Question about Hitachi VTMX4510A S-VHS VCR
How to set the vcr to record
I have set connected the vcr to the cable and I set the menu options for the day and channel that i want it to record. But the vcr won't record the shows. I think that I have to have the auto timer turned on but i don't know how to do that. Please help! Thanks
  • 50 Answers
Hi I'm not familiar with your model in particular, but normally there will be a timer button on the remote that you must press, or you must turn the vcr off after programming it for the timer recordings to be made. There should be a timer indicator on the front, either a symbol or a red light depending on the age of the vcr. If you program it, then press the timer button on the remote, the timer light should be on and the vcr will shut itself off, if it is the other type, then the timer indicator should stay lit when you shut off the machine. If that light is on, then your timer recordings should work. Hope this helps, good luck!
Posted on May 01, 2007
I have a Goldstar VCR and I want to record a tv program using it. How do I do it?
Most Goldstar VCRs only have an analog tuner. (TVs do not often have an option to output their video to another device.)
So first what is the source of the TV program? If it is an OTA analog or CATV cable. Set up the VCR normally by connecting the incoming signal cable to the VCR and then use the coax out to the TV. Scan for channels and set the VCR to record the desired program. (Either use the timed record or one touch record method.)
If your source is digital, you will need a set top box (either a digital to analog converter or cable box). To split an incoming OTA signal between your TV and the converter box, you can use a switch or a splitter. (A splitter will give lower signal strength to both the TV and the converter box.)
Depending on the box, you can either connect a coax cable from the box to the VCR and then to the TV or composite video from the box to the VCR. If you use coax, set the converter to channel 3 or channel 4 and record that channel. Otherwise set the VCR to record Line 1.
To record, put in a tape with sufficient space available with an intact safety tab. For One Touch Recording, set the VCR to the desired channel and tape speed. Then press Rec. Press several time for a timed recording. For Timed recording, press Menu > Program. Press Select and move through the list to program day to record, the start/stop time, and channel, etc. When done, press Menu to save the setting. The timer light should come on (most VCRs will turn off).
I hope this helps.
Aug 05, 2011 | Goldstar GBV241 DVD Player/VCR
How can I receive and record cable channels on my Sony SLV 750 vcr? The tuner only displays channels 1-99 on the vcr. Thank you.
I will be assuming you have analog cable TV service, no cable box. If you have a cable box, the instructions would be different.
There are many steps to properly setup your Sony VCR and they should ALL be setup to correctly record channels, however just to cover your question here....
Press MENU on the remote control for the VCR and you should see on your TV screen, the main menu options. Select TUNER PRESET. Press OK. Set Antenna/Cable to CABLE. Next Select AUTO-PRESET. Available channels will be scanned. This may take a few mins. so be patient. Channels could go up to 125. This should make available cable channels ready to record/view.
You can ADD or Delete a specific channel also if one is missed or undesired by selecting MANUAL SET.
Feb 11, 2011 | Sony SLV-798HF VHS VCR
Lost manual. Cannot get HR A591U JVC VCR program to record a future cable tv program. Seems I have tried everything but it does not record as I set up. It will record an existing show by pressing...
Timer Recording JVC VCR HR A591U
Timer recording can be programmed on-screen with
the remote control. The built-in timer allows automatic
unattended recording of up to 8 programs within 1
month.
EXAMPLE: Program a timer recording for the 26th day,
channel 125 (CATV), 11:00 - 11:30 PM on timer program
number 1 (Tape speed: EP).
When a TV is connected with an audio/video cable, turn the
TV and this VCR on and select the video input mode on the
TV.
• After timer recording is completed, the VCR turns off
automatically.
• You can program the timer recording while a regular
recording is in progress; the menu screens will not be
recorded.
• The timer recording will start at 20 seconds before the time
you predetermined.
Press MENU on the Remote.
Check the “TIMER REC SET”
option is selected, then press
ENTER.
Press SET –/+ to select one of
the program lines, then press
ENTER.
Press SET –/+ to select the
date, then press ENTER.
