FixYa.com
Tags:
Vantec 1 Bay NexStar 3 USB 2.0 External Drive Case
NexStar 3 External Drive
posted by wanamoka on Feb 06, 2007
I am getting the error when I try to open- E:\ is not accessible Incorrect Function.
I have tried two different firewire usb, checked the serial bus controllers and windows says its working. Ieven went throught the trouble shooter and can't find the problem.
No problem with any of my usb ports either.
If you know the fix I sure would appreciate it.
Wanamoka
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 14, 2007
Not Rated (0)
warewolf2001
Rank:Wiz Wiz
Rating: 82%, 85 votes
have you got a firewire dvd or cd drive you could test with as this problem is acuring with all firewire controllers have you got one on board if so turn this off in the bios also check it out on another operating system pc as you did'nt say if you are using mac or pc.
if all is fine on another pc or mac then their is a conflict issue with motherboard and controller card please use usb for now then upgrade to a motherboard that it worked with.
hope this solves problem
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Drive Cases problems?
Vantec 1 Bay NexStar 3 USB 2.0 External Drive...
nexstar 3 external hard drive
I'm a moron. I've plugged the... Answer This...
please help to change the name...
I would like to change the name... Answer This...
cant get my external hard drive...
please help Answer This...
nexstare 3
lighting surge took out board... Answer This...
Nexstar IDE to USB, Will Not...
Laptop hard drive is having... Answer This...
Repair Service
Find Drive Case Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
