Question about ASUS DRW-1608P DVD±RW Dual Layer Burner
Really slow burning
I recently bought and installed a new asus dvd burner, i installed it allright and it functions correctly however the reason i bought it was so that i could burn faster than what my existing burner could. this is not the case but.. from the moment the burn button is pushed it took about 2 hours to burn data onto a dvd+r. According to the software it was writiing at 16x, however this could not have been the case. any help with this would be appreciated... have i installed it wrong? or is it just incompatible with something, thanks sincerely Joel
  • Joel mcdonald Feb 11, 2007
    i did this and it did in fact make my burner work faster.... however it is still slower than it should be... i have no idea why this is... i have looked for speed controls and have found nothing
    Novelist:
    Champion:
  • 202 Answers
Joel, I would try updating the firmware. I had a problem with a DVD Burner that didn't work out of the box until I updated the firmware. You can find you update here: http://support.asus.com/download/download.aspx?SLanguage=en-us That should help. Good Luck, Tim
Posted on Feb 06, 2007
Hello I bought yesterday an ASUS DRW-24B3ST and a new computer and can't install win7 from USB because of missing CD/DVD driver
my advice is use another computer that has a cd/dvd burner and burn the copy of windows on to a blank disk that way you should be able to install windows
May 12, 2011 | ASUS INT DVDR 8X SATA NERO 9-BLK -...
Hi, i recently purchased a LG dvd burner and dont have a installation cd or software. Is there another way to fix this problem?
Hello, Your computer will automatically install the basic drivers for the burner to view cds but to burn a dvd or music cd or data cd or photo cd you will need software to do so. Windows XP and newer operating systems have a simple burning software using Windows Explorer which will pull the appropriate application automatically. I recommend a program such as Nero which originally comes with most burners. But for a more advance and controlled burning program Roxio has the easiest and most versatile program for about 50.00. Keep in mind if you want to make back-up copies of bought DVD movies or software you will have to have a specific program such as DVDFab. I can send you a copy of the actual software Cd that originally comes with your burner if you need it as I have bought several LG burners which now I have multiple copies of the software with OEM Keys. They have Nero V6.6 which is good for simple disk burning. Also keep in mind when buying blank disk NEVER buy the cheap unknown brands or the cheesy store brand disks as you will waste more disk due to bad coatings than you would if you bought better brands such as Memorex or Sony. Verbatim brand is a good inexpensive disk perfect for learning how a burner works due to the cost being reasonable and if you make a mistake burning the disk its not as bad a monetary loss. After you learn how to use the burner and program and you are ready to make good permanent disks then get an archival type disk with at least a 50 year storage time, (Your local computer store will help you with picking out the right kind, these disks are expensive but if you want to store vital photos or such this is the kind you need). Also A DVD-R is the most versatile disk for most players old and new and a DVD+R if more for burning on the "fly" and for newer expensive players. A CD/DVD±RW means you can reuse a single disk more than once but are very unreliable.
Sep 28, 2010 | LG GE20LU10 AUAE10B DVD±RW Burner
My dvdr/rw wont burn dvds properly
There are many reason for this.Try following steps to look out for solution.
1>Use better quality Dvd to burn .DVDs are just a few cents worth of plastic, manufactured in massive quantities. Sometimes you end up with a bad disk or a bad batch. Try a new disk, or a whole new brand, and you may have more luck burning your DVDs
2>Dust in your DVD burner can prevent it from burning DVDs correctly. Buy a lens cleaning disk and use it in your DVD burner drive. This can clean things up and give you a clean, successful burn.
3>For better quality burn at slow speed.It’s always tempting to burn DVDs at the highest speed possible. In theory, you’ll save time and can get more DVDs burned. In practice, though, higher speeds can result in unreliable burns.
Slow things down and set your DVDs to burn at 4x or even 2x. This may eliminate errors.
I hope this will solve your problem.
Mar 22, 2010 | Computers & Internet
Asus 2014s1 writes a dvd disc that it does not later read. but the slave dvd reads it. this happen with phillips+R, verbatim+R. I already downloaded and install firm software 1.01 but nothing changed. also...
I recently experienced the same problem. The cause is the drive itself is starting to fail. It will continue to degrade until it stops functioning completely.
The only thing you can do is replace it.
Feb 23, 2010 | ASUS DRW 2014S1T - Disk drive - DVDRW /...
Burn cds
Hi first thing go to
start
control panel
printers and other hardware
system (on left side)
hardware
device manager
DVD / CD rom drives
does it show up as a burner? DVD-RW or CD-RW
if not it may have a wrong driver installed If windows does not recognize it as a burner it will never work untill you get past the driver issue.
If the correct driver is installed
should be pretty simple there are many ways to burn
right click on a file and select SEND TO and send it to your burner usually drive D add all your files then select BURN FILES
or if they are media files you can use Windows Media Player
if all else fails track down a copy of Nero burning rom software or Roxio easy media creator.
Finally having said all that are you using the correct media?
if you try to burn files using a DVD on a non DVD burner it won't work.
also older burners were finicky and you had to watch your + and -'s
meaning if a DVD-R isn't working then try a DVD+R
if its an older burner you may consider upgrading it, a DVD burner can be bought on ebay or newegg for about $50 and its only a 2 cable install so its not to hard.
Another more extreme solution is to save all your files which you should be keeping in the "my documents" folder and do a system restore. (requires the factory restore disks)
This is very time intensive and can be VERY tricky but if the computer has been running for 3 plus years and is running slow it could probably use a fresh start and anything that has been corrupted over the years gets wiped away.
Hope that helps
Dec 29, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
To burn dvd-r on ASUS CB-5216A CD-RW/DVD-ROM.doest it supports the burninig of DVD-R
have the same same problem unsolved yet. it's not on the software actually, it's in the installation of the drive...
May 29, 2009 | ASUS CB-5216A (90D70001UAYZ) CD-RW/DVD-ROM...
Does not read dvd
According to Asus there are many burned dvd formats that are not supported or simply do not work in this drive. Asus stated that most dvd-r should work but not all, and that is the only burned dvd media that works. You may want to look into buying a different drive.
Dec 17, 2008 | ASUS DRW-1608P3S DVD±RW Dual Layer Burner
Wont burn cds , files , etc
well it could be many reasons why it wont write your burner but first what software you are using for burning. it happens to me before using media player when i try to burn music. the reason was i haven't configure my media player to use my dvd burner for burning because i have dvd burner and a cd burner installed. Now maybe you try to reinstall it using your dvd driver the one which with your dvd burner when you first bought it.
Nov 20, 2007 | Computers & Internet
The above internal burner not picking up blanck dvd-r
strictly speaking this is the correct response from your writer, as the disk "is" blank. Your DVD burning software, Like cloneDVD or Nero, should recognise the "blank" and then allow you to burn your disk image. you need to check that your DVD/CD authoring software is installed correctly and updated for all the latest features.
Aug 09, 2007 | ASUS DRW 0402P DVD-RW Burner
ASUS DRW-1608P DVD±RW Dual Layer Burner Logo
121 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
