Microsoft Access 2002 for PC Logo
Posted on Dec 04, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to create a program using ms access?
How to create a program using ms access in simple inventory?
Florenn Baggao
Level 2:
Sergeant:
  • Expert 174 Answers
  • Posted on Dec 04, 2008
Florenn Baggao
Expert
Level 2:
Sergeant:
Answers
174
Questions
0
Helped
44361
Points
506
You need to study the basics of database programming. take short courses for database programming.
  • Florenn Baggao Dec 04, 2008
    you need to study the basics of database programming. take short courses for database programming.
How to develop online inventory system for a iron sail shop and which programming language is good for inventory and which database ? and php, mysql can help?
Thank you for using FixYa
Hello I see that you may be leaning toward open source, and that is a good idea for your inventory. Of course MySql will work. You could use MS Office Access, or Oasis is another good one. My previous experience has been that people hear all these big names about databases and might not even need one that expensive. Are you determined to write this one yourself or do you have a programmer in the family or are you going to pay for one? It depends on how extensive your inventory is, if you are looking at less than 500 to 1000 items then these programs may really be overkill. It is surprising how many small businesses are actually running on Quickbooks. You can take a program like that and others similiar and use just the inventory module. Some people might even be able to get by with Microsoft Works or other smaller programs. Most database programs have templates that may not be exactly like your business, but allow modification to the templates to make it more like your own. I hope this was useful and please comment if this was helpful to you.
1helpful
Can you give sample source code of visual foxpro program using mySql as database flatform
Create a connection: lcStringCnxRemoto = "DRIVER={MySQL ODBC 3.51 Driver};" + ; "SERVER=200.1.1.1;" + ; "PORT=3333;" + ; "UID=booking;" + ; "PWD=booking;" + ; "DATABASE=booking;" + ; "OPTIONS=131329;" lcStringCnxLocal = "DRIVER={MySQL ODBC 3.51 Driver};" + ; "SERVER=localhost;" + ; "UID=root;" + ; "PWD=clave;" + ; "DATABASE=booking;" + ; "OPTIONS=131329;" SQLSETPROP(0,"DispLogin" , 3 ) lnHandle = SQLSTRINGCONNECT(lcStringCnxLocal)
Accesing data:
SQLSETPROP(0,"DispLogin" , 3 ) lnHandle = SQLSTRINGCONNECT(lcStringCnxLocal) IF lnHandle > 0 cmd = SQLEXEC(lnHandle,"select QuantityRooms from roomtype","cur_roomtype") IF cmd > 0 BROWSE ELSE AERROR(laErr) MESSAGEBOX("Can't connect to mySQL. Error: " + CHR(13) + laErr[2]) ENDIF USE IN cur_roomtype SQLDISCONNECT(lnHandle) ELSE AERROR(laErr) MESSAGEBOX("Can't connect to mySQL. Error: " + CHR(13) + laErr[2])
ENDIF
Creating complex sentences:
TEXT TO lcSQLcommand NOSHOW SELECT Inventory.inventoryid, Inventory.date, Inventory.roomtypeid, Inventory.sold, Roomtype.descrip, Roomtype.rooms FROM inventory Inventory INNER JOIN roomtype Roomtype ON Inventory.roomtypeid = Roomtype.roomTypeID ORDER BY Inventory.date DESC ENDTEXT cmd = SQLEXEC(lnHandle,lcSQLcommand)
Passing parameters to a query:
nValor = 12 cmd = SQLEXEC(lnHandle,"select QuantityRooms from roomtype where roomtypeid = ?nValor","cur_roomtype")
Calling a Stored Procedure:
SQLEXEC(lnHandle, "call myStoreProcedure(@param1)")
GOOD LUCK!
2answers
What is ms-excel
ms excel is a program that you can make graphs and set up all sorts of things like prices at a petrol station on the front neon sign you can set it up that each time the price rises it will automatically increase that rise in dollars and cents
hope this helps
1helpful
Choices available to create database of c++ program
You should use the MySQL database as it is free to use and has great functionalities.
go to the belo link to get details about creating database and using in ur c++ code.
http://c-programming.suite101.com/article.cfm/using_a_mysql_databases_with_c
Thanks!
Rating Teachers Behavior Inventory
You could assemble a simple Excel spreadsheet and then total, average, find the mean, standard deviation, trend or a host of other answers or information. You can lock the spreadsheet so no one can tamper with it or change the structure. That would be much easier than creating a special program unless there is a specific reason to do so.
2answers
Create an inventory prog. in visualbasic?
Do you have Microsoft Office? There are some excellent Access Templates for Inventory Databases
access has a complete tutor built in id do the course press F1
and ask.
hope this helps
18helpful
3answers
Connectivity between HTML page and Ms-Access
<HTML>
<BODY>
Set MyConn = Server.CreateObject("ADODB.Connection")
MdbFilePath = Server.MapPath("sample.mdb")
MyConn.Open "Driver={Microsoft Access Driver (*.mdb)}; DBQ=" & MdbFilePath & ";"
SQL_query = "SELECT * FROM Friends"
Set RS = MyConn.Execute(SQL_query)
WHILE NOT RS.EOF
<LI><%=RS("Name")%>: <A HREF="<%=RS("Link")%>">Homepage</A>
RS.MoveNext
WEND
</BODY>
</HTML>
3answers
Ms access
before this u should know what is databse.
ms access has various objects likw table,form,query,report etc..
table is a object which stores the actual data and form is used to enter the data in to the table and display the data from the table, while report is object which is used to desplay your data in required formate.Query is used to fetch the data from the table in customised formate.for that u should have knowledge of SQL.
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
