Question about HP PSC 1210 All-In-One InkJet Printer
Can't print to the edge of the page
Hi. I am trying to print an image which covers the entire A4 page. The image stretching to all edges of the page. But when I try to print it on my hp psc 1210, it clips my image so that the full image is not printed but there is a boarder of white around the page. How can I print my image over the entirity of the page? Without any white boarders?
The program I am using to print my image is Adobe Photoshop. But I have also tried other programs such as microsoft word and paint. I don't mind which program I use, as long as it prints my full image to the edges of the page!!
Pls help me, Thanks,
Shell.
    Guru:
  • 1,049 Answers
I don't know many inkjet printers that can print to the edge of the page on all four sides. The area in which the rollers feed the paper often can't be printed to and neither can the very bottom.
Posted on Dec 09, 2008
How to do borderless printing on HP laserjet 1022n?
the hp 1022 is not capable of printing edge to edge for that matter very very VERY few can. the problem is that the printer needs to be able to move the paper through the machine without distorting the printed image and this requires a LEAD EDGE usually about 3-5mm edge to edge down the long side of the paper the printer is able to get quite close to edge at 2-3mm either side but NOT EDGE to EDGE the only real way of accomplishing true edge to edge is to overprint and trim the final page to size.e.g. print on A3 and cut to A4
Jan 29, 2014 | HP LaserJet 1022n Printer
Can I print to the edge with Phaser 7400
No this is phisically impossible, try a larger sheet of paper and cut it
Mar 17, 2013 | Xerox Phaser 7400DN Laser Printer
Error Message: load the correct paper cassette: A4
check under printer driver, paper size.Usually the default paper size iz ltr. change it to A4 if you wana print on A4.
Jul 22, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
My printer won't print on a full scale.. meaning
this has to be set from the wizard for the printing job ...look for the edges size..but when you print on paper ..something like a full size A4 image ...it will always leave a 5 mm edge as default setting ..But like I said..initiate printing ..and in that wizard set the edge to 0 or ..click to remove edge if it is possible..anyway if it is possible there is the only location where you can change it ...and I'm not sure if it can be done permanently
Apr 29, 2010 | Office Equipment & Supplies
At college we have a w7200, how can we print across the paper rather than down it, for example a panoramic image across the width of the paper and say 20cm high
Try selecting LANDSCAPE as opposed to PORTRAIT by using the proper print menu in your application rather than the simple print icon from most tool-bars.
You can usually find it in the FILE menus
Apr 20, 2010 | Canon imagePROGRAF W7200 InkJet Printer
Hannspree HF229H monitor and Windows XP. Images stretch to fit.
I had this same issue.
Go into the monitors menu, go down to "Image Settings", go to "HDMI Mode", select "PC Mode"
Hope this fixes it for you. It worked for me.
Feb 16, 2009 | Hannspree 22" widescreen LCD Flat Panel HD...
Cannot fill a3 sheet
Have you set up the page as A3? If so, should be ok if you set the printer paper size to A3. If you set up the page on A4 you will need to tell the the printer to 'scale to A3' and it's best to say you want to preview before printing
Jan 31, 2009 | Canon PIXMA iX4000 InkJet Photo Printer
MP600 with Mac OS X - no borderless printing option?
I had the same question. I found the answer at Canon's site but I can't link directly to the page so here's how I found the solution...
1. Go to the Canon Support site. 2. In the "Please enter your question field" type: How do I Print edge to edge? 3. Hit the "Search" button. 4. Click the #1 (top) search result "How do I Print edge to edge?" 5. Click the #1 (top) solution: "Use Borderless Printing (Mac OS X) MP600 6. Follow the directions.
It seems the main thing you need to do is go to the "Page Setup" dialog. Then make sure you've chosen the MP600 in the "Format for:" popup menu. Finally, in the "Paper Size:" popup, select "A4" then "A4 (borderless). It's a hierarchical menu.
FWIW I still haven't gotten a "perfect" borderless print. Seems you gotta get the paper in there exactly straight...
Jan 02, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Prints black vertical line at bottom of page on every print. HP 8550gn
This should help -
Developer streak
Developer streak is characterized by a line of dark or missing toner
that stretches from the leading edge to the trailing edge. Replace the
toner cartridge corresponding to the color of the developer streak (for
example, if the streak is magenta, replace the magenta toner
cartridge).
Repetitive defects troubleshooting
Repetitive defects are defects that occur in the same vertical position
on the page, but not necessarily on every page. Most repetitive
defects are caused by problems with one of the following, and are
indicated by the positioning of the defect on the page:
 developer roller (at 38 mm)
 charging roller (at 44 mm)—see additional information under
“Charge roller set” on page 454.
 cleaning roller (at 56 mm)
 developer DSD wheels (at 65 mm)
 transfer roller (at 66 mm)
 transfer drum (occurs once per 11-by-17 inch or A3-sized page,
or every other letter- or A4-sized page)
 fuser (at 150.5 mm)
 imaging drum (at 195 mm)
 transfer belt (at 222 mm)
May 21, 2008 | Office Equipment & Supplies
Print margins too large on Xerox DocuColor 12 - How do I reset?
Not sure this is what your needing but ,,
The Edge Erase default setting is No Erase, which enables the copies to print within 2 mm of each page edge. This is normally sufficient to remove shadows from the edges. If the dark edge is closer than 2 mm, you must set Edge Erase at Variable Erase.
The Variable Erase option enables the copier / printer to vary the amount of erasure from 0 to 50 mm in 1 mm increments. The same amount of erasure is applied to both top and bottom edges or right and left edges of the document.
  1. Select [Edge Erase] on the Added Features tab. The Edge Erase screen is displayed.
  2. Select [Variable Erase]. The Variable Erase screen is displayed.
  3. Under Top & Bottom Edges, use the [Up] arrow to increase the amount of erasure at the top and bottom edges. Use the [Down] arrow to decrease the amount of erasure at the top and bottom edges.
  4. Under Left & Right Edges, use the [Up] arrow to increase the amount of erasure at the left and right edges. Use the [Down] arrow to decrease the amount of erasure at the left and right edges.
  5. Under Original Orientation select the page orientation that most closely resembles the orientation of the document on the Document Glass.
  6. Select [Save]. The Edge Erase screen is displayed.
  7. Select [Save]. The Added Features tab is displayed and shows the new Edge Erase values.
Feb 05, 2008 | Xerox DocuColor 12 Printer
HP PSC 1210 All-In-One InkJet Printer Logo
285 people viewed this question
Seeker5211
Seeker5211
