Question about Sony KP-57WS500 57" Rear Projection Television
Convergence ineed to replace the ic stk392-560's- can i take out just the d card? if so, how? thx kevin
  • edv70 Dec 08, 2008
    I wonder if this will fix my tv issues. There is red, blue, and green ghost images.
  • 505 Answers
If you pull the D board and replace the ICs it will likely fix your problem. Check the input and feedback resistors with an ohm meter and see if they need replacing too. Sony has 6 output fuses that may blow with the ICs. If you replace all the bad parts, you can then magic focus to get back to a somewhat normal picture.
Posted on Dec 07, 2008
Blue ghosting on LG rear projection TV- not fixed by using Auto Convergence button. Any other suggestions - Model RT39NZ40RB
Probably a failure in the convergence output circuit. Most circuits are comprised of a 2 IC package and I would recommend replacing both. $100-150 in parts and some experience with a soldering iron is good. Thx
Bill W
integrityhomeworx.com
Mar 09, 2011 | Televison & Video
My colors separate as you go from right to left across the view screen so that at the left side of the screen 3 overlapping images appear, each one is one of the RGB colors. Can this be fixed by me or do I...
U have tools like a soldering iron,a desoldering pump or a roll of desoldering braids and also can do and have pretty good soldering skills,because it involving replacing convergence ICS.The tv have dead convergence board must replace 2 STK convergence ICS and some or all it resistors too.To fix the convergence board,to solved the picture convergence problems.As i said u have all the tools have pretty good soldering skills,tries websites like Tvrepairworld.com,Tvrepairkit.com to buy a convergence kit belong ur tv model and make to fix it ur self.Or the shop,will cost like $300-350 for parts and labors.
Feb 05, 2011 | Sony KP-65WS500 65" Rear Projection...
I have a convergence problem in the bottom of the lower left quadrant pf the screen. It is like a parabolic semi circle that is at the very bottom edge of the screen. The front screen isn't damaged at...
Tv 100% have a convergence problems,if any parts of the tv picture colors lines R,G,B are mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board the 2 STK ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 23, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Horizontal and vertical lines themselves are off skew. can you adjust these convergence ines. everything else color ok
No,this tv 100% have convergence problems,it dead.Any colors lines R,G,B are mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 22, 2010 | Mitsubishi WS48511 48" Rear Projection...
Hitachi 62 v569a has a blue gost line around the sides i replaced the bulb and didn't seem to help can u give me a idea what might be wrong thx
The tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts,must be replaced on the tv convergence board to solved tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 17, 2010 | Hitachi 62VS69 62" HDTV
I have a KP-57WS500 57 in. Rear Projection
No,U have solderwicks?U can buy it,in any Radio Shack store.Use solder iron on top of the solderwicks to soap up the solders out ICS pins.Replaced the ICS use any kind solders just resoders ICS back to the heatsink.Tries Websites Tv repair World.com,Tv repairkits.com to buy a complete convergence kit.
Mar 06, 2010 | Sony KP-57WS500 57" Rear Projection...
Blue outline around images on screen and also on menu yellow offset. picture was fine. I have tried convergence and did not help
Have the convergence IC's replaced. Only one has failed but have both IC's changed as the other is not far behind..
Thx please leave comment
Oct 08, 2009 | Televison & Video
Ineed to know what convergence ic's are in this tv
Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Apr 17, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Vertical color seperation on a Sony KP57WS500 TV
YOU HAVE A CONVERGENCE PROBLEM. THE CONVERGENCE IC'S NEED TO BE REPLACED
EST $400.00
Dec 26, 2008 | Sony KP-57WS500 57" Rear Projection...
Vs-45607 Vertical Hold Problem
Good Day; Just replace the caps first, 99.9% fix if not replace 9v regulator. Good Luck, big IRISH.
Nov 23, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Sony KP-57WS500 57" Rear Projection Television Logo
49 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
