Question about Frigidaire FES367 Electric Kitchen Range
At a loss
Help! When my wife was cooking dinner tonight, all of the eyes on our stove quit heating. Suddenly the clock went out. We turned the power off and I reset the circuit breaker to the range. The clock stayed off, but when we turned one of the eyes back on, the oven buzzed and the power came back on. Still no action from the eyes. When we turned the eye off, the power went back out. after letting it alone for a moment, the oven buzzed again and apparently reset itself. I cycled through the same functions, i.e. using the eyes etc. Same problem exists. Hope somebody's got a clue!
    Scholar:
  • 76 Answers
Gluehead Most likely it is a problem with the power supply. It suppose to come two hot (120V) lines to your range and looks like one of them is missing. I would reccomend you to call an electrician to check both circuit breakers and the power from the wall outlet. Gendos...post back
Posted on Feb 06, 2007
SOURCE:
What's wrong and how do I fix it?
The circuit breaker outside in the power panel for the stove has a bad breaker. It will be two breakers with their handles joined together by a pin so if one tripe it takes the other so 220 V is no longer present. When one, but not the other trips you only have 110 V. That's why the lights and clock still work but no heating elements.
Nov 16, 2015 | Frigidaire Kitchen Ranges
Stove control panel not working
You do not have a fuse or overload button on a Maytag cook-top. If you heard a pop, it was the touch pad on your control board blowing out.
Oct 22, 2009 | Kitchen Ranges
All 4 burners stopped working - circuit breaker ok
How old is this cook top stove? Does it require replacement?
Jun 11, 2017 | GE 30 in. JP385 Electric Cooktop
Amana Electric Stove Error Message Probelm. PLEASE RESPOND!!!
  • push and hold the clock button for 3 seconds
Mar 10, 2008 | Kitchen Ranges
Kenmore Electric Self Cleaning Stove 790.95660103 Oven On All The Time
There is a relay in the electronic control of your range that is stuck closed causing power to be applied to the element continuously. The relay is an integrated part of the control and isn't replaceable.. The repair would be to replace the electronic control(clock).
Feb 24, 2018 | Kenmore Ovens
Amana gas range ARGS7650 oven not working, stove top working
check clock has not accidently been switched to Auto this can also happen if someone has interupted the power supply
Dec 25, 2007 | Kitchen Ranges
Electric Heating Element Not Heating stove
It's not a fuse, but a wire or heating element has burned up. Please TURN OFF the circuit breaker until you repair the problem, or at least until you know what the problem is! You say "in" the stove, so I'm assuming that you mean in the oven. Whichever element it is, whether it's in the oven or on the stovetop, just needs to be removed and checked for continuity with an ohmmeter. Quite frankly, if it IS an element, then you should see a burned-out spot somewhere on it that's pretty obvious. Then you just need to replace the element. If it's a wire, then you will need to repair the wire so that it safely makes contact with the element again. That process is a little more involved than just replacing an element, but let us know what you find. I can describe a wire-repair procedure if need be. ;)
Aug 13, 2007 | Dacor Epicure ERD30 Dual Fuel (Electric...
Stove/oven gets hot then shuts off
Shut the breaker off! These are the exact symptoms that a tenant of ours reported for their range. I went to check the range and found that one of the power wires on the terminal block in the back of the range was burning itself up. It had actually started a small wire fire. You need to pull the range out of it's hole and unplug it. Remove the panel in the back above where the cable goes into the range. Examine the power wires and terminal block carefully, because I bet you'll find one of the wires is burning up and needs to be repaired. Please write back and let know what you find.
Aug 09, 2007 | Frigidaire FES367 Electric Kitchen Range
Frigidaire FES367 Electric Kitchen Range Logo
242 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Marvin
Marvin
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
