Question about Toshiba Satellite 1105 Series 14.1" Flat Panel LCD Monitor
Toshiba Satellite 1105 installing 1024 meg of memory causes crash
I have checked the memory, using Microsofts memory checker, and the memory checking utility provided with Ubuntu disk. Memory is 512Meg each, Crucial CT64M64S4W75. PC133 SODIMM. The computers battery is no longe working, and I am running off of the power supply. 256 Meg works OK, there is a lot of disk thrashing with modern virus portection installed. When I remove the 256 and install one bank of 512 the computer will boot to windows, but is very unstable, and will blue screen at any random point. If I install 1024, 512 in both banks the computer will lock up at post. I have thoroughly checked the memory with this computer. I think that it is power related problem. Too much current draw from the extra memory and a undersized power supply.
I also did a clean install of Windows XP, all updates installed, and minimal software running on start up.
  • Marc Hess
    Marc Hess Jan 03, 2009
    The solution to the problem is...your laptop will only support 256 MB in each bank. The Crucial web site incorrectly suggests 512MB in each bank. 512MB (256MB in each bank) works perfectly.
4 Suggested Answers
acdr
  • 1913 Answers
SOURCE: Slow computer
no but scan your system with avast antivirus with latest update download it with gooogle
then also rmeove temparory files.
also run "chkdsk /r"in run then rpess "y"
the restart the computer.
Posted on Nov 29, 2008
HEMPYODA
  • 168 Answers
SOURCE: Toshiba Satellite laptop continually shuts down.
unfortunately is sounds like your system has been compromised by a virus; which has erased or corrupted needed system files. before you give up and reformat your system you should try the Spinrite program, written by gibson research co. you can DL it here .. http://btjunkie.org/torrent/SpinRite-6-0-Release-1/3779c30edea9218ee5596b3b8c62a0aecc56767e1047
you will need a torrent service like; utorrent, shareaza, etc
Posted on Sep 12, 2009
anaesarora
  • 172 Answers
SOURCE: Toshiba satellite 1410 - motherboard problem
check all the ribbon flat cables running from batteries to pc mother board. i suspect a ribbon cable must have got split . cut or damaged.
Posted on Sep 19, 2009
  • 10406 Answers
SOURCE: hey, i have the monitor listed above and need help
Right-mouse click anywhere on your desktop wallpaper.
Click Properties.
Click Advanced.
Click Monitor, and look for any "settings".
Or, start at http://www.toshiba.com and search for your model-number, and see if any software is available for download.
Posted on Jan 05, 2010
Jumper location for toshiba satellite L850
From memory, there is no jumper. Look for bare solder pads near the bios battery... usually marked 'RST' or 'FRST' or similar. There will be a few pairs of pads grouped, you only need to short out the RST ones (a pair) Its a bit of a juggling act, but short them out during the process of applying power to the laptop. so... short out, maintain the short, plug in power, power up laptop, maintaining short for about 3 seconds..... remove power, restart.
Nov 27, 2014 | Toshiba Satellite L855-S5240 15.6" Laptop...
Monitor not coming on
First check to see if you have a Funtion button that looks like it has a desktop pc on it and a screen next to it...this button, when pressed with the "fn" key switches the display from external to internal and visa versa...if this dosen't work..then you can try to connect an external monitor to the vga connector to see if the video driver is working ok...if you get a picture,,,then you will need to have the laptop serviced for a dead screen problem...another possibility is that the backlight may have become defective on the laptop and there againg will need to have it serviced
Dec 25, 2010 | Toshiba Satellite 1105 Series 14.1" Flat...
I have hooked my Acer 1912 monitor up to my toshiba laptop as a second screen. When I select a resolution of 1280 x 1024, the display on the monitor slides over five inches to the right and I only see half...
Friend,
On the monitor go to settings and shift the screen to the left till the display is correct. However, please check for other resolutions after you have shifted. May be the monitor is not geared up to take on 1280 X 1024. Check that as well.
Aug 25, 2010 | Acer AL1912 19" LCD Monitor
My Problem w/ my Toshiba Satellite P105-S9337 model no. PSPAGU - OOJOOV is it has a strip of white line vertical on the screen and it's about 1" thick? is their a way I can fix this problem?
Connect an external monitor to the VGA port on the computer. If that display is correct, then it's probably the LCD screen on your laptop that is damaged.
Find a computer-store. They may have "pre-owned" LCD screens the same size, for about $100.
A "brand-new" LCD screen is at least $200.
Replacing the LCD screen is *NOT* something that *YOU* can fix, unless you're a qualified technician.
Jun 15, 2010 | Toshiba Satellite 1105 Series 14.1" Flat...
I have just got an LCD monitor to replace my old CRT monitor but when i plug it in and turn and after windows has installed a little grey box come sayin 'frequency out of range and to change my display...
When you power up the computer press F8 key then Enter in "Enable vga mode".
Then go to start menu->control panel->display->settings.
Then change screen resolution to 1024*768 or 1280*1024 then apply and ok.
Then check .
Let me know if you need further assistance.Thanks for using FixYa.
Dec 20, 2009 | HP vs15 15"LCD Flat Panel Monitor
Facebook is disabled
facebook access is blocked in your network. my fuess is your accessing facebook during office hours and your network admin blocked access to facebook. talk to your network admin to open facebook access if possible.
Oct 17, 2009 | Toshiba Satellite 1105 Series 14.1" Flat...
I changed from comcast to quest and I don't know how to transfer my email to my new address.
Okay now you cannot transfer your email address to your new one because of the fact of the domain change however you can pay comcast to do forwarding for you until you get all of your contacts updated i think its like $9.95 but don't set that in stone you needto call and ask.
This is just like changing your physical address but with a small fee..
I sure hope this does help you out..
Oct 04, 2009 | Toshiba Satellite 1105 Series 14.1" Flat...
Sep 19, 2009 | Toshiba Satellite 15" Flat Panel LCD...
Away from computer, screen goes black. cannot resume. have to turn off (reset) computer
It must have gone into sleep mode, Close your laptop screen and open it again, if it doesn't work get professional help
Nov 10, 2008 | Toshiba Satellite 1105 Series 14.1" Flat...
Toshiba Satellite 1105 Series 14.1" Flat Panel LCD Monitor Logo
41 people viewed this question
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
