Question about Philips Audio Players & Recorders
Cd cartage will not work
I have a Magnavox stereo aprox 12 yrs old. CD cartiage seems to move freely but when inserted it will change but no sound. It keeps saying error.
Model # CDB583BK01
Serial # 65067143
I did not fix the problem!
Your add says "FIX A PROBLEM FOR FREE" Then I get a E.MAIL saying we can fix this for you for $9.99 or $15.00
WHERE IS THE FREE???????
Judy
Posted on Dec 05, 2008
I have a wave machine aprox 15 yrs old.If I manually spin the cd once or twice it will read and play but begins skipping on later tracks.Also volume control is sometimes problematic.Seems like it needs an...
Clean lense on cd pickup. Remove spin motor. Spray some WD40 in the bottom of the motor and connect 5 volts dc to motor and spin for a few seconds in both directions. The motor brushes need cleaned off. This works on most all cd players. Reinstall the motor.If this does not fix replace cd assy. Check solder connections on volume control. If ok replace control.I had one of these that i sold for $500.00 on Ebay. Even used there is a demand for this item.
Nov 20, 2009 | Bose Acoustic Wave (32022) 5-Disc CD...
I have a memorex stereo, turntable, 3 cd changer etc. The standby light comes on but no sound, it is only 2 yrs old..
Sometimes you have to unplug it for about 30 seconds, then when you plug it in press the power on button. If there is still no sound, check the speaker connections on the back they sometimes come loose.
Oct 17, 2009 | Electro Brand Nostalgic Stereo CD Music...
CD Player won't read disc
sounds like the cd mechanism is not completly loading, or chucking..when you tip it back the cd can move freely, need to check belts, possibly slipping
Jul 05, 2009 | Sony CD Radio Cassette Boombox, CFD-E90...
Refill cartridge
i think it is very easy to riffal than other printer cartage.. take out cartage from printer. side of th printer we can get one onepice of plastic as apush butten . when we push this button . we can get two part of cartiage. then we can easly see white cap of cartage.. first openinig cap we throuww old dust .then clean cartage by bloing air by air blower. thanks
Jun 26, 2009 | Brother MFC 240C All-In-One InkJet Printer
Left front and rear speakers sound muffled when playing cd's
after you play a cd while the cd is playing go into your audio settings and adjust theres settings foe each part on a stereo if u set the audio for AM//FM then play a cd the stereo changes to the cd settings
Jun 01, 2009 | Jensen Car Audio & Video
Kenwood KDC-X589 seems like the CD player doesn't put out sound
you have to change the cd read setting it might got set to cd read 2 it needs to be cd read 1 in standby mode press menu button scroll through with track button till you see cd read and set it to cd read 1 if not in standby mode try in cd mode same steps
Jul 03, 2008 | Kenwood KDC-X589 CD Player
Magnavox DVD Video Player DVD609AT
DVD609AT:
The manual is available at Philips website, the number for more info in manual is out-of-date; the new number is 1-800-605-8610
This unit has a problem when playing dual-layer discs of some kinds - read the warnings on the Magnavox website - playing the wrong kind of disc will cause an error that will require svc/repalcement to fix
Playable Discs
This DVD Player will play Digital Video Discs (DVDs) and Audio CDs. In order to play a
DVD or Audio CD on this DVD Player, make sure the Disc meets the requirements for
Region Codes and Color Systems as described on this page. Also, the Discs should have
the following logos and should meet these standards.
• CD-ROM
• Compact Disc-Interactive
(CD-I)
• Compact Disc-Recordable
(CD-R)
• Digital Video Disc-Video
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Super Audio CD (SACD)
• Photo CD
• Video CD
• Video Single Disc (VSD)
Digital
Video
Disc
12 cm
12 cm
Approx. 4 hours
(single-sided)
Approx. 8 hours
(double-sided)
Approx. 80 minutes
(single-sided)
Approx. 160 minutes
(double-sided)
20 minutes
8 cm
8 cm
(singles)
Logo
Maximum
Disc Type Contents Playback Time
Sound
and
Pictures
Audio
CD
Disc Size
Sound
74 minutes
Disc
Segments
DVDs are
divided into Titles,
which are divided
into Chapters.
Titles and Chapters
are numbered.
Audio CDs are divided
into numbered Tracks, i.e.,
a track may be one song.
Unacceptable Discs
If you insert an unacceptable type of disc, “Please insert a playable disc” will appear on
the TV screen. Also, “- - - - - “ will appear on the DVD Player display panel. Insert a
DVD or Audio CD. The following Discs will not play on this DVD Player.
• CD-ROM
(CD-I)
(CD-R)
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Photo CD
• Video CD
May 28, 2008 | Philips Magnavox DVD/VCR Dual Player
Connect 5 piece Sony seperates stereo system
OK, this is pretty easy to do. First connect your leads from the component outputs(i.e., tape, cd, phono, etc) to the recievers corresponding input for the device. Then connect the recievers outputs to your equalizer, if it is a seperate eq. Then the outputs of that to your amplifier, then your speakers to that. Be sure all of your wires are connected with the proper polarity. These instructions may be a little different for your exact setup but basically follow the same order minus any device you dont have.
Feb 03, 2008 | Audio Players & Recorders
MAGNAVOX BIG SCREEN TV
Hi, I am having the same exact issue with mine. Although, it is only about 2 yrs old. We are still trying to find out what is wrong with it.
Aug 01, 2007 | Philips Magnavox 51MP392H Rear Projection...
48 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
