Question about RCA R52WH73 Projection Television
Digital Tuner and Thanks
Wiltab, thanks for all the help, I got a quote of over $250 bucks to fix this problem. Instead I went to Radio Shack and picked up a soldering kit for $10... what a life saver.
I do have another question I will shoot you. The digital tuner also went out on the same tv. It is also removed from the options menu. I would figure it is a fuse as well???? Any help would be appreciated.
Actual TV is the R52Wh74, no option for it...
Thanks in advance
    Genius:
  • 1,030 Answers
Ok in the setup menu. when you program your channels It have the option for digital tuner analog tuner or both. if you do not have this you may have a problem with your digital tuner board also known as admin board. it the board that sits above the green signal board, check the cables that go to that board make sure connectors are good.
Posted on Dec 05, 2008
Testimonial: "willtab is a life saver, saved me several hundred dollars."
    Problem Solver:
I do NOT have the option to select both/digital from the menu. Should I replace the whole admin board or could this be caused by a blown fuse? Thanks again for all of your time.
Posted on Dec 06, 2008
Tip
Wiltab, thanks for all the help, I got a quote of over $250 bucks to fix this...
FL231. FUSE.... The RCA ITC222 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and green shadows? Does it have bowing in affect on the top and bottom of picture? when you turn it on does some thin red green and blue line bow in from the top then go away. The main question to determine if you have the fl231 fuse problem is if you go into customer menu then setup do you have the "CONVERGENCE' option. If you do not. then i suspect you have this problem. In the manufactering of these sets Lead free solder is used. now there is great debate over the use of lead free. connection tend to be more brittle. cracks develop around the solder connections of the high voltage flyback transformer. this very small crack set up oscillations in the cuicit with a 400 milliamp fuse. THis fuse cant take it. When this fuse blows the processor then does not know its a projection tv with three projection tubes. it thinks its a crt tube tv. and crt tube tv dont need "convergence" so it removes the convergence from the set.
TO REPAIR... 1. Warning. this set can generate leathal dangerous voltages even unplug do not attempt if you have no experence with electronics.
2. Remove the back. there a number of torx 20 screws.
3. what you will see is a number of circit boards There will be one on the right and one on the left. the one on the right is the small signal board. the one on the left is called the power deflection board. it has a large black part with a big red or black wire coming from the top, this is the flyback.Next to the flyback on the right of it there will be three small rectangular componets tan or brown in color. these are fuses. the one in the middle is the fl231 fuse.
4. getting to this fuse can be difficult. these two cuicit boards sit on a tray that is removable. to remove this tray it is pulled out and up. BUt watch the wires.loosen the wire tyes.
5 when you get the tray up the bottom side of the board can be accessed
you will now have to unsolder that fuse. one side of this fuse is under a plastic part of the tray. i have found the easest way is to cut away the plastic to get to it. if you dont want to do this you will have to remove the board. only remove half of the plastic brace
6. REPLACE FUSE RCA PART 259213
7 RESOLDER FLYBACK CONNECTIONS simply heat up and add a little solder
8 reassemble set. make sure you examine the set for loose connections.
9 and remember "BE Careful'
on Dec 04, 2008 | RCA R52WH73 Projection Television
Hi there, Is there a way to record your own message for the answering machine msg instead of that guys voice that says "Please leave a message".? THanks, Sarah
The instructions for recording the outgoing message are on page 10 of the manual at
http://www.radioshack.com/graphics/uc/rsk/Support/ProductManuals/4303808_PM_EN.pdf
Aug 07, 2011 | Radio Shack 3808 Digital Answering Machine
Tuner not working
You mean a digital tuner or an analog tuner (the old ones with the cursor)?
Post for reply.
Stelios.
Feb 23, 2010 | Proton R5A Clock Radio
Lost charger for aqtlantis 250. If i go to radio shack what do i ask for? THANKS. TOM
Charger - Cradle for Uniden Atlantis 250 - Uniden Part # GCAS3B3640Z (Cradle Only - No adaptor)
Hope this helped.
Jul 18, 2009 | Uniden Atlantis 250 Marine Radio
Samsung syncmaster 910mp TV connection
I believe you are describing this connector adapter.
http://www.thesource.ca/estore/ catalog number 2780265
Jan 16, 2009 | Samsung SyncMaster 910MP 19" LCD Monitor
No TV Reception
Sony Technician confirmed that that the TV has an analog tuner
2 options - outdoor antenna with digital converter --- or cable service
Jan 16, 2009 | Sony KP-53V75 53" Rear Projection...
Convergence
Convergence. your convergence has failed. first questuion does the autoconvergence work.. in the customer menu under setup do you have the convergence option if you do not go to the tips and tricks section under my profile and read the article fl231 problem this is a simple inexpensive repair. NOw if you do have that option then you may need to replace what is known as convergence power supply
Oct 27, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Panasonic CT-32sl 13 32" TV
This sight rocks! And so do the people that posted information! Went to Radio Shack and got the 6.3amp 250 volt fuse. Fuse was easy to get to once I removed all of the screws and easily slid off the back. $2.99 fix (foe the fuses)
Jan 04, 2008 | Panasonic CT-32SL14 32" TV
RCA R52WH73 Projection Television Logo
101 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
