Question about Hotpoint HSS25IFMCC / HSS25IFMWW Side by Side Refrigerator
Icemaker making small amount of ice
Hotpoint side by side freezer model #HSS25GFPDWW
making small amout of ice, water is flowing fine from outlet on door
freezer freezing okay; doesn't seem to be enough water going into freeze tray, not sure how much should be in tray
I RESET THE SWITCH ON THE ICE MAKER AND TURNED THE TEMP TO 9 FROM 5 AND IT STARTED MAKING MORE ICE. I'M NOT SURE WHAT WAS WRONG BUT IT APPEARS TO WORKING FINE NOW.
Posted on Dec 05, 2008
What this can be?
On the rear of the refrigerator, there is a water control valve, that controls the flow of water to the icemaker and the water dispenser, if equipped. Hard water is usually the cause for this to quit running. The icemaker and water dispenser, are two separate circuits, and each one has it's own water control valve.
Mar 13, 2015 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Kitchenaid Superba Ice Maker quit
If you add some water there, yourself. It should make some ice for you, untill the water runs out.
Try this
http://www.acmehowto.com/howto/appliance/icemaker/diagicemaker.php
Sep 08, 2008 | KitchenAid Superba Architect KSCS25INSS...
Adjust amount of water to ice maker
there is a small setting on the icemaker module, but it only makes a VERY small difference. you would want to fix the water supply issue though. the icemaker fills a ceartain amount of time, not to a level, so if you increase the time, it is still filling so slow that it won't make a big difference.
3 possibillities for slow water flow
1. flow coming into the fridge is too low- plumbing issue, likely at the water valve under your sink.
2. Water filter needs to be changed every year
3. Bad solenoid valve in the fridge. it is where the water enters the fridge.
May 19, 2012 | Kenmore Refrigerators
Water is leakig from behind the control panel
You did the right thing by trying to clear the drain in the back of the freezer, but it must not have cleared. If the ice maker is not leaking then the only other source of water can be defrosting ice build up on the evaporator coils when it goes through its cycle. You know your drain is clear when water can flow down it. Defrosting your refrigerator completly usually solves this. If it does not, then check to make sure the freezer compartment fan is working, next it may be either your thermostat or timer control. Those are pretty much the only possibilties.
Aug 25, 2009 | Hotpoint HSS25GFP Side by Side...
Bosch Side by Side, top shelves dont freeze food, bottom does
majority of refrigerators today are equipped with an automatic icemaker. The water valve supplying the icemaker is a key component of the icemaking system, and it should be the first thing you check if the icemaker's performance is erratic or if the icemaker stops working. When the icemaker calls for ice, its switch closes an electrical circuit and energizes the solenoid-operated water valve. This allows water to flow through the valve and into the ice cube tray. The water is frozen into cubes, and the cubes are dumped into the ice bin. As time passes, strange things may happen to the refrigerator's icemaking capability. The cubes may be small or there may be a solid chunk of ice instead of individual cubes. It's also possible that the icemaker will stop working. These are all signs of a malfunctioning water valve. The valve is equipped with a screen on its inlet to remove minerals and sediments in the water supply. Over time, minerals and sediment build up on the screen and restrict flow through the valve, or even block it completely. Minerals that make it through the screen can cause the valve to stick in the open position, overfilling the ice cube tray in the process. This is a common problem in areas with hard water, but it can happen just about anywhere. Another malfunction that will cause the icemaker to stop working is a break in the solenoid coil winding. This is known as an open coil. The coil winding generates a magnetic field as current passes through it, and this magnetic field opens the plunger valve that controls water flow. A break in the coil winding stops current flow and this prevents the valve from operating. Test And Inspect The icemaker's valve is easy to inspect and test. First, gently pull the refrigerator away from the wall, and unplug it. Turn off the water supply to the icemaker by closing the shut-off valve in the copper waterline leading to the valve (Fig. 1). Use a screwdriver or nutdriver to remove the rear lower access panel from the refrigerator's back. Next, remove the fill tubing from the water valve. Use a wrench to loosen the flare nut on the brass fitting on the inlet side of the valve (above). Place a container under the valve to catch the small amount of water that will spill from the valve and tubing. Now use a screwdriver or a nutdriver to remove the screw holding the valve's mounting bracket to the refrigerator cabinet (Fig. 2). Pull the valve out of the compartment and remove the tube on the valve's outlet. Then, remove the solenoid's electrical contacts (Fig. 3).
Mar 29, 2009 | Bosch KGU66920 Side by Side Refrigerator
Icemaker on Hotpoint Model HSS25GFPAWW Refrigerator not working
try turning the temperature for the freezer down a little bit. it has to at least be around 17 degrees before the older ice makers start to work.
Jan 20, 2009 | Hotpoint HSS25GFP Side by Side...
Too much water getting to ice maker
The little cup that sits in front of the hose that dispenses the water, has frozen water in it . Check that first and if it's OK, then there is a small screw that you can adjust, look at your manual.
Nov 03, 2008 | Kenmore 53642 / 53644 Side by Side...
Too much wate flow into icemaker
it over filling or it leaking from the mold i never seen thi model over filled mold when i see wtr in bin is usually the mold that is leaking you can check with a mirror or remove to inspect is texture is peeling off repl entire ice maker if is ok then repl wtr valve is not closing when it has filled the mold you only need 4oz of wtr
Nov 02, 2008 | Kenmore 53642 / 53644 Side by Side...
Side by side refrigerator icemaker not making ice. Hotpoint mdl HSS125IFMD Tried installing new filter. Getting water but no ice being made.
I would first try replacing the solenoid valve which lets the water in. Also, how are the ice cube arms aligned? They should be vertical
Jul 04, 2008 | Refrigerators
Water leaking inside freezer ice maker
sounds like the line was frozen but the water fill indicator is faulty.
Jun 05, 2007 | Hotpoint HSS25GFP Side by Side...
Hotpoint HSS25IFMCC / HSS25IFMWW Side by Side Refrigerator Logo
222 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
