Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
I have a Cruzer Micro 1GB and the light does not come on, and is not detected when I insert it in a USb port. I accidentally pulled it out of my laptop about two weeks ago and have not been able to use since then. What do you suggest?
  • yukki cross Dec 06, 2008
    i have a micro cruzer 2.0 gb it stopped working this week after i pulled it out my computer a few days ago and since then the light would not show up on the usb and the computer could not detect it.
  • 827 Answers
You have to Safely Remove the drive before you take it out.
Try right clicking and formatting it.
Try downloading the U3 driver, if you haven't already.
First plugin the sandisk to your usb port, and then check from WindowsExplorer, does your sandisk cruzer detected? you'll get a new driveletter besides your local drive or named "removable disk".
If you do see it then just do format (you'll lose the U3), copy, store, overwrite it again and again as you like.
If you still need the U3 application, pls read this:
http://www.u3.com/support/default.aspx#CQ1
You possibly have to reinstall the driver properly.
If a wizard that comes up as soon as you plug the devicein, Just let it detect the device and then go to Control Panel, and System,and Device Manager, and double click on the devicedriver, or if it isn't there, double click on the unknown device withthe yellow exclamation mark and hit the Driver tab, Install Driver, andchoose the 'Let me choose the driver' option, and navigate to where youunzipped that driver you downloaded to, and click on the driver, wait forit to finish installing and reboot.
Let me know how you get on..
Good Luck!
Chris (ziraffa)
Posted on Dec 26, 2008
How to reformat a flash drive
Hi jabbbbbb6,
The Cruzer Micro is a flash storage device that connects to your computer's USB port. It comes in various sizes and fits on a keychain. If you want to erase the drive, you can perform a reformat from within Windows' Disk Management utility. After you reformat the drive, you do not need to reinstall any drivers because Windows automatically detects the device.
To Reformat, please follow the instructions:
1. Insert the Cruzer Micro to an available USB port on your computer. Right-click "Computer" and select "Manage." Click "Disk Management" under "Storage" on the left pane of the window.
2. Right-click your USB drive on the list of drives and select "Format." Select a name and file system type for your drive.
3. Click "OK" to reformat the drive. Click "Start" and "Computer" to access your drive.
Rate this accordingly.
Hope it helps.
Thank you for using Fixya.
Oct 06, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
When i plug my 4g cruzer micro usb memory stick nothing happens the cpmuter dosnt read that it is plugged in
Try a different USB device on each of the USB ports on your computer.
Hopefully, all your USB ports are working correctly.
Try a different USB port on your computer.
Hopefully, the SanDisk will be detected on one of the ports.
Try a USB port on a different computer.
If the SanDisk still is not detected, then spend $10 to buy a new 4GB flash-drive.
May 22, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
My 1gb cruzer usb device is not responding on my laptop but is on my parent computer what would i do
If it does not work on your laptop, what error-messages do you get?
Does some other USB device work in the USB port on the laptop?
Do you have more than one USB port on your laptop?
Do any USB devices work in any USB ports on your laptop?
Dec 18, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
PC is not detecting my Cruzer micro pendrive but
I have experienced this type of problem before. But what I did was to install an Avira Anti-virus on a system using windows xp and eventually it did open.
So you can try it as well or insert your flash into any another system that had a strong anti-virus which can enable you scan/format the drive.
Best of Luck
Nov 06, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
San Disk Micro Cruzer 4GB
Try plugging it in to a different USB port on your computer. Make sure the connecter on the Cruzer is clean and there's no dust inside.
Also, try plugging it in on a different computer.
If none of these work,
I'm afraid it's a hardware problem and there's nothing that can be done about that.
Hope I helped!
Tom
Jun 20, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
1gb cruzer micro
This is caused by 1 of 2 problems:
  1. Your flash drive is corrupted in some way, forcing the computer to reformat it before you can use it.
  2. The flash drive was formatted for a specific device (like a piano) and was made only for that device.
  3. Your PC incorrectly recognized it
  4. You do not have the correct drivers installed.
If you have problem #4, you can go onto google and search "1 gb cruzer micro drivers".
If you have problem #3, try plugging your flash drive into a different USB port.
If you have problem #2 or #1 (Which it most likely is), then you should try or buy a software application such as PC Inspector, to recover those files. Then you may reformat the flash drive.
However, I found that sometimes, just restarting the computer, and inserting and re-inserting the flash drive sometimes does work. But that's not guaranteed.
Feb 05, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
2gb micro cruzer causing the pc to restart
Do you have another USB device which you can use to check if it will come up with the same problem? There are 3 things which could cause it to freeze and restart. It could be a problem with the software device driver needed to detect the USB micro cruzer, the USB port itself or it's the USB micro cruzer. One good thing worth to try is plugging your USB micro cruzer on another computer to check if the problem will also occur there. If it does, then it's isolated to the USB device. If there's no other computer available, 1) Try to run an anti-virus and anti-spyware scan on your computer, 2) start up your computer on safe mode and try to check if it'll occur there as well. 3) If it doesn't occur under safe mode and your able to access your USB device, try to run an anti-virus and anti-spyware scan on your USB device to check for problems there. 4) If all else fails, then it could be a problem with the USB device. hope this helps.
Jan 02, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Untitled
I'm guessing you are using a Mac, so you will need a friend's computer with Windows XP or later. Go here for the U3 Launchpad Removal Tool, or Google 'sandisk u3 removal'. The CD image is a hidden partition used by the U3 LaunchPad.
Nov 27, 2007 | SanDisk 1GB Cruzer Titanium USB Flash...
USB drive not working properly
May be you should Re-install your USB Drive, use USB installer and re-install it!
Jan 25, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
110 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
