Question about Home
Only 3 of 6 jets in jacuzzi tub working
When turning on the tub only 3 of 6 jets are working, 2 of them feel like they are trying to work. suggestions?
  • 4 more comments
  • Anonymous Feb 16, 2009
    I ran all 4 jets to clean, then drained the tub, filled with cold water, pushed the power button and I could hear the motor but jets would not work. I waited a couple of hours, and still nothing. Tried next day and still nothing. Filling with cold water was to rinse the cleaning solution. It has worked in the past but now is not. Thanks!
  • dccrossland Feb 16, 2009
    #3 of the 6 jets do not blow air, and furthermore, the air intake on that side actually drips water out. Can this be due to uneven pressure from one side to the other? The hose from the pump is much longer (3 feet) on the problem side of the tub.
  • Anonymous Apr 15, 2009
    2 on the same side of my 6 jet whirlpool tub are not working. I tried turning them clockwise to open them like the aquaglass website suggested, but they are still not pumping.
  • Anonymous Apr 27, 2009
    how to clean jets.
  • phil_m7 May 11, 2010
    Is the tub new? Have the jets worked before?
    At your service, Phil
  • Anonymous Mar 23, 2014
    we have a jet tub but the switch keeps shutting on and off
    Problem Solver:
  • 7 Answers
Make sure the jets themselves are fully opened. Some models you can turn individual jets on & off
Posted on Dec 12, 2008
My new jacuzzi 6 jet tub is only working on one side. What could cause that?
Probably control panel or if there are separate pumps for each side, that side's pump probably doesn't have a relay working with bad switch from the control panel.
Mar 31, 2015 | Whirlpool Jacuzzi Bath Tub with Jets
When I push the button on my american standard jacuzzi tub I hear the hum of the motor but jets don't come on
In my case I took the motor out and used a screw driver to turn the impeller in the front of the pump and the fins inthe back. Put it back together and it worked. I then used 2 tablesoons of dishwashing detergent and 1/2 cup bleach and ran it for 20 minutes to clean and degrease the impellers
Jun 30, 2012 | Jacuzzi Fuzion Whirlpool
One of the jet assemblies on my Jacuzzi 325 hot tub popped out and I can't get it to stay back in. i've been pushing it in as hard as I can but when I turn the pumps on it pops back out. Should I be...
once a jet face has fallen out of a hot tub that means the insert has failed and is broken. you will need to locate a new jet insert. Jet inserts have little tabs on them that hold them in place and when they get worn out the jet face will fall out into the tub.
Jan 29, 2011 | Jacuzzi Home
I have a new Jacuzzi tub with a Rapid In-Line Heater. When I fill the tub the water the initial temp is 67 degrees. The heater only increases the temp to 71 degrees. What is wrong with the heater ,if...
The bath heater you have is not designed to HEAT water - they only Maintain what you start with.
You need to start the bathtub with the hot water you want. It will only heat about 1-2 degrees an hour.
Jan 08, 2011 | Jacuzzi RapidHeat In-Line Heater U395000 [...
1 set of 4 jets won't work properly?Jacuzzi 6 place tub any solutions?
check the face of the jet trim to make sure it is turned on. most jets today turn clockwise and counter clockwise to turn the water on/off on each jet.
Feb 27, 2010 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Whirlpool Jacuzzi with 10 jets one stopped working.
either one of ur hoses has come off or is stopped up get to the sides and see if one has come off
Feb 24, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
We have a new Jacuzzi tub and went to turn it on
check to make sure the pumps on and that its wired correctly and that all valves are open.
Feb 22, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
I have a jacuzzi corner tub. The control panel
I would expect there is a Jacuzzi dealer in your town and I would guess he has parts. If you purchase parts locally, not only are you helping your neighbor but also, you will have the opportunity to pick his brain on tips to install.
Thanks for your interest in FixYa.com.
Feb 20, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Some jets dont work
jets don't 'clog' - turn the face of the jet nozzle - it is perhaps an adjustable jet you have that has been turned off.
Apr 18, 2009 | Home
Suddenly whirlpool action in jacuzzi tub very low
Try turning the jets clockwise while they are running and see if this makes a difference.
Jan 18, 2009 | Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner...
Home Logo
1,492 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
