Have had the camera about 6 months and it started to have wide horizontal bands during playback. I bought and TDK head cleaner and that seems to have worked for a while. Now the problem is getting worse. Sony wants it sent back for $139 service charge. I also tried to reset the camera. Thanks
Someone here recommended on another post to put the lense cap on & videotape the blackness in a quiet room for 5-10 mins. I tried this as a last resort & it worked. When I played back the tape, no more skipping or gray lines. I had 4-5 SOLID gray lines with skipping video & audio in between on every tape I put in. I think the person who helped me solve this said that it was a result of the tape alignment going off. My camera is a Canon zr80 digital camcorder. (Called Canon, they had me reset it & then recommended sending it in).
Wide bands in the playback video indicate a clogged or defective video head assembly. If your cleaning tape appears to resolve the problem, the heads are getting contaminated. I would not use the same tape in this unit. Try cleaning the heads and then use a brand new tape to avoid clogging the drum assy again. If this does not resolve the problem, the drum assembly will have to be replaced. Hope this helps. Joe Weibel customelectronics.org
