Question about Texas Instruments TI-30XA Calculator
I need to know how to put an exponent in square root form
  • Anonymous Dec 08, 2008
    I need to know how to enter exponents on the calculator
  • Anonymous Apr 23, 2009
    how do i enter an exponent though you know 2 to the second is 4
  • 43 Answers
To get an exponent press 2nd then LN or LOG
LN is natural logs, so entering 1 then 2nd LN gives you the natural exponent of 1 which is.2.71828....pressing LN gives you the natural log of 2.71828.... which is 1
LOG is logs to base 10, so entering 1 then 2nd LN gives you the 10 to the power 1 which is.10, pressing LOG gives you the log of 10 which is 1 again
Posted on Dec 31, 2008
What is the square root of 30?
We are asking what number, times itself, is equal to 30. Five times itself is 25. Six times itself is 36. The answer is somewhere between 5 and 6. Let's split the difference and try 5.5. 5.5 times 5.5 is 30.25. This is above 30, so let's try a smaller number, 5.4. 5.4 times 5.4 is 29.16. This is lower than 30, so we need a higher number. How about 5.45? I get 29.7025. We need a number a little higher. How about 5.47? I get 29.9209. Still need a little higher. How about 5.48? 30.0304. So it is somewhere between 5.47 and 5.48.
On a calculator, you can use the square root function. Sometimes you have to enter the number before you hit the square root function and sometimes you need to enter the number after hitting the square root function. Another way of doing it is to use the exponent function, usually with a y to the x key or a ^ key. Enter 30, hit the exponent key, and then enter 1 divided by 2 in brackets.
I get approximately 5.477225575051661134569697828008.
Good luck.
Paul
Mar 29, 2015 | Office Equipment & Supplies
How do you put in radicals in the casio fx-300ms
Use the square root key. For roots of higher index, use the xRoot key; the shifted function of the Y^x or [^] with exponent 1/3 for cube root, 1/4 for 4th root, or 1/n for the n-th root.
Jul 14, 2014 | Casio FX-300MS Calculator
Write the expression in radicant exponent the given is square root of 81 what is the answer and the solution.
I come up with 3. (81^(1/2))^(1/2)=3. the Simplest form. I used 81^(1/2) because, 81 looks like 81 to the first power, instead of a fraction.
Jan 14, 2011 | Texas Instruments TI-89 Calculator
I'm doing radicals I need to type an exponent into my calculator that goes before the square root not after. how do i do that (5) as an exponent square root of 32.....the answer is 2 but how do i type it...
Use the xth-root function to compute any root. It's the fifth entry on the MATH menu, which you can get by pressing the MATH key. The fourth entry on the same menu gives you the third root without needing the 3 to be specified.
For example, to compute the 5th root of 32, press 5 MATH 5 3 2 ENTER.
Oct 21, 2010 | Texas Instruments TI-83 Plus Calculator
How do I find the square root of a number? and how do I enter scientific equations?
For square roots, use the square root key just to the left of the divide key. For example, 4 square-root = will give you 2.
The calculator doesn't have any way to store equations, scientific or otherwise. If you mean scientific notation, use the EE key just above the 7 key to enter exponents. For example, to enter 1.23x10^6, press 1 . 2 3 EE 6. For negative exponents, make sure to use the +- key to the right of the decimal point instead of the - key.
Sep 22, 2010 | Texas Instruments TI-30XA Calculator
Want to know how to calculate a number raised to a power
Use the general power key marked with X to the y ( look for the image of a key on same line as Power in the screen capture)
You enter a number then press the power key and finally the exponent. If exponent is complicated (fraction, negative or other) enclose the exponent in parentheses.
You aslo have dedicated keys for certain powers and roots (square, square rooot, cube, cubic root)
Jun 09, 2010 | Casio FX-260 Calculator
How to use the exponent key on a casio fx 300ES calculator ?
The key to use for the square, and the cube are well marked and they share the same physical key (X to 2) or [SHIFT][X to 2]. Similarly the keys to use for the square root and the cube root share the same physical location (the square root key, to the right of the square key).
For any other exponent, including fractions and negative exponents you use the universal power key labeled [X to ] ( X with a raised square).
  1. You enter the base (the number to be raised to a power).
  2. You press the [X to ] power key.
  3. You close the parenthesis (the right one).
  4. You press [=]
Sometimes the result may not be displayed as a decimal number, but as a radical (if you take a root). To make sure it is displayed as a decimal number, in step 4 above, press [SHIFT][=]
Mar 13, 2010 | Casio FX-300W Plus Calculator
I need to know how to enter anything above cube root into my TI-83.
  1. Use the universal power key marked with [^].
  2. To avoid problems if the exponent is an expression, enclose it in parentheses.
  3. To enter any power type number^(exponent)
  4. If exponent is negative use the (-) change sign key next to the dot, below the 3 key.
  5. To calculate the roots (cubic, fourth, fifth, etc.) roots use the fact that a root of n-th order can be represented as ^(1/n)
  6. Ex: cube root of 27: 27^(1/3); square root of 64 : 64^(1/2) or 64^(0.5)
Feb 26, 2010 | Texas Instruments TI-83 Plus Calculator
How do I cube root a number on my ti89 titanium calculator?
To find the cubed root of say...8, then you would type this into the calculator:
root(8,3)
Nov 02, 2009 | Texas Instruments TI-86 Calculator
Texas Instruments TI-30XA Calculator Logo
702 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
