Question about Acer Aspire 9300 Notebook
Acer Aspire 9300 Keyboard replacement
How do I remove the keyboard from the laptop? I have to check under it to see if my daughter spilled anything on it. I have basically taken every screw out of it and I can now see the frame lifting off, but I don't want to unhook any of the cables until I know I can get them back onto the motherboard.
  • Ron Baxter Dec 13, 2008
    Acer Aspire 9300. Can someone please help. How do I get the keyboard off? The connecting cables are so small I cannot reach the plugs to release the keyboard and may not be able to get them back in....
I have the Acer 9000/7000 pdf service manual if anyone would like it.
You may contact me at jonyjams @ hotmail.com (take the spaces out before and after the @ sign)
Posted on Jun 18, 2009
  • 395 Answers
The thin plactic strip where the power button is come's out and should see 3 spots where a flat head screw driver will fit and help lift it out. once thats out there should be 3 or 4 small screws to remove the keyboard. you should not have to remove and screws from the bottom of the laptop to remove the keyboard
Posted on Dec 11, 2008
ACER ASPIRE ONE NETBOOK need help, keys 5,7,9,-,[ have stopped functioning, possible to small amount of coke being spilled on keyboard, have removed keys to clean under them but doesn't seem to make...
There's a need for you to bring your netbook to a service center to check for any possible hardware problem. Usual cleaning should be able to resolve this issue but if not it requires a local service center to ran further check on your netbook.
Apr 11, 2011 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire 5602WLMI water in keyboard
Here is a great deal on a replacement keyboard:
http://www.sunvalleyus.com/AcerKeyboard/Acer-5601AWLMi-5602WLMi.html
To replace it, first of all, remove the power connector and the battery before you do anything on that laptop.
remove the 3 screws in the middle cover. remove that middle cover by putting a screwdriver in one of those holes which are covering the displaybrackets. pull it up slowly. same thing goes for the opposite side.
remove the 2 screws which are holding the keyboard and the cable to the mainboard.
Reassembly is the reverse of dissasembly, be careful with the ribbon cable as its fragile, and there is a little plastic piece that either pulls up or pulls out that releases the cable.
One of the easiest repairs to a laptop there is.
Jul 06, 2010 | Acer Aspire 5602WLMI Notebook
Instructions on how to remove and replace a keyboard acer 9300
Unplug computer>power down> remove battery>remove all screws on exterior housing> remove internal screws> disconnect the wire/cable from keyboard>remove keyboard.
Jan 12, 2010 | Acer Aspire 9300-3716 Notebook
How to replace a acer aspire 5735 keyboard
Here is the factory service guide that explains complete servicing of the laptop. Make sure to save a copy for yourself, the file is free to use.
http://tim.id.au/laptops/acer/aspire%205735%205735z%205335.pdf
Oct 11, 2009 | Acer Aspire 5735 Notebook
Replacing keyboard on acer aspire 9300
there are some screws in the hinge cover that pops out in most laptops , then a few screws to remove keyboard, and the cable attaching keyboard to motherboard , a clip to lift up
Jul 19, 2009 | Acer Computers & Internet
Problem aspire 6930
you have a locked key. it may be anything from a liquid spill to forced. but that noise is telling you that a key is locked. try removing the keyboard and plugging in a usb keyboard. if you dont get a noise then you need to replace your existing keyboard or unjam the key causing the problem
Mar 28, 2009 | Acer Aspire 6930-6771 Laptop
How do I remove the keyboard on my Acer Aspire 1640z?
Ok,
Usually there are hidden screws under the screen.
usualy under some clip or something.
if you find them unscrew the keyboard.
DO NOT YANK IT OUT!
carefully remove the cord .
PLEASE SEND A PHOTO OF THE LAPTOP for further info
Jun 30, 2008 | Acer Aspire 1640Z Notebook
Acer Aspire 5610 - one key does not work
Laptop keyboard are semi-sealed circuit boards. This means that liquid can get into the contacts and can not be cleaned. Depending on how much liquid was spilled on the keyboard chances are that the liquid has seeped around the edges of the keyboard and down onto the mainboard of the laptop. My first suggestion would be to keep the laptop turned off until you can remove the keyboard and check for liquid damage to the mainboard. If there is no damage to the mainboard I would suggest buying a new keyboard before turning the computer back on as any shorts caused by the liquid damage on the keyboard can cause damage to the keyboard controller circuit on the mainboard.
Jan 03, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 9300 Notebook Logo
2,571 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
