still couldn't play back the tapes at their correct speeds. 4. 8mm/Hi8/minDV audio is recorded differently than VHS. 8mm/Hi8 audio is recorded in AFM HiFi mode, while miniDV audio is recording in 12-Bit or 16-Bit PCM digital audio format. So, even if the video could be played back in a VHS VCR, the audio could not be read properly. 5. 8mm/Hi8 video is of higher resolution than VHS and is recorded in a different bandwidth length (miniDV video is recorded digitally), so once again, a standard VCR still could not read the information correctly, even if the tape could fit into a VCR.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Radio Shack Accurian ADR-0106 Logo
243 people viewed this question
Top Radio Shack Televison & Video Experts
Computer Repairing
Computer Repairing
xxxxxx xxx
Are you a Radio Shack Televison and Video Expert? Answer questions, earn points and help others
