Question about Akai LCT2715 27 in. LCD Television
Power Supply Board Problem?
I have had this unit for nearly two years, and haven't had any major problems with it. I almost never have used the built-in DVD player, instead using a separate DVD player that is connected to this unit.
It's probably a coincidence, but a few days ago, I clicked the eject button on the DVD player, and found a disc that had been inside for nearly a year. I popped in back in, and continued to used the TV, without using the DVD player. A day or two passed as I used the power ("Standby") button on the side to turn the TV off and on (instead of the remote.)
A couple of days ago, when I tried to turn the TV on, the screen remained dark, and the power indicator was flashing an orangish red. I then tried to use the remote, without any success.
I unplugged the unit for a couple of minutes, before trying to turn it on again, unsuccessfully, and then left it unplugged overnight before again trying to power in up, unsuccessfully.
I have tried to click the standby button after plugging it in, I have tried to hold down the button after plugging it in, I have been holding down the button before plugging it in, and I have held it down for over a minute. Nothing seems to work. At this point, given how many problems there have apparently been with this model after only a short time, it doesn't seem to make sense to invest $300 for a part that will probably quickly fail, also. At this point, I would settle for simply removing the DVD that's in the slot. I tried similar techniques with the disc eject button, also to no avail. On PCs, holding down control/alt/delete at the same time has an effect. I am just wondering if any combination of buttons on this model would do anything.
Out of frustration, with the unit unplugged, I even removed four screws and took off the plastic cover on the back of the DVD compartment, and tried to remove the DVD disc by grabbing the edge with a set of tweezers, I could get a pretty good grip, but it felt like the center of it might be on the spindle of the player that spins it, so I was not able to remove it.
Any suggestions? Again, at this point, I would settle for simply removing the disc (even if it might get a little scuffed in the process.)
Thank you.
call me at 801.664.5450
Note: I have already left you a voicemail on your phone. thanks.
    Problem Solver:
  • 8 Answers
The motor that spins the DVD, locks it magnetically to another free spinning disk... if you got that far, remove the dvd player part, flip it upside down, see if you can manually move some of the gears. you should be able to free the DVD enough to pull it out with the tweezers. if you can send a picture to s69joe@yahoo.com I might be able to point out what to move.
Posted on Dec 11, 2008
Vizio e420-a0 has no picture
the problem isnt in the power supply unit, put back the original power supply instead, check the heat section of the board where you can see the flyback section, verify the high voltage input by using the voltmeter , if high voltage is missing check all the capacitors and diodes near the highvoltage section, if blown replace it with the same value.
Nov 29, 2016 | Vizio Televison & Video
SAMSUNG PS42AS5 PLASMA TV POWER SUPPLY FAULT 470MFD CAPACITOR BLOWS NEAR POWER SUPPLY
First thing you should do is to invest in a really good surge protector for your TV. Then when you replace the capacitor again use a good capacitor. Cheaper is not always better. Rubycon seems to do the best for me. There may be other suggestions, however I have the best luck with them.
Apr 03, 2013 | Computers & Internet
Picture on my Toshiba 37RV753B has gone off and the standby light keeps flashing yellow. It was working ok a few hours ago, but I switched it off to go out and now it won't work. It's only just over a
Hello!
If you have used your TV 24/7 for the past year, the issue might be in the power supply. If there are "bloated" capacitors, set will not start up. If you haven't unplug it for a year, it might be staying alive. Once you unplugged the set, those capacitors won't let your set back to normal. That's a big project and requires technical background. If you think you can handle that, open your TV set and inspect TV's power supply board. It will be located near power cord plug or wire. Also, it might be covered by tin shield, which must be removed for further observation. If you see any "bloated" electrolytic capacitors, replace them with same value and voltage. But it might be main board's issue, as well. what is your place's ambient temperature? If it's lower, than 75F, try to warm up the back of the set, before even trying to poke it open. Use hair dryer. First, point it on main board's in/out connectors. Do not overheat! Few minutes might be enough. Then, try to plug the set in and observe the behavior. Any change? turns on? Main board is bad. Same with power supply. If heating up main board area does nothing, try power supply area. If it makes a difference, start looking for bad capacitors.
Good luck,
Let me know results.
Thanks,
Alex.
Dec 10, 2011 | Toshiba Televison & Video
Sharp dvd player does not come on even on standby although the power supply is on.
Pleasant day!
The problem could be the power supply or the main board.all you have to do is to follow this simple and easy way of troubleshooting.
  1. Remove the cover.
  2. Plug-in your DVD player and power it ON to perform a voltage data/check.
  3. Check the input power of the DVD.Use multimeter tester to test the AC voltage (AC range).It should have 120v or 240vac depends on the requirement of your DVD or the main supply that comes on the outlet.If no voltage reading,your power cord have a continuity problem.Replace it with the same type and A.W.G number standard.
  4. If the power cord got voltage reading.Next is test the output voltage of power supply such as 5vdc for the main board and logic supply using multimeter (DC range).If no voltage reading,the problem could be the power supply board.
Check the following parts which commonly breaks on power supply board.
  • The power transistors (regulators)-It is commonly binds on heat sink and found on the primary of the chopper.use a multimeter (range diode test) to check if it is shorted.
  • The fuse-able resistors-it is the resistor that have low resistance such as 1ohm 2.2 ohms etc.It is usually found near the power regulators/transistors.Use multimeter (range resistance) to check if it is open or change value.
