Question about Epson Stylus 1520 InkJet Color Printer
Very Noisy when Printer initializing - Cover Open Light on
When I turn on the printer and it starts its initialization routine, the mechanism that moves the print head back and forth seems to be stuck and the gears (?) make a terrible racket. After a few attempts to move the print head fail, the routine stops and the Reset Light start blinking as well as the Cover Open Light (which is NOT open). I love this printer - it is a mighty work horse. Any ideas as to what the problem is and how to solve it so I can get it back in the field.?
BAD news - this combo of lights indicates 'fatal error' - usually fixed by power-off then power on - if it repeats then there is a mechanical error with the printhead transport mechanism probably jammed by foreign object or broken part - only solved by opening up - unless you are confident about your fixit skills, then best solved by a qualified service technician - the printer is too valuable to poke a screwdriver into at random.
Posted on Dec 22, 2008
My laser jet pro map m177fw is stuck initializing, and i have tried everything. i have read several other's issues, but mine persists. can you help?
Please review the HP troubleshooting for your printer:
HP Color LaserJet Pro MFP M177fw
If this printer is new, you may need to make sure the toner cartridges are seated and installed correctly.
It appears others have had similar issues and solutions are provided here:
Laserjet Pro MFP M177FW stuck in Initializing
May 16, 2017 | The Office Equipment & Supplies
Initializing
NVRAM Initialization:
1. Turn the printer off.
2. Press and hold down CANCEL (X) and Start Copy (button just below the X button) buttons at the same time while powering on printer. *Keep these buttons press while you power on the printer*
3. Continue to hold down buttons until the printer display reads PERMANENT STORAGE INIT.
4. Release the buttons when "PERMANENT STORAGE INIT" is displayed. Printer will return to Ready automatically.
Dec 12, 2012 | HP Hewlett-Packard - LaserJet Pro M1217nfw...
Hp laserjet 9050n appear disk not initialized .how to solve. thank you.
Turn off printer
Press and hold PAUSE/RESUME(START on MFP)
Turn on printer
Keep holding the PAUSE/RESUME or START until all 3 error lights light
Release the buttons
Press LEFT ARROW(5 button on MFP) until INITIALIZE DISKS appear
Press the CHECK(6 button on MFP)
Wait for printer to READY
May 11, 2011 | HP LaserJet 9050 Printer
Hi i have just inherited a designjet 430,it is not connect to a computer as yet. i have loaded a roll of paper and ran some tests which seem to work ok except when i press the set up button the media light...
Either: the sheet you loaded is
misaligned.
Realign it again. See the Users Guide
for a short tutorial on loading media.
Or: it is an invalid size.
For supported media sizes, refer to the
Users Guide.
Or: the media lever is lowered.
Raise the lever.
Or: the cover is open when the printer is
initializing.
Lower the cover
These are the trouble shooting suggestions from the HP service manual
May 01, 2011 | HP DesignJet 430 InkJet Printer
Says printer has a paper jam. There is no paper
if you can open the cover of your printer then cleaned all the sensor inside maybe dusty which cause an error. try to look also any obstacle at the mechanical assembly because during power ON it needs initialized that needs mechanical free to move side by side so it works properly.
Apr 11, 2011 | Canon Office Equipment & Supplies
I get a error initializing scanner?
Background of issue- When 4345/M4345 boots up, amber light comes on under start button and the message "Initializing Scanner" is displayed. The unit will print but will not preform any scan functions.
Steps taken to try to resolve issue:
1. Updated firmware
2. Restored factory defaults
3. Took off cover in back of printer covering scanner controller board and reseated all cables
4. Took apart scan unit and cleaned (2)mirrors in scan head
5. Took off back cover of unit, reseated cables coming from scanner controller board
6. Ran Scanner Test, in menu (which everything functions properly)
Usually I would say scanner or controller board has failed but I had 3 M4345 come down with this issue in one week. The only resolve i've found for this issue is repetitively turning on and off the unit until it comes up without "scanner initializing" message. Once it comes up it functions 100% until the unit is turned off and issue will come back.
I'm at a loss here with so many units having same issue, open to any advice. I once took the formatter out of bad unit and put it in good one and it caused the issue in the good one but i'm double verifying this tonight. Thanks for any help.
Nov 17, 2010 | HP LaserJet 4345mfp Printer
I purchased recycled ink cartridges for my HP6380 and have had nothing but problems since.....I get error messages that cartridges are empty, now it won't print at all, and I have changed out all...
You might try to reset the product. This would be similar to initializing the printer when new. (Suggest new cartridges for better odds of success).
Your control panel should have the following two buttons somewhere:
<OK> and <X> [might be <Cancel>]
1) Press and hold both <OK> and <X> until the printer powers off. Release the buttons
2) While pressing and holding the <OK> and <X> buttons, turn the printer power on. It should cycle for a short while, then turn itself off again.
3) Turn the printer on again using just the <On/Off>
This time, the printer will start an initializing routine that could take up to 5 minutes to complete. Please do not disturb it during this task.
Try printing again, or print a test page to verify results
Jan 03, 2010 | HP Photosmart C6380 All-In-One InkJet...
Hp designjet 1050c printer displays a system error
Printhead failure this is.
Turn the printer on.
Following initialization,
use the Down Arrow key to scroll to the Ink system menu icon and press Enter.
NOTE:If the error code appears during initialization press the Enter
key to allow printer to complete the rest of the initialization process.
Scroll to Replace Printheads and press Enter.
The printer should now move the carriage to an accessible position.
Open the top cover.
Remove all four printheads.
Turn the printer off using the main power switch located on the back of the printer.
Following initialization, insert one printhead at a time, starting with the black printhead.
Determine whether or not the printer accepts the printhead.
Turn the printer off and repeat steps for each of the printhead.
Replace the failed printhead.
Hope this helps
Regards
Apr 17, 2009 | HP DesignJet 1050c InkJet Printer
Blinking Resume Light
i think the problem is that the printer could not initialized the printer head position. you can open the cover and turn on the printer. check if the motor for feeding paper moves but the roller does not. replace the gear attached to the roller. i hope this will help.
Jul 24, 2008 | HP DeskJet 612c InkJet Printer
Epson Stylus 1520 InkJet Color Printer Logo
140 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
