Question about HP LaserJet 3055 All-In-One Printer
How can send fax thru internet
Hp laserjet 3055 printer sending fax via internet(not my office I can use fax my sending fax thru office printer hp3055 use)
  • 386 Answers
You can not send faxes thru the internet unless you use a service such as E-Fax.
Faxes usually are sent via phone lines only.
If you are asking anything else then you have to be more precise in your question as it is not exactly clear as to what you are asking!
Good Luck!
Rich Lilja
Posted on Dec 04, 2008
HP 3055 All In One laserjet prints all black pages
Odds are that you have a bad toner cartridge; especially common when using remanufactured cartridges. (Staples, Corporate Express, etc.) Replace your cartridge with an OEM HP cartridge and you should be OK.
Feb 22, 2010 | HP LaserJet 3055 All-In-One Printer
How do i change the number of rings before fax
Menu/Fax Setup/Enter/Fax Receive Set up/Enter/Rings to Answer
Feb 03, 2010 | HP LaserJet 3055 All-In-One Printer
HOW TO SET FAX IN HP LESERJET PRINTER 3055
Pages 67 thru 117 covers all fax functions and features of your HP Laserjet 3055 in this users guide. Hope this helps.
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00495173/c00495173.pdf
Oct 24, 2009 | HP LaserJet 3055 All-In-One Printer
Fax issue with HP Laserjet 3055
Hi. The fax-module in lj 3055 needs a 100% analog dial tone. You might get it working on a internet-phone-line, but HP garantees nothing because there are so many internet-phone-providers, and all of them operates with different specs and line-quality. You might try to lower the baud rate, turn off JBIG compession and error-correction. If the problem still remains, you need to replace your phone-line to a 100% analog line. Not any internet or ISDN/adapter-stuff. You should test your fax on any analog line at a friends house, just to make sure the fax i working anway.
Jul 27, 2009 | HP LaserJet 3050 Printer
3055 fax not working, sendng or receiving directly
Below is a link to an HP tech site. They helped me with MY hp all-in-one. It turned out I needed to download a different driver from HP's tech website (the download is free) and that is probably what you will be doing, also. God luck.
Jul 08, 2009 | HP LaserJet 3055 All-In-One Printer
I can send a fax, but not receive one.
re-install your 3055. check for the manual on HP website. download it.
plus you may need a filter on your phone...fax boards are very sensitive to online static.
Jul 03, 2009 | HP LaserJet 3055 All-In-One Printer
Can't read fax that is being sent
tell those people to wear their eye glasses...hahaha..
May 09, 2009 | HP LaserJet 3055 All-In-One Printer
Someone is faxing me iam getting commerror283 how to fix it
This error typically indicates a problem with the line. Sometimes it's caused by noise (like from DSL on the same line, or alarm systems/home automation systems that use the same line).
Try other devices on the line, like a standard phone or modem and see if you can detect the noise issues. You may need to order a separate POTS line for faxing, especially if you are using the aforementioned services or VoIP systems.
Hope this helps!
Mar 29, 2009 | HP LaserJet 3055 All-In-One Printer
Printer can't send or receive faxes
Same problem here - I got it work:
- Error Correction: off
- V34: off
(both Menu -> Fax-Setup - All Faxes)
- detect-dial-tone: off
(Menu -> Fax Setup - Fax Send setup - detect dial tone)
:-) Stefan
Aug 30, 2008 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3055 All-In-One Printer Logo
167 people viewed this question
Seeker5211
Seeker5211
