Question about Car Audio & Video
Installing new radio in a 2003 Ford F-150
Need color code . I am putting in a Sony Radio and removing the factory one in my truck.
  • 85 Answers
Ok try this link :
TIP: the best way to test speaker wires to be sure is with a small battery (triple AAA or double AA should be fine or 9v is easiest) and touch the positive and neg terminals of the batt to the speaker wires and you should hear a popping sound in the speaker and to determine which wire is positive and neg just look at the speaker and if it moves outward when you touch the wires to the batt then the polarity is correct if it goes inward than it is backwards.
Hope this information helps
Posted on Dec 04, 2008
I want to change my F-150 radio, basic, with a radio/cassette/cd, will I need a different harness?
You will need a harness adapter for your model truck. This you will want to solder and heat shrink over the solder joints (Dont just twist tem together) then just plug it in to the factory harness.
You will probably need an adapter kit also.
The wiring harness adapter should come with the color codes for the wires corresponding to your trucks speaker and power wires pinouts make sure you correctly connect them to the color codes of the stereo for proper speaker placement and voltages
Mar 13, 2011 | 2006 Ford F-150
Installing newer radio in older truck
Hello zachary_reed,
What you need is an aftermarket wiring harness. These are made by Metra, Scosche, and others and are made to plug directly into the OEM radio harness. It appears that the one you want is the Scosche FB02B available from SonicElectronix. You simply connect the wires from your new receiver to the harness wires and then plug it into the factory radio plug. Another online retailer that sells aftermarket harnesses is Your local car audio shop or perhaps Best Buy may also have the wiring harness.
Be sure to match up the wires from your new radio harness to the aftermarket harness by FUNCTION, not by color. For example, most newer receivers will use Yellow as the 12V constant (hot) wire. The wiring color code for your F150 is shown here. Make sure that the pin on the aftermarket harness is connecting the yellow from your new receiver to the green/yellow of the OEM plug and so on.
Hope this helps.
Jun 09, 2009 | Pioneer DEH-1100 CD Player
05 Ford F150 Radio doesn't work.
I had the same problem and i brought a new ford oem cd player 2 times and my mechanic says its an electrical problem with some fords not the Cd player or the radio. So your cd player may not be junk, it may be electrical or wiring problem.
May 25, 2009 | 2005 Ford F-150
Wiring color meaning
did you buy a factory radio connector to connect the old harness to the new radio wiring if not you can get one at wall mart for 20 dollars and it will be color coded
Mar 08, 2009 | Sony XPLOD CDX-GT200 CD Player
I had the same problem and all I did was buy new wires the ones that came with the stereo itself burned up and seased to work. now I paid $6.00 for it at best buy. they look the same colored wires as the ones that came in it.
Dec 29, 2008 | Roadmaster (VR500CSBT)
Need To Wire In A Aftermarket Radio In A 2008 F-150
Easiest way is to go to web site, When you order a radio face plate or factory wireharness they give you a free installation kit which shows the color codes of each wire for the radio. Also, when you get the wireharness you don't have to cut any factory wires, it just plugs into your factory harness and you connect the open ends to your new radio.
Dec 18, 2008 | 2008 Ford F 150 2WD
Ford car stereo.
Thank You, any ways..I finaly found a color code from FORD parts direct..I have the color pinout for the new radio..(Sony am/fm/cd) Now I need to get the conectors and wired together.Thank You..again.
May 18, 2008 | Car Audio & Video
Car Audio & Video Logo
487 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
