Question about Lexmark X8350 All-In-One InkJet Printer
I refilled the ink cartridge in my Lexmark x8350 all in one printer and the cartridge won't align. I've cleaned the cartridge repeatedly. What do I do next?
  • 33 Answers
If white lines are present in the alignment page, then try this, warm some bottled water on the stove or microwave untill it almost boils. Then pour the water about a quarter of an inch deep in a plastic clean cup, place the printhead section of the cartridge, (the part that the ink sprays out of), in the water and let set for about 5 to 10 minutes. When you remove the cartridge from the water, dab it several times on a lint free paper towel or an old cotton cloth, DO NOT RUB or touch the printhead with your fingers or anything else. Then using a cotton swab dampened in rubbing alcohol, clean the shiney electrical contacts on the cartridge and where they touch in the machine. If you still cant align, then probably its time to replace the cartridge. You can only refill so many times before the printing elements burn out with usage.
Hope this helps,
Printdoctor
Posted on Jan 04, 2009
Refilled ink printer. still shows empty on the printer,s screen
Lexmark does not recommend the use of refilled/remanufactured cartridges. These tend to degrade print quality and printer/cartridge performance.
Please note that once a cartridge is refilled, it can no longer register its ink level.
Sep 13, 2011 | Lexmark X8350 All-In-One InkJet Printer
I have try to print but its not printing. i've allready fill the ink still the page come out blank.
It could be due to the refilled cartridge that you are using. Refilled cartridges tend to degrade print quality and cartridge performance.
You can try to clean the cartridge nozzles. Please follow the steps below to fix the problem:
  1. On the printer control panel, press Copy.
  2. Press Options until Maintenance is highlighted.
  3. Press the right arrow until Align Cartridges or Clean Cartridges appears, and then press Select. A test page will then be printed forcing ink through the cartridge nozzles and clean them.
Try to print your document again to verify that the cartridges are working.
If that doesn't help, I would suggest you replace your cartridges with new genuine Lexmark cartridges.
Aug 17, 2011 | Lexmark X6150 All-In-One InkJet Printer
Alignment problem. just refilled black ink cartridge..seeing message that printer is not aligned and remove tape from cartridge, but i see no tape
1) remove the cartridge and check it is not leaking. If it is, the printhead area on cart will be flooded with ink. Removing couple of ml from cart will stop it leaking.
2) If the cart looks clean (not leaking), stamp the printhead on some folded tissue paper or paper towell. It should leave a solid black stripe about 10mm long on the tissue. If it doesn't, your refill ink hasn't quite reached the printhead. You can blow little air into the breather hole (on top) to prime the printhead. Stop blowing when ink starts leaking at the printhead.
Clean the cartridge up before installing it.
3) If all above is ok and it still doesn't align properly, repeat above steps with the colour cartridge. The printer needs all colours working to perform the alignment process.
good luck with it
LC1000
www.inkbank.com.au
Dec 10, 2010 | Lexmark X7350 All-In-One Printer
Had the cartridge filled instead of buying a new one. I was told at costco that the printer sometimes shows low ink when it's filled to check the manual there is an option that needs to be changed. I...
Some menus on the X8310 and X8350 are repeated in the Copy Mode, Scan Mode, Fax Mode and Photo Card menus.
If you press the Menu button while in any of the above menus, two ancillary menus will be listed, Maintenance and Device Defaults.
To select either of these menus, press the check mark pattlnk_442006_155-selects.gif at the center of the navigation keys on the printer.
Maintenance Menu options View Ink Levels Clean Cartridges Align Cartridges Print Test Page Reset Defaults
Device Defaults Menu options Set Date and Time Language Country Copy Paper Photo Paper Photo Size Button Beep Power Save Timeout Caller ID Pattern
The ink levels should reset when the ink jet cartridge is installed
Another thing which is mentioned at their support site is quote:
If you have refilled the cartridges you got along with the printer, you can't reset them. 23 and 24 are not meant to be refilled. They are what Lexmark call "return program cartridges"- they can't be refilled, you can send them back to Lexmark ( that's why they are called "return cartridges"). You need to buy either 23A and 24A or 34 and 35, those cartridges are refillable.
Here is a link to Lexmark, with a list of cartridge compatibility for your printer:
http://lexmark-cartridges.com/cfv2/printer.php?lang=uk&partner=&productName=x3550
If you find my answer helpful, please vote. Thank you!
Nov 16, 2010 | Lexmark X8350 All-In-One InkJet Printer
How do I reset the ink level on my lexmark x8350?
http://support.lexmark.com/index?locale=en&segment=SUPPORT&startover=y&userlocale=EN_US&question=x8350+ink+level&productCode=LEXMARK_X8350&page=answers&detectedProductFacet=CMS-CATEGORY_REF.LEXMARK.PRODUCTS.ALLINONE.LEXMARK_X8350&searchid=1280474419390#1
The above is the description page for you Lexmark printer.
Solution
The ink levels should reset when the ink jet cartridge is installed.
Jul 30, 2010 | Lexmark X8350 All-In-One InkJet Printer
Refill inkcartridge 17 of lexmark x2250 don't work
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
Apr 28, 2009 | Lexmark X2500 All-In-One Printer
I just refilled black ink of my new printer Lexmark x5495. Does not recognise the black cartilage and keeps on asking for alignment. When it prints alignment page it does not use the refilled black ink....
Apr 10, 2009 | Lexmark X5470 All-In-One InkJet Printer
Lexmark X8350 jams (and other problems) after ink cartridge refill
You have a paper jammed in the path or there is something blocking the path, try to look inside carefully.
Apr 29, 2008 | Lexmark X8350 All-In-One InkJet Printer
X8350 lexmark cartridge refill
Carefully lift the tape sticker and there are three very small holes under, with a thin screw make them a little bigger and test with a pin the corresponding color and then inject 4 to 5 ml. of ink in each one, after that reapply the tape sticker.
Apr 25, 2008 | Lexmark X8350 Print, Scan, Copy and Fax...
Lexmark (Invalid cartridges)
That printer uses Lexmark 32,33,34,35 cartridges. The branded cartridges should work. Have you contacted Lexmark's technical support center? Contact information is on www.lexmark.com. They should be able to get you going again.
Mar 09, 2008 | Lexmark X8350 Print, Scan, Copy and Fax...
Lexmark X8350 All-In-One InkJet Printer Logo
228 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
