Question about Sony Watchman FDL-220R 2.2 in. Handheld Television
All TV's that use an outside antenna or rabbit ears will have to use a converter after February 7 unless they have satellite or cable. What about these small LCD televisions?
  • nancyvaden Dec 07, 2008
    Thank you so much!
    Genius:
  • 1,199 Answers
Most will work if they are a newer model
Posted on Dec 07, 2008
We want to hook our small Magnavox tv to a rabbit ear antennae to get only local stations. How to do this?
Unless this a new TV with ATSC (digital) tuning built in, you will need a digital adapter for off-the-air reception. Older TV sets have analog tuners, and analog broadcasting ended in June 2009. Wal-Mart and Radio Shack carry the adapters, as do other retailers. Your antenna connects to the adapter, and the adapter sends the converted signal to the TV on channel 3 or 4.
With digital broadcasting, a strong signal is necessary. Unlike the analog days, when a weak signal just meant a fuzzy picture, a weak digital signal will cause pixellation (blockiness) or freezing of the picture, or may not even be detected by the tuner. Depending on how far you are from the station's transmitter, you may find that rabbit-ears may not work too well. You may need an amplified antenna or even one outside to get best performance.
Aug 07, 2011 | Televison & Video
Finds no channels
It is meant for Rabbit Ears or Outside Antenna Only.....
Jul 24, 2009 | Insignia Digital-to-Analog Converter for...
Digital Converter connection with old Rabbit Ears TV
First, make sure your connections are right. The rabbit ears need to be disconnected from the TV and reconnected to the converter box. Then the output cable from the converter box connects to the TV. Then try turning the rabbit ears or re-locating them near a window if the wire is long enough. You should be able to get some signal. A newer indoor antenna may help you pull in some of the weaker stations.
Jun 15, 2009 | Insignia Digital-to-Analog Converter for...
Analog or dtv
Hi, This tv has an NSTC tuner which is analog. If you subscribe to cable or satellite it will work just fine without you having to do anything for the upcoming change. However if you are using your own outside antenna or rabbit ears you will need a converter. Hope this helps.
Jan 30, 2009 | Philips 20PT6446 20" TV
2004 MODEL 24V511T. DO I NEED DIGITAL TUNER IN ORDER TO RECIEVE
If you receive your TV signal ovr the air using rabbit ears or a rooftop antenna, yes you will ned a converted box. If you have cable or a satelite signal, no converter is needed.
Dan
Jan 18, 2009 | RCA 24V511T 24" TV
I'm looking for rabbit ears/antenna for my Durabrand T.V.
Radio Shack, Wal-Mart, etc. all carry a selection of antennas that will work with your converter box. Depending on the strength of DTV signals in your area, you may need an amplified antenna (has a built-in booster) to get good reception. Analog broadcasts were watchable with a weak signal (the picture would just be fuzzy), but the digital system needs a good strong signal. The sales people may be able to suggest an antenna based on what other customers have purchased and their reports of how well they do. Outdoor antennas are also available if needed.
Jan 12, 2009 | Durabrand BH1304D 13" TV
Is this tv set up for the digital switch in Feb.
If the TV was manufactured in 1993, it is NOT ready for the digital switch. If you have cable or satellite, you don't need to do anything because the cable or satellite box will do the swith for you. If you are using an outside antenna (rabbit ears) you will need to get a converter box. Hope this answers your question
Dec 21, 2008 | Toshiba 32AF43 32" TV
Does my Sanyo TV Model Number DS31650 need a converter box?
As long as you have either cable or satellite, you will be OK. The change coming in Feb. is for people who still use an outside antenna( rabbit ears). Please take time to rate this response. Thanks
Dec 07, 2008 | Televison & Video
DTV Converter Box
If there is no digital tuner built into the tv or unless you subscribe to Cable TV or Satellite service you will still need a converter to view tv with rabbit ears (air broadcast).
I Can Fix It
Sep 22, 2008 | Protron PLTV-32 Television
Do I need a converter for the February 2009 switch over?
If you receive you rsignals from a set of rabbit ears or an antenna, yes you will need a converter. If you have cable or satellite a converter is not neeed.
Dan
Sep 03, 2008 | Toshiba 27A44 27" TV
Sony Watchman FDL-220R 2.2 in. Handheld Television Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
