Question about Sony DCR-DVD301 DVD Camcorder
DVD ejected before finalizing and now there is nothing???
I accidentally hit eject while trying to turn on the light while recording at night outside. I was devastated when I closed it and then no menu came up. It was as if it was a blank DVD. My husband ejected the next DVD before done finalizing when I told him not to and the same thing happened. Everything I recorded before gone! I am so scared everything is gone. THe first DVD was my son's birth. I can't imagine it's just gone! HELP!!! THanks in advance!
    Champion:
  • 217 Answers
Use disc file recovery software such as norton' disc file recovery. Unreadable or corrupted disc files can be recovered using these programs in your computer.
Posted on Aug 31, 2007
Dvd stuck in computer
push eject button, slap the top of computer sould eject. the rubber type band that turns the wheel to open tray is worn out needs replaced
Apr 10, 2013 | Apple Televison & Video
Could not finalize disc because of error detection
First try reinserting, but it's probably hit a bad spot.
Might be useable as a data disk. Do a complete format which will lock out the bad spots.
Jun 15, 2012 | Samsung DVD-VR330 VCR and DVD Recorder
I tried to eject a DVD and now the DVD holder is
if you had forced it open its probably not aligned (if its still open give it a little shove and press the eject again (otherwise unplug the machine for 5-10 min..and try pressing the eject button again
Jul 09, 2010 | Toshiba D-VR4 DVD Recorder/VCR
Philips 3360H - can't eject DVD
Try this..turn it off, unplug it for a min or two, then plug it back in. THEN...if the power stays off...hit the eject/open/close button on the panel.
Sometimes this activates the eject mode without turning on the unit. IF NOT, try the remote eject without turning on the unit.
Apr 06, 2010 | Philips DVDR3370H DVD Recorder/HDD...
DVD stuck
In the front side of the dvd drive you will see a small hole ...so to eject that cd put one niddle in that hole and .
Now press the button at just after that apply a force on niddle .suddenly you will notice that cd will come outside ,if not try more times and you will learn to eject the cd when you are unable to do it by pressing the eject button...
Low feed backs hurt my ratings and I am tring to help you with your problem,so let me know that the information i given you is helpfull or not.
Thanks
Dilip Bagdi
Technical Associate
May 01, 2008 | Panasonic DMR-EH55 DVD Recorder/HDD...
DVD Stuck in Player
While the above problem is not in the manual, I would try pushing and holding down the Open/Close buttton for an extended period to see if the unit will 'unlock' itself.
Mar 16, 2008 | Sanyo DWM-390 DVD Player
Disc Tray Will Not Eject
Just next to the eject button on the actual recorder there should be a tiny pinhole.  If you use a small paperclip and insert it, then push, you should be able to manually eject the DVD.  Hope this helps!
Oct 16, 2007 | GoVideo Go Video DVD/VCR Combo
Trouble Ejecting Disks
Turn your laptop upside down. Whilst it's upside down, press the eject button!!!!
Oct 07, 2007 | Apple MacBook PC Notebook
Reading and bad disk
You can press the eject button on the drive behind the front panel or connect the ribbon cable from the drive to a PC to eject it. More instructions are on my website here: www.drx9000repair.netfirms.com/
Mar 02, 2007 | Cyberhome CH-DVR1500 DVD Recorder
Open Questions:
My Hitachi VM H710A plays just fine, and the picture looks fine. But when it playsback footage or records footage, five to ten seconds later, it stops abruptly, and flashes the word "TAPE". First thing I must add, is that I was using a prerecorded videotape, and was testing it from the beginning of the cassette and the middle of the cassette. I thought maybe the heads were dirty, and so I cleaned them using a cotton swab and rubbing alcohol. I cleaned the head drum with a piece of paper soaked with rubbing alcohol so that I wouldn't get any fibres in the heads. I waited for it to dry and then I put a cleaning cassette inside. To which, it still stopped abruptly five to ten seconds in during playback. I then decided to look at the manual of the camcorder and see the symptom. It says that due to temperature changes that it might cause this symptom. I placed it in a cool room and left it there all day and checked on it, and the camcorder is still doing the same thing as before hand. Then another cause said that it might sense some moisture. I made sure that the camcorder was dry externally and internally, and yet still, same problem. Thats when I decided to take it apart and look inside to see if there was anything odd inside the camcorder causing it to function the way it does. The belt seemed to be working fine, and there was no missing parts. The tracking poles and path alignment was fine, and not loose. Everything simply seemed just fine. So I am unsure as to why my camcorder is operating like this.
Sep 17, 2018 | Hitachi Video Cameras
See all Sony DCR-DVD301 DVD Camcorder Questions
Sony DCR-DVD301 DVD Camcorder Logo
149 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