Set the start time, end time,
channel and tape speed as in
step 3.
NOTE: To record from external
source, press SET –/+
and set the channel to
"L". "L" will appear next
to CH 125 (or 69).
To enter other programs,
repeat step 2 through 4. Or,
press MENU twice to return
to the normal screen.
Press TIMER on the Remote.
The power will go off, the
TIMER REC indicator ( ) will
light and the VCR stands by
for recording.
To cancel a program:
Press the SET –/+ to select the
“TIMER REC SET” option in the
MENU. Then press SET –/+ to
select the unnecessary program,
and press CANCEL to cancel the
program.
Aug 28, 2010 | JVC Televison & Video
Unable to view/record cable channels with Panasonic DMR EZ48V
Here is what you will need. This is assuming you do not have a HD cable box.
1) A two port cable splitter available at your local hardware or electronics store. VERY IMPORTANT- this splitter needs to pass up to 1000 mghz so you do not interfere with the functions of the cable box. Also, when purchasing this don't be fooled gold does not always equal good (a common mistake made by folks).
2) 1 small coax cable.
3) 3 Additional coax cables. (1 long enough to reach from the wall to the cable box. 1 long enough to reach from cable box to the TV. 1 long enough to reach from wall to the VCR. These cables should be RG6 coax cable (about the width of a standard wooden pencil)
4) 2 RCA cables (Yellow/Red/White)
Here is how you need to connect the cables....
1) Use the small coax cable and connect it from the WALL to the INPUT of the two way SPLITTER.
2) Use one of the coax cables and connect it to the OUTPUT of the SPLITTER. Connect the other end of this cable to the INPUT of the CABLE BOX.
3) Use one of the coax cables and connect it to the OUTPUT of the CABLE BOX to the INPUT of the TV.
4) Use one of the coax cables and connect it to the OUTPUT of the SPLITTER. Connect the other end of this cable to the INPUT of the VCR.
5) Use one of the RCA cables and connect to the DVD/VHS COMMON OUT on the VCR. Connect the other end of this cable to the VIDEO IN on the back of the TV.
6) Use the other RCA cable and connect it to the VIDEO OUT on the back of the CABLE BOX. Connect the other end to the IN 1 on the back of the VCR.
Here is how to set up the VCR-
1) Tune the TV to the video input that you connected the VCR to.
2) Go to the auto program in the menus for the VCR and select "CABLE" as the source and you should now be able to get all the channels you would normally get without the cable box.
3) This will give you the option to record shows from basic cable on the VCR. While copying these channels you will still be able to tune the TV to CH 3 for the cable box and watch TV normally through the cable box.
4) If you want to copy one of the channels that is only available with the cable box you will still be limited to only being able to watch that channel while it is recording but here is how you will do it.
  • Tune the CABLE BOX to the channel you want to record.
  • Tune the TV to the VIDEO INPUT you have the VCR connected to.
  • Select either VCR or DVR on the VCR.
  • Select recording mode.
  • Press the INPUT SELECT button.
  • Select IN 1.
  • Press RECORD.
Hope this has been helpful....
Good Luck....
Jan 19, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
How do I tape onto a vhs from analog tv with converter box?
There are 2 options-
Option 1
Connect the coax cables in the following order.
1 From the wall to the input of the converter box.
2. From the output of the converter box to the input of the VCR.
3. From the VCR to the TV input.
Here is how you record with this option.
1. Tune the converter box to the channel you wish to record.
2. Turn the channel on the VCR to channel 3 or program the VCR to record channel 3 this will record whatever channel you have your converter box set to at the time of the recording.
Option 2- (will not work on satellite)
1. From the wall to a 2 way splitter (made for digital cable. General rule of thumb with digital cable is gold does not usually mean good.)
2. One output from the splitter to the converter box and the other to the input of the VCR.
3. Connect an Audio Video (RCA (yellow/red/white cable)) from the VCR to the TV input.
4. Select the appropriate input on the TV for the VCR.
Here is how you record with option-
Tune the VCR to the channel you wish to record and push the record button or program the timer to record the channel and time that you wish.
