Question about Lexmark X4270 All-In-One InkJet Printer
Paper will not feed into scanner
Nothing will feed into the scanner. I insert a paper and it sounds like a motor is running to pull the paper in, but the rubber wheel does not move.
  • Ron Richey Oct 16, 2007
    "get it fixed" -- brilliant observation, Guest...
    Lexmark does not "fix" these problems nor make repair parts available.  They simply replace the machine if it is deemed to be under waranty.  Otherwise, you are simply SOL.
    What I actually did, was dis-assemble the printer, and found a small tab broken off the rotating roller that was pushed along by a rotating shaft.  A little epoxy with some ultra-fine wire embedded in it for reinforcement, repaired the tab, and the printer works once again.
    --rrichey
Get it fixed lol
Posted on Oct 16, 2007
The auto feed on my vupoint magic wand stopped working. What's going on? How do I fix it
I imagine could be few possibilities why:
bad motor
bad gear, roller, belt or something other connecting motor to feeding mechanism
bad or dirty paper sensor (scanner doesnt recognize that paper is inserted)
May not to be cost effective to repair it.
Oct 06, 2018 | The Office Equipment & Supplies
Unit runs with nothing inserted into shredder
About 598,000 results (0.73 seconds) Search Results
    [PDF]Shredder Troubleshooting FAQ
    https://images-na.ssl-images-amazon.com/images/I/81GTHxKpz9S.pdf
    Make sure that the unit is securely plugged into a working outlet / socket. 2. If you have ... The shredder runs but it does not pull paper down. 1. Be sure the ... When ready to shred, be sure to insert material directly into the center area to start.
    [PDF]Instructions Manual
    https://images-na.ssl-images-amazon.com/images/I/71EUxqIkPNS.pdf
    you leave the shredder in the "Off" position whenever the shredder is ... To beginshredding, locate the switch on the unit and select the "Auto" mode (FIGURE 2). ...Your basic vegetable or cooking oil (nothing flammable ... a) While in "Auto" mode, the motor will not start running until paper is inserted into the feed slot. Set.
    General Shredder Troubleshooting - iThinkBlue
    store.ithinkblue.com/shredder-troubleshooting/
    Make sure that the unit is securely plugged into a working outlet / socket. ... While in "Auto" mode, the shredder will not run until paper is inserted into the middle ...
    [PDF]troubleshooting paper shredders - Ativa
Jan 31, 2016 | Shredder Office Equipment & Supplies
Documate error 8
Hello.
I am a Support Engineer with Xerox Scanners.
E8 is a Paper Jam error that could be caused by:
- paper crumpling during scan.
- paper is multi-feeding all at once instead of feeding separate.
- scanner continuously tries to feed after paper has fed through.
if the paper is crumpling during the scan, make sure the inside of the scanner is clear of any obstructions. use the paper guides in the ADF tray to keep the paper straight when feeding in.
if the paper is multifeeding while scanning, fan out the pages before inserting them into the scanner. if problem persists, try cleaning the rollers with rubbing alcohol and a lint free cloth.
if scanner tries to continually feed after the paper feeds through, the ADF tray will need to be reseated. open the scanner and remove the ADF tray at the top. line up the 4 keys at the bottom of the tray with the 4 corresponding key slots inside the scanner. push the tray back until it clicks into place.
We also have an extensive support site and knowledgebase at
http://www.xeroxscanners.com/en/en/support/
If you continue to experience trouble, please feel free to contact us by calling 800-648-0410.
Regards,
Xerox Scanners Support
Jan 28, 2013 | Xerox DocuMate 162 Pass-Through Scanner
The belt inside my scanjet 4200c has come off. How do I reattach it? I have opened the scanner. It looks to be relatively easy but I don't know how to attach the belt to the motor etc
Instructions
1 Lift the hatch on the feed tray and pull up the large green tab to the left of the roller. Remove any jammed or torn paper from under the roller and around the feed tray.
2 Pull the input feed tray out of the automatic document feeder. Grasp the feed tray with both hands and pull it straight out.
3 Check the interior of the automatic document feeder for jammed paper. Remove any jammed paper, then reinsert the feed tray into the automatic document feeder. Push down the feeder cover until you hear a click.
Mar 08, 2011 | HP Scanjet 4200c Flatbed Scanner
Runs only in reverse
I just had this problem with my shredder. I think the problem started with a bin that was full. Running the shredder in reverse resulted in shredded paper being pulled up into the slot used to feed paper into the shredder. Some of this shredded paper was blocking the little plastic tab that activates the switch when paper is inserted, so the shredder would no longer start when paper was inserted. I emptied the bin and removed the shredded paper from the feed slot, being careful not to break the plastic "sensor" while removing the paper from under it. The shredder works fine now.
Nov 06, 2010 | Fellowes W11C Confetti-Cut Shredder
Paper tray some times paper are not passong through
if you're using bargain paper try upgrading paper quality, it will feed more reliably! or try tapping the edges of your paper 'stack' on a flat surface and inserting it firmly into the feed slot - don't 'slam' it in!
good luck! (make sure the paper is inserted evenly)
Sep 24, 2009 | Canon DR-6080 Path-Through Scanner
Lexmark x4270 wont feed paper
In this Case take out the Paper from the Paper Feed Tray........ Unplug the Power Supply from the Printer.......... Remove both the Cartridges from the Printer.......... Now take a size 10 Envelope fold it so that it should become like a thin long strip........ Now Insert that Envelope on the left side corner of the Printer and move it from right to left and left to right as fast as u can for about 10 times.......... Now Insert the Ordinary Papers onto the Printer and insert both the catridges and Turn on the Printer...... It should resolve the Issue......... Good Luck..........
Jan 16, 2009 | Lexmark X4270 All-In-One InkJet Printer
Lexmark 4270 won't feed paper to print or copy!
In this Case take out the Paper from the Paper Feed Tray........ Unplug the Power Supply from the Printer.......... Remove both the Cartridges from the Printer.......... Now take a size 10 Envelope fold it so that it should become like a thin long strip........ Now Insert that Envelope on the left side corner of the Printer and move it from right to left and left to right as fast as u can for about 10 times.......... Now Insert the Ordinary Papers onto the Printer and insert both the catridges and Turn on the Printer...... Good Luck
Trouble with paper feed
Frequent jams are because either scanner picks up more than one paper or does not pickup at all. If scanner picks up more than one paper, then paper is sticky. If the paper is thin, it can pick up two at a time. Fan the papers so that they are not sticky.
Paper at the point of entry into the scanner must be crisp. If folded or 'dog-eared' trim it. Rotate the paper if any other side is crisp, roate the image later.
Clean all the rollers thoroughly, the pickup roller, retard roller and other rollers in the scanner. One can rotate the inner rollers and clean totally, not just waht is seeable area. If the rubber is worn out, it must be replaced. TRy a single page to check if the rubber is okay. Jarring noise is because the motor is 'stopped' and cant rotate because paper is stuck. This can affect motor/inner parts, but is designed for normal use.
Feb 02, 2008 | Canon DR-7080C Flatbed Scanner
Lexmark X4270 All-In-One InkJet Printer Logo
71 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
