Question about RCA F27669 TV
Sound on (and good) Picture off
This issue just started in the last week or so. While watching TV after a considerable amount of time the picture goes out but the sound remains. It's as if I turned off the TV. After several minutes the picture comes back on. The vents are clear as best I can tell so I do not think it is over heating. Is a part failing? Is their a simple solution? I was hoping to keep the TV until analog broadcast signals have been taken back by the feds. I simply can not afford a new TV much less a HDTV flat which I really want at this time. Anyone; ideas/help.
  • 38 Answers
Check and resoldered the suspected loosen part. this could happen the TV may turn normal at first to turn on after few seconds it is getting heat the suspected loosen part may totally open. resoldered the board at the secondary area near around the flyback. good luck!!
Posted on Feb 12, 2007
    Sergeant:
  • 308 Answers
If you can solder and have good eyesight, you're in luck. That is a classic symptom of a bad solder connection leading to the base of the Horizontal output transistor, labeled Q14401 or possibly Q4401 on the printed circuit board. This transistor is mounted to a aluminum plate heat sink near the high voltage transformer with a red wire coming out of the top of it. First Unplug the set. You will then need to follow the circuit trace from the 'B' connection of that transistor back to a coil of wire labeled L14401 or L4401 and you will find that one of the two connections there will be loose. Resolder that and you should be all fixed up. You may also find a bad solder connection or two on the pins of the high voltage transformer. A good magnifier will definately help. Good Luck.
Posted on Feb 06, 2007
The tv has sound but no picture. For
LG LED TV has no picture (black screen) but still sound ...
www.tomsguide.com/answers/.../led-picture-black-screen-sound-fixed.ht...
My 32' LG LED TV has suddenly lost picture! The sound is all right but the Screen is pitch black. After switching it on the picture flashes for a second and then the screen goes completely black.
LCD Easy Fix (sound but no picture) - YouTube
? 4:52
https://www.youtube.com/watch?v=IBRE1Dcyxp4
Jan 13, 2012 - Uploaded by Clay Whitehead
TV Has Sound But No Picture Troubleshooting Guide - Duration: 2:30. by Repair.com 472,733 views. 2:30. LG LCD TV REPAIR -NO PICTURE ...
Dec 21, 2015 | LG 47LN5400 47" LED TV 1920x1080, 120 Hz....
Please help diagnose problem with Panasonic TH-50PC77U Plasma HDTV
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 31, 2015 | Panasonic TH-50PC77U 50 in. Plasma TV
Hi, I have a plasma 42inches TC-p42gt25, I have
sounds like bad capacitors on the power supply board
Len..
Oct 13, 2014 | Televison & Video
No picture, has sound. Black screen with green lines.
Probably a power supply issue in a 7-year-old TV
Feb 13, 2014 | Sharp LC Televison & Video
Viewsonic N3252W picture ok but no sound
Download the repair book to this TV by net. It will have all details.
May 23, 2012 | ViewSonic N3252w 32 in. LCD Television
Three-year old 47" Samsung LCD. At first, some pixelation, usually correctable by turning TV off then on again. This situation lasted months, getting slightly more frequent each week. More recently, the TV...
1. the motherboard might be bad and you will need to replace it. 2. or The power supply is bad
Chances are if its making clicks the power supply is bad and you will need to replace it. Which makes sense because constantly powering the tv on and off will damage the power supply or possibly short out your motherboard. These things usually cost about 200 bucks to fix at a local tv repair store.
Sep 02, 2010 | Samsung LN-T4671F 46 in. LCD Television
I have a samsung model hlr4667wx/xaa picture freezes
analog board can cause that symptom especially if the pic is freezing .
Jun 26, 2010 | Televison & Video
Picture goes off and on...
Most likely your Cathode Ray Tube or CRT is going bad. That model number reflects an older TV. What you are describing is a fairly common problem for that television. If you bump the TV and it improves or gets worse then you know there may be a short.. Either way, I would recommend that you use our Premium Service or use our online resources to find a repair person near you. Good luck.
Jun 20, 2008 | Sony KV-32V16 TV
RCA 37'' has sound but no picture
1)confirm service # on back of tv 2)Is sound from tv or surround system? 3)suspect bad flyback xformer.
Sep 01, 2007 | RCA F36665 36" TV
RCA F27669 TV Logo
42 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
