Question about E-Machines T2893 PC Desktop
Computer does not turn on at all
I checked the cable but its working ok, I need help to connect another just to see if that is bad our not!
  • 92 Answers
Hi you have many reson for this
1.- first thing to do check power button cable from your front pc if it's ok to check it onplug (power sw) and bypass it whit a screw driver (tournevis) if your pc turn on this is your problem
2.- change your power supply and try it again
3.- you have a big problem whit your mainboard sorry
good lock
Posted on Dec 04, 2008
    New Friend:
  • 50 Answers
Yeah that would be the best take the computer over to a friends house and hook it up to there monitor and see if it works on that one. if it does bam video card is bad. my suspicousion would be that it is video card. or try changing out cables.
My intel d946gzi lan not connected driver ok what can i do it
If the LAN driver is showing up ok as per the device manager then try these steps:
First with everything on (ISP modem and computer) open your browser and now look to see where the cable enters your network card. You should see one solid light and one flashing light.
If there is only the solid light, check to make sure the cable is pushed all the way in (or try another cable if you have one).
If that didn't work try this: Turn both your modem and computer off. Now, you need to try turning them both on at exactly the same time. Check to see if the network is now working.
Oct 04, 2014 | Intel Computers & Internet
Car wont start, but all lights work....Theres no turn over sounds at all, car simply wont even budge, but all signs of a bad battery are no there, all electrical things work.
SOUND LIKE FAULTY STARTER SOLENOID OR STARTER MAKE SURE BATTERY CABLES AND BATTERY POST TIGHT CLEAN TURN OFF RADIO FIRST BEFORE REMOVING BATTERY CABLES. TO KEEP FROM LOSING CODE. USE A MEMORY SAVER IN CIGARETTE LIGHTER BEFORE REMOVING BATTERY CABLE.BMW WARNING YOU BECAUSE YOU SHUT DOWN PCM VECHICLE HAS TO BE TOWED IN AND REPROGRAMED .IF ALL IS GOOD YOU COULD HAVE PROBLEM IN ELECTRONIC IMMOBILIZER CONTROL OR FAULT IN THE TRANSMISSION CONTROL UNIT.
Jan 31, 2011 | 1999 BMW 323 Series
Hi, every time i connect this to my home computer it turns it off! if i turn the computer on with it already connected it turns it off, have done initial set up on work computer and can access ok from...
sounds like your pc's usb socket has a problem, try the following...
1. Try a different usb port,
2. Using a small light (and possibly a magnifying glass) look inside the usb port on the pc for bent pins or distortion within the socket causing the pins to touch something they shouldn't.
3. check the usb cable for minor damage, try a different cable if you can, different machines use different ways of manufacturing sockets making some more sensitive to a damaged plug than others.
The pc turning off is a safety system which prevents power being sent through data ports. If the pc turns off immediately after inserting the usb cable then that's a sure sign that there is a bad connection/short somewhere between the socket and the cable.
Hope this helps.
Jan 16, 2011 | Verbatim 250GB USB Portable Hard Drive
My computer wont turn on
take out the psu completely from the cpu/tower, plug in the power cord,if there is a switch on the psu turn it on, next locate the main power connector (24pin) and find green wire,take a piece of wire and insert it into the green wire connector,next touch the other end of the wire to the psu outer case or a black wire on the main connector,if all is well the psu will turn on,if you have a dc voltage tester check the voltages on the red and black wires on molex connector...5vdc,yellow and black...12vdc.if ok look at the main board and inspect the capacitors to see if they are swollen, if ok
replace psu and disconnect hdd,cd/dvd,floppy ect from main board only leave memory,processor and video, power on if ok shut off and reconnect hdd, power on, if ok shutoff and connect floppy, if ok power off and connect cd/dvd drive.during this testing you will know what is bad.let me know how it turns out.email; arjoon.ken@gmail.com
Feb 19, 2010 | Computers & Internet
Starter problem i think
Sounds like a bad connection either battery or starter. Do the dash light's go out or dim when you turn the key to the starter possition if so check the battery cable conections for corrision. Check the cable coming from the battery to the starter for a loose or bad connection. Check the minus cable where it connects to the engine. As you are getting a click noise when you turn the key means that all other wiring is working as it should. If no loose connection and the battery is ok then you will need a starter. If you havent checked your battery get jumper cables and try to jump start it. If it starts with the jumper cables then all you need is a new battery to sort your problem.
Aug 10, 2009 | 2003 Suzuki Aerio
E-machine was working fine last night got up and it turns on but the monitor says check cable or power but all is ok.Computer wont display anything, can anyone help?
Do a reset: Turn the computer and monitor off. Unplug the monitor video cable from the computer and unplug the monitor power cord from the wall outlet. Let it sit for 5 or 10 minutes. Plug everything back in, turn on the monitor, then start the computer. Sometimes that will work.
If you still have the same problem, try to borrow a known to be good monitor from somebody. If it works, then you know your monitor is bad.