  • The capacitors-it is the one who can store voltage.If you have capacitance meter you can test that,if none just look at the appearance of the capacitor if it is bulge on top or leak.
NOTE: If you found the defective parts that mention above,replace it with the same type and ratings.
When the problem is still there,The problem of the power supply is major and not for D.I.Y.I suggest to send it to the qualified technician or just buy a new one.
5. If the power supply have output voltage.The problem could be the main board and unfortunately the main board is not for D.I.Y because composition of the board is very sensitive.The only way to fix it is to buy a new main board unit.
I hope this solution could fix your problem.Please response if you have any comment and question.Thank you and good luck.
Apr 28, 2011 | Televison & Video
My Sharp LCD panel color TV. does not have any power supply. When I turn on the power button, its power indicator led from red to green for split second and completely turn off without any life. What...
Good day!
This are the steps to find and fix that problem.
  1. Open the cover of your TV.
  2. Disconnect the input supply of system board or main board that comes from the power supply unit.
  3. Power ON the TV to check the voltage reading of disconnected connector to the input of system board by using voltmeter.
  4. Check the 5vdc and 12vdc by using voltmeter.If you got voltage reading of 5vdc and 12vdc,try to connect the input connector of the system board and check the voltage again.If no voltage when you connect it.There's a shorted parts on your system board.Replace the whole system board because its very difficult and expensive to repair it.
  5. When the input voltage of system board doesn't have 5vdc and 12vdc even disconnected on the board.The problem is on power supply.
Check the following:
  • Fuse-Check the fuse if busted.
  • Transistor and diode-Check the transistor and diode if shorted.
  • Resistor-Check the resistor if open/change value.
  • Capacitor-Check the capacitor if leak/bulge on top.
If you found the defective parts that mention above.Replace it with the same type and ratings.
NOTE:If the following parts are OK and the problem is still there.The power supply have major problem and its not for D.I.Y..
Apr 25, 2011 | Sharp AQUOS LC-32D43U 32 in. LCD...
DV-585K (PIONEER), My player is not turning on. I've already check the cord, fuse and the switch and they are all good. What else could I check or is there any parts that needs to be replace if problem is...
The most common caused why your unit didn't power up was because of faulty power supply board. Since you've already checked the AC line, the fault now is quite technical if you haven't an experienced in electronics. The board must check the faulty parts like the fusible resistor in line with the shorted voltage regulator IC/transistor (mounted in heat sink), dried electrolytic filter capacitor, open/shorted chopper transformer, shorted diode. You must know how to test this parts to pinpoint where the fault came from. If you can't troubleshoot the board yourself, you may replaced it by inquiring to your local pioneer service center for the power supply board's availability.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Apr 24, 2011 | Televison & Video
No power to tv through power cord yes
good day
the problem of your unit is on the power supply...the power supply is the that gives supply to all of the board that TV have....
I give you some tips to perform a troubleshooting...this solution is for D.I.Y and simple trouble shooting only...if this is not successful the trouble of your power supply is major and its very difficult to repair..
so if that case happen I suggest to purchase a new power supply..
your power supply looks like this?
first,you have to remove the cover of your TV..
secondly,after you remove the cover..the power supply will reveal and remove it to perform trouble shooting by unscrewing it
thirdly,check the fuse..if busted replace it and check some shorted transistor and diode by using multimeter tester...
fourthly,also look for leak or bulging top capacitor..if found replace it..also check the open or change value resistor..
and finally if you found any defective parts test it by plug in the ac supply to your power supply unit and check the output voltage...if you got 5v,24,and 16vdc it means that your power supply is OK..and if not,your power supply got a major trouble..your option is to give it to the qualified technician or purchase the new one..
if you are purchase a new power supply I give you a web site to order..
http://www.electronica-usa.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=EU&Product_Code=FSP1943F01
thank you very much and good luck
Apr 10, 2011 | Protron PLTV3250 32 in. LCD Television
Green light flashing on back of unit near power cord also green light flashing on motherboard near power supply plug in.
I would suggest trying to replace the power supply. If that does not fix the issue, i would need to hear more about the computer.
May 06, 2009 | Sony VAIO VGC-RB40 PC Desktop
My DP885 will not turn on. Plugged in nothing happens.
And probably had a 90 day warranty?
The problem is surely with the power supply for the unit if it is completely dead.
If you still have the car adaptor at hand, try running it in a car. If it works there, then the major part of the set is OK and the problem limited to the power supply. Since the main supply is internal, there isn't a whole lot you can do on your own.
In many other systems (LCD TVs, for example) the supply is a separate board but it isn't likely to be this way in your player so the supply is probably part of the main board which is probably too expensive to replace or even repair.
If you decide to replace it with new, punch in the brand & model number here at FixYa to see if that unit also may suffer an early death.
Apr 03, 2009 | LG DP885 Portable DVD Player
I have a rca hdtv r52wh77 1 year old ,i have color problems ,i cant get to the convergence set up ,please help.thks
Try looking at the main board very near the flyback and you should see 3 fuse links (they look like hard capacitors) one of them is probably open causing lack or power to the convergence board by way of the ribbon seated close to the vertical output IC
Dec 22, 2007 | RCA P52937 52" Rear Projection Television
Akai LCT2715 27 in. LCD Television Logo
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
