Question about Maytag Dishwashers
We have a Maytag MDB7601AWW Dishwasher that is not filling with water. We've checked all the hoses and water is getting to the machine, just not in it. What do we do now?
    Sergeant:
    Champion:
  • 338 Answers
Just inside the dishwasher usually on the bottom right in the front is a mushroom shaped "float" lift it up and down a few times making sure it ends up in the down position. if you move it slowly you should hear some clicks. do that and try to run the dishwasher if that does not fix the issue then your going to have to get a meter and see if you have 120v to the fill valve when you start the dishwasher. if you have the 120v then replace the fill valve
Posted on Dec 04, 2008
Kenmore washer Model A107 is pouring water out from underneath
More then likely it is the dis-charge water from pump hose. But if ya got a new machine why not!
Feb 16, 2013 | Washing Machines
No water in dishwasher
I would suggest to check the information by clicking here if you are planning to DIY.
May 20, 2008 | Dishwashers
Maytag washing machine no water coming in
check water coming out of hoses. check on hot and cold fill. could be fill valve
Feb 09, 2013 | Maytag Legacy MAV208DAWW Top Load Washer
No water getting to dishwasher
First is to see if water is getting to the dishwasher.
Locate the fill hose which should be under the sink along side the dishwasher.
After shutting off the water, disconnect the hose and see if you have good water pressure into the fill hose by turning it back on into a bucket.
Let's say you do.
Now locate the valve at the dishwasher where that hose is connected to it.
That valve is usually under the dishwasher at the very rear, usually on the left.
That solenoid/valve has the fill hose, two wires, and a small (usually black) hose going from it up to the machine itself.
You'll need to see if that valve is getting electricity when it should be filling the machine.
There are two wires to the valve.
They should likely be getting 110 volts when the dishwasher is supposed to be filling.
If they are, the valve may be bad, if they are not, likely is a problen with the timer itself.
Be Blessed
Jan 23, 2013 | Dishwashers
When you turn on the dish washer it heats up but there is no water coming into the machine- quiet series 300
Hi
When the Dishwasher is not filling in, you'll need to check for the water inlet valve, the filter screen and the float switch/assembly. Also check for the float assembly inside the dishwasher. When water is filling your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages.
If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly.
Hope this helps... Please post back if you need more information.
Daniel
May 07, 2011 | Maytag Dishwashers
Dishwasher runs but gets no water...
Hi
If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. Hope this helps... Please post back for any further assistance.
Daniel
Jan 31, 2011 | Maytag 24 in. MDB5651A Built-in Dishwasher
The dishwasher goes through the cycles but will not fill with water on some cycles.
Hi
If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don't get any value on the multimeter hen you'll need to replace the water inlet valve assembly.
Daniel
Oct 20, 2010 | Maytag 24 in. MDB5600A Jetclean II...
Maytag MDB7601AWW door will not latch
possibly need a new door latch assembly this is kind common on those maytags the latch assembly becomes defective or doesnt latch properly...W10130694 is the part number for the replacement part u would need you can see a pic of this part at repairclinic.com just enter the part number. you could purchase it there or online thorugh sears or etc... also check local they might stock at and be cheaper with no frieght shipping charges......to change this or check your assembly prob have to remove all screws from inside door usually a torx bit this will seperate panels and control will pop off.. hope this helps
Feb 06, 2010 | Maytag 24 in. MDB7601A Free-Standing...
Maytag dishwasher quiet series 400. Dishes have hard stuck on grit and food particles after rinsed and dried.
Very common problem is soap build up in these machines. Try putting it into a wash cycle with no dishes, and no soap. Let it wash for about 5 minutes, and then open the door. If you see alot of soap suds, then soap build up is the problem. Try doing a couple loads with no soap, and no dishes, and throw a cup of vinegar into the machine halfway through the wash. Repeat as necessary. This should solve your problem.
Mar 14, 2009 | Dishwashers
Maytag portable dishwasher is not draining
try to clean the filter by taking off the bottom section of the water jet, it might be clogged, if that does not work, u got the same problem as me, it just wont drain. The pump is probably broken.
Dec 05, 2008 | Maytag MDB9600A Jetclean II Built-in...
Dishwashers Logo
187 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