It's also possible that your video circuitry is bad. If the monitor plugs straight into the motherboard (onboard video), then you'll need to purchase a video card and install it. Disable the onboard video first.
Feb 25, 2009 | E-Machines (T2958) PC Desktop
White screen
ok here could be 2 problem
1 your computer done send video signal
2 cable it is bad
you should try first to other computer to see if work , if yes that means your computer it is with problem , if not work that mean your monitors dont receive signals
Dec 10, 2008 | Computers & Internet
I have a Lexmark 5400 seies printer and just purchased a HP Windows Visa PC. I am having problems connecting the printer. It keeps telling me that the USB is not connected. I have checked this out and it...
A couple of questions: Are you using an accout that has install rights? (ie. Administrator level account ) Are you seeing the UAC (user account control) prompts if you are are you clicking allow this software to run? Can you install other software? If these are true then
at this point try removing all printer software, then restart computer. Now turn on printer connect usb cable to printer then plug into a usb port on the computer, Do you get a "Found New Hardware" popup window? If so remove the cable from the computer and restart the computer. Now insert the cd that came with printer and follow the instructions for the software installation. If you don't see a "Found New Hardware"prompt then try a new usb cable, or try leaving the printer connected and turning the printer off for about a minute then back on. If this doesn't help try leaving it connected and re booting your machine also try different usb ports on your machine. If none of this helps you may have account permission issues or just bad hardware.
I would really need more info about your machine configuration if these tips don't help
Oct 14, 2008 | Computers & Internet
LAPTOP /no power
It states you are not getting no power on your lap top computer :
No power or computer does not turn on Cause: No power from the computer can be caused by any of the below possibilities.
  1. Connections not connected properly.
  2. Third-party hardware.
  3. Bad power cable.
  4. Incorrect power supply.
  5. Bad battery.
  6. Bad power supply, power button, and/or power board or inverter.
Solution: Note: If the computer is turning on but is not posting (beeping) or giving any type of picture on the display, please see document CH000607. If you are uncertain if the computer is turning on or not, this can be easily checked by locating any fans in the computer or visible from the outside of the computer. If these fans are spinning, the computer is receiving power and this document may not apply to your issue. Connections not connected properly Verify that the power connection is connected properly to the wall and the back of the computer. If the connections appear to be connected properly, attempt to disconnect and reconnection both ends of the cable. If you have a power strip (surge protector) or switch used to turn everything on at once, temporarily disconnect the computer from that switch and connect that cable directly to the wall. This will help verify that the strip or switch is not bad. Verify that the outlet works by connecting a different component to that switch.
Third-party hardware If additional hardware has been recently added to the computer it is recommend that you temporarily disconnect that device or devices from the computer to verify they are not preventing your computer from turning on. Note: If the computer was working fine before you added the new hardware, removing the third-party hardware did not resolve the issue, and the computer is not beeping but is turning on, please see our POST troubleshooting document CH000607.
Bad Power cable Verify that the cable supplying your computer is not bad or damaged by using another power cable. If you have a standard CRT monitor, this cable can be used in place of the computer power cable. If you have a portable computer or laptop, when the cables are plugged into the laptop you should see a power light or battery charge light. If this light is seen, this is a good indication that the power cable is good.
Incorrect power supply If you are building your own computer or if the computer has never turned on since you purchased it, it is possible you are using a power supply that does not supply enough power and/or the incorrect type of power supply. Verify your power supply meets the requirements of your motherboard and processor.
Bad battery If your computer is a laptop or portable computer that utilizes a battery for mobility it is possible that the battery may be causing your issue.
  • If your computer powers on when the cable is connected to the portable computer but not when it is disconnected, we recommend you purchase a new battery.
  • If your computer does not power on when the battery is connected and when the power cable / charger cable is connected, try removing the battery and seeing if the computer can power on with only the power cable connected. If no power is still received, skip to the final section.
Bad Power Supply, power button, and/or power board or inverter If, after following the above sections, your computer still receives no power, it is likely that a hardware component in the computer has failed. It is most likely that the power supply has failed. If you do not plan on replacing the power supply yourself or if you have a portable computer, we recommend having the computer serviced by your computer manufacturer or a local computer repair shop. If you have a desktop computer and plan on trying to repair the computer yourself, we recommend you replace the components in your computer in the below order.
  1. First open the computer and verify the power connections. You may also wish to consider disconnecting the main power cable and reconnecting the power cable to make sure it has not become loose. Also verify the power button cable is correctly connected to the Motherboard.
  2. Replace the power supply with a new power supply.
  3. Replace the motherboard.
Good Luck,Please dont for get to Vote,Thank You
Jan 17, 2008 | Toshiba Satellite M40-S417TD Notebook
Help on philips 30gb gogear jukebox
Need some more info, so have a few questions: Has it connected OK in the past or are you just recently connecting it to your computer? What kind of computer are you using? What is the operating system the computer runs? Did the cable come with the unit? Does the cable work on anything else OK?
Jun 07, 2007 | Philips HDD1630 MP3 Player
E-Machines T2893 PC Desktop Logo
65 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