Note- with this option you will only be able to record channels that you would receive without the converter box. Also each time that you split the cable line you loose part of your incoming signal and depending on how you house is set up this option could affect the quality of your digital signals on the converter box.
Jan 02, 2010 | Mitsubishi VS-55707 TV
Electronic ILLITERATE!!! - nothing recorded from cable tv channel
okay, if you have a cable box (cable out plug to dvd/vcr in), then from the dvd/vcr (cable out plug to tv/monitor). make sure tv/monitor and dvd/vcr are set to ch #3. you swith channels with the cable box ,you are not going to be able to record HBO on dvd (but you can with the vcr), any other cable ch(tnt, history, tbs,we, oxygen and more) is recordable w/ both dvd/vcr
no cable box. take cable wire plug to dvd/vcr in, than other wire is connected to tv/monitor
now go to dvd/vcr with remote, menu, set to catv, scan channels. now when you wish to look at tv the dvd/vcr must be on at all times. again you will not be able to record Premium ch like HBO
hope this help............pls feel free to rate
May 14, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Doesn't give me the option to change the channel when timer recording
If you are recording something on the VCR, it won't let you change the channel. If not, you need to make sure the RC is set to the vcr in question (mine has VCR1 and VCR2)
You can set it up the way I've done for years...put cable line into VCR first, the VCR to TV..you then can watch and record 2 separate channels.
May 09, 2009 | Proscan PSVR73 VHS VCR
How to program vcr to record digital channels?
Any VCR select to input source from where recording.
So select appropiate Euroscart or other AV connection.
Digital channel will be your digital cable set top box or sat receiver, DVD player, whatever. Very unlikely you use a digital capable set topbox to output to your VCR or TV with old fashioned RF coax cable where you have to tun in to cerain RF frequency under Channel 0 or so. So when in timer menu select that input source connection. Direct recording without timer select the source with remote. This solution applies to all brands
May 02, 2009 | Sansui VRDVD5000 DVD Recorder/VCR
Panasonic NV SJ205 changing RF settings
Your VCR has input to record video-audio signal. Here is 2 options to record program in vcr.
1= You need to hook up video-audio cable at Monitor Out in TV and video-audio in at VCR. select Line-1 or Line-2 (where you hook up cable) in vcr and insert cassette with Record Tab intact, VCR is ready to record TV program. select desired channel on tv and hit record button of vcr, recording will start.
2= Plug RF antenna / cable wire in RF In of vcr and tune desired channel in vcr (get help of vcr's user manual for that) and push record button to start record directly in vcr.
Have further query, let me know please.
bye.
Sep 09, 2008 | Panasonic NV-SJ205 VHS VCR
Owners manual
Turn on power to TV, and DVD/VCR, set TV to channel 3 or 4
Insert video cassette
Select desired channel by using CH/TRK
Set the desired recoring speed (SP or EP)
Press REC once
Press STOP to stop recording.
Timer Recording,
Press Menu and the Main menu will appear.
Use up and down arrows to choose the Timer record menu
Press Select/Enter to go to the Timer Record menu.
Use arrows to choose the program no. (1-8)
Use down arrow to choose Month option
Use arrows to choose the desired month
Use down arrow to choose the Day option
Use arrows to choose the desired day
Use down arrow to choose Start Option
Use arrows to choose the desired start time
Use down arrow to choose the Stop option
Use arrows to choose the desired stop time.
Use down arrow to choose the Channel option
Use arrows to choose the desired channel (Channel, Line1 or Line2)
Cable users: If you have Cable TV and used Cable Box in Connecting Antenna/Cable TV to DVD/VCR using a cable box converter, you must set the channel in this step to match the cable box output channel (usually 3 or 4). Change channels on the cable box instead of the DVD/VCR
Mar 15, 2008 | Sanyo DVW-5000 DVD Player/VCR
Hitachi VTMX4510A S-VHS VCR Logo
345 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
